Old Mar 09, 2010, 01:04 PM
WBFlyer is offline
Find More Posts by WBFlyer
WBFlyer's Avatar
Portland, OR
Joined Feb 2007
Muliplex EasyStar
Can you do ground takeoffs with the addition of landing gear?
WBFlyer is offline Find More Posts by WBFlyer
Old Mar 09, 2010, 01:15 PM
JettPilot is offline
Find More Posts by JettPilot
JettPilot's Avatar
Miami
Joined Apr 2005
Sure !!!! I have seen videos of them taking off the snow just by sliding on the belly. Be very careful not to add a bunch of weight and drag though. I dont think adding gear to this plane is a good idea performance wise, but it would work fine.
JettPilot is offline Find More Posts by JettPilot
Site Sponsor
Old Mar 09, 2010, 01:38 PM
Acorns is offline
Find More Posts by Acorns
United States, IA, Mason City
Joined Oct 2008
As Jett says, depending on the motor you may not even need the gear. I have a Eflight 2000kv on mine and with a vtx/cam it will slide off of a thin grass or snow with no problems.
On the other hand, while the EZ makes a great fpv platform with minimal gear, it flies like sh*t when you put much weight on it. Try a Radian if you want a cheap, good replacement.
Acorns is offline Find More Posts by Acorns
Old Mar 09, 2010, 03:17 PM
WBFlyer is offline
WBFlyer's Avatar
Portland, OR
Joined Feb 2007
Well, I saw somewhere they sell a addon gear kit for the Easy star. I like to be able to take off and land in a seperate field (on a strip of concrete in the middle of the field) and then take off again. I think it would be impossible without gear.. I have been doing this with a small .40 balsa trainer but if you have a not-so-perfect landing, I spend a lot of time fixing damaged wingtips etc...
Old Mar 09, 2010, 03:45 PM
mrfliboy is offline
Find More Posts by mrfliboy
Don't leave it Stock
mrfliboy's Avatar
USA, IL, Round Lake
Joined Feb 2004
I saw the gear you're talking about, being advertised at the top of RCGroups Banner, which changes constantly. Hope this helps.
mrfliboy is offline Find More Posts by mrfliboy
Old Mar 09, 2010, 04:30 PM
WBFlyer is offline
WBFlyer's Avatar
Portland, OR
Joined Feb 2007
Yeah, and in RC mag. I think that would be what I need. I do like to fly with Alirons though...
Old Mar 10, 2010, 09:08 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Then Stick on a set of Easyglider wings on it. That helps with the extra weight.
Flypoppa is offline Find More Posts by Flypoppa
Old Mar 10, 2010, 11:57 AM
Jhondra is offline
Find More Posts by Jhondra
KF7JBN
Jhondra's Avatar
United States, ID, Nampa
Joined Nov 2008
Who needs gear? My 250W inrunner drives the plane just fine on it's belly across grass. With full video and loaded for bear on lipo's, I still prefer to hand launch though. Grin.
Jhondra is offline Find More Posts by Jhondra
Old Mar 10, 2010, 01:30 PM
skunkworks2006 is offline
Find More Posts by skunkworks2006
skunkworks2006's Avatar
Michigan
Joined Nov 2006
Run some heavy duty strapping tape along the bottom and you can even land on pavement if needed. I've done this some, and it works okay. You just replace the tape when it gets worn. I still prefer grass and snow though, and like others can ROG w/out landing gear.
skunkworks2006 is offline Find More Posts by skunkworks2006
Old Mar 10, 2010, 03:09 PM
Jhondra is offline
KF7JBN
Jhondra's Avatar
Joined Nov 2008
Screw the tape! Just make sure you are crashing your easystar a couple times every month, and then you have a reason to redo the fuse every 6 months from spare fuse stock.
I'm joking.
Mini-Review EasyStar RR from a Beginners Point of View WAFlyer15 Beginner Training Area (Aircraft-Electric) 33 Jun 02, 2010 10:50 AM
Discussion Easystar maiden!! ashdec87 FPV Talk 3 Mar 03, 2010 03:42 PM
Discussion Easystar - fixing and new electronics ampsonic Beginner Training Area (Aircraft-Electric) 11 Feb 26, 2010 04:52 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
