Old Mar 10, 2010, 06:36 AM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Question
ESC Timing Mode
This may have been asked before and I did do a search however I came up empty handed. My question is, what exactly does the Timing Mode setting on an ESC and what is it function?
Thank you.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Mar 10, 2010, 09:23 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
In brushed motor you could turn the end bell and either advance or retard the timing which in turns causes the motor to spin faster or slower but always at a cost.
More timing faster or more power but less efficent & less battery time.
For brushless since their is no burshes, the timing is done by programming the ESC.
Timing programming varies with ESC but generally they have 3 or more setting.
LOW MID & HIGH or also reffered to with numbers 15 degree 20,25 degree in timing.
Its recommended by manufacturers to leave the timing on the default value or middle setting. But you can always experiment with different settings, it will also help if you have a watt/amp meter so you can physicaly see the difference.
freechip is offline Find More Posts by freechip
Old Mar 10, 2010, 09:35 AM
Joined Aug 2009
Thank you.
Old Mar 10, 2010, 01:35 PM
Ken Myers is online now
Find More Posts by Ken Myers
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
You might find this article useful
http://homepage.mac.com/kmyersefo/timing/timing.htm
Ken Myers is online now Find More Posts by Ken Myers
Old Mar 10, 2010, 02:42 PM
Joined Aug 2009
Awesome source of information, thank you for sharing.
Old Nov 29, 2014, 07:29 AM
alicecooper is offline
Find More Posts by alicecooper
Joined Apr 2014
Alasdairx
I tried experimenting with timing effects on my test rig, and was surprised how much efficiency I gained. At preset throttle and wattage input, my 2810/emax esc gained 5% exra thrust being moved from default mid setting 3 to 1. I then moved it to 5 and lost around 6% and, the esc got really hot, real quick. Same effect on my 3508 motors, so I'm sticking to low setting of timing. That's a total swing of 11%.
Similar result with frequency, 8k ran well, but is audible, 22k esc got super hot, and efficiency suffered, but makes motor silent to humans.
alicecooper is offline Find More Posts by alicecooper
Old Nov 29, 2014, 03:04 PM
Lnagel is offline
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Congratulations. You have just discovered by experimentation what is probably a little known, but truly valid, fact of ESC operation. It is always most efficient to use the lowest timing setting and PWM frequency that allows for smooth motor operation.
Larry
Lnagel is offline Find More Posts by Lnagel
Discussion High KV ESC Timing Question... mcauburn Foamy EDFs 30 Mar 01, 2010 12:27 PM
Discussion ESC Timing Question... mcauburn Foamy EDFs 2 Mar 01, 2010 07:51 AM
Discussion Motor/esc timing blues. radek Power Systems 4 Sep 14, 2009 01:35 PM
Discussion ESC Timing Guidlines mt_100 Power Systems 1 Aug 28, 2009 01:45 PM
Discussion Programming timing mode and pwm for esc jrubenis Power Systems 5 Jun 13, 2007 07:55 AM
