Old Mar 09, 2010, 08:16 PM
johngb is offline
Find More Posts by johngb
Joined Sep 2009
514W 12V 42A power
use IBM X345 Power for Hyperion EOS0615 DUO3 so .... Good!
johngb is offline Find More Posts by johngb
Old Mar 09, 2010, 10:29 PM
kapone is offline
Find More Posts by kapone
Joined Mar 2010
Mine's gonna be bigger!! Actually TWO of the following, running in parallel. Over 100A at 12v.
kapone is offline Find More Posts by kapone
Old Mar 09, 2010, 10:58 PM
johngb is offline
Joined Sep 2009
oh Cool 12C/54A so good!
Old Mar 09, 2010, 11:06 PM
3Dmuse is offline
Find More Posts by 3Dmuse
Ontario, Canada
Joined Sep 2009
EOS0615 DUO3 needs more than 14.5V to give you the full 180W per port. I'm afraid you'll be getting less from that charger if using a 12V power supply.
3Dmuse is offline Find More Posts by 3Dmuse
Old Mar 10, 2010, 09:13 AM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
Right but it only drops output by about 12%. So it depends on what your charging whether or not 12V input has an effect. For example if you only need 100W out of the charger 12V input is fine.
If y'all look in my blog I show how to get 24V. I have 4 Duos and charge 6S 5,000 packs from time to time so 24V is handy.
feathermerchant is offline Find More Posts by feathermerchant
Old Mar 10, 2010, 09:34 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
johngb
mind posting details on getting it to turn on and such. First time I have seen a IBM X345.
Old Feb 09, 2012, 08:36 AM
ppierluigi is offline
Find More Posts by ppierluigi
Joined Feb 2012
please :-)
Hi it'a a old post but... I own a pair of these, could you please tell me the pins that I have to short? the picture insn't clear
thanks
ppierluigi
ppierluigi is offline Find More Posts by ppierluigi
Old Feb 09, 2012, 10:34 AM
Joined Feb 2012
ok solved
a1 d3
pp
Old Feb 22, 2012, 10:22 AM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Originally Posted by everydayflyer View Post
johngb
Same here. I have 2 to convert, hopefully today, but need to know what pins to short...
Rick
rampman is offline Find More Posts by rampman
Old Feb 22, 2012, 03:09 PM
rampman is offline
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
I did not understand the a1 and d3 in post #8 above.
To make searches easier for others I will put all label info here.
The label shows:
Model: ARTESYN 7000758 - 0000 REV A.
FRU P/N 7000758 - 0002
IBM P/N: 49P2166
IBM FRU P/N: 49P2167
EC NO.: H22799T
Input:
120V - 7 A (Amps)
220V - 3.5 A (Amps)
Output:
+12V 42A
+5V 2.0A
Maximum continuous output is 514 watts.
Should be the same for the IBM X345 as the pictures above looks the same as my unit.
Place the power supply as shown in picture above.
Top row, third pin from left (PIN3) will tie with the bottom left pin, the short pin (PIN13).
I have not put a load on it yet but the 12V DC is active and the green DC LED on the front lights up. Also, the fan runs slow at all times 120V / 240 volts is applied but it speeds up some when these pins are tied together.
Rick
Old Jul 06, 2012, 08:18 AM
rcgchris is offline
Find More Posts by rcgchris
...muy bien...
rcgchris's Avatar
Germany, BW, Pforzheim
Joined Jul 2012
Seems to be a nice PS because of size, weight and output of 12V@42A and 5V@2A with up to 514W output.
To me it's not clear where the pins needs to become shortened. Counting from where? Can you supply a foto?
Has anybody modified this PSU to bind two units together for 24V?
Is it possible to add some electronics to fetch other voltage as well in order to use this as a more universal power source?
rcgchris is offline Find More Posts by rcgchris
Old Jul 06, 2012, 08:25 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Originally Posted by rcgchris View Post
Seems to be a nice PS because of size, weight and output of 12V@42A and 5V@2A with up to 514W peak.
I got two of these from feathermerchant a while back and previously was floating the AC ground to run 24V but just modified it using some instructions from him to isolate the DC side instead. Here's the instructions:
http://www.rcgroups.com/forums/showp...&postcount=431
The pins to short are in the little grid on the back to the side of the main connections. I would have to look at it when I get home to see which pins are shorted and compare to what someone gave above.
As for other voltages these are really designed to just be 12V supplies mostly I think. That's the advantage over a desktop power supply.
grimbeaver is offline Find More Posts by grimbeaver
Old Jul 06, 2012, 09:34 AM
rcgchris is offline
...muy bien...
rcgchris's Avatar
Joined Jul 2012
Originally Posted by grimbeaver View Post
I was previously floating the AC ground to run 24V, but just modified it using some instructions from him to isolate the DC side instead. Here's the instructions:
Thanks a lot! I hope to see the picture from yours to find the right pins as well.
Old Jul 06, 2012, 10:40 AM
United States, MN
Joined Feb 2011
I'll stress this mod is not for the unskilled. Highly recommend using a good flux to solder to the trace as getting it to stick is extremely difficult and though it doesn't look that cramped it suddenly gets smaller when you try and stick a soldering iron in there.
Old Jul 05, 2013, 02:05 PM
heckmic is offline
Find More Posts by heckmic
Germany, NRW, Nottuln
Joined Mar 2011
Could you please tell me which pins you have connected? I can only see that one is the third from left in the upper line. Which one is the another pin.
Thanks!
Edit:
Got it: Top row, third pin from left (PIN3) will tie with the bottom left pin, the short pin (PIN13).
heckmic is offline Find More Posts by heckmic
For Sale 12V Power supplies 42A $50 and 12/24V 47A power supplys for your chargers feathermerchant Aircraft - Electric - Batteries & Chargers (FS/W) 234 Apr 10, 2012 06:52 AM
For Sale 12V Power supplies 30A $40 and 42A $50 for your chargers feathermerchant Aircraft - Electric - Batteries & Chargers (FS/W) 1 Sep 03, 2009 08:07 PM
Sold POWERFUL 12V 30 Amps Power Supply SLIM & LIGHT - FREE PRIORITY davebd Aircraft - Electric - Batteries & Chargers (FS/W) 0 Aug 24, 2009 02:04 AM
