Joined Aug 2005
I have retired the DragonOSD project. The successor is the DragonOSD+:-
http://forum.tsebi.com/viewtopic.php?f=7&t=63 http://forum.tsebi.com/viewtopic.php?f=7&t=62
Daniel |
Joined Aug 2005
This is the DragonOSD+. It is actually about a quarter the size of the old DragonOSD+BOB4 which is about half the length of the older OSD and slightly narrower. It has a better power supply (switching and heavily filtered with reverse polarity protection) that doesn't get hot and runs down to 4.6V and way past 16V. It sports a bunch of things the old OSD doesn't including over 60 times bigger flight log with the ability to store multiple flight logs. It supports a bunch of peripherals on a I2C bus (which is not available on the old OSD), including magnetic compass, barometric altitude, true air speed, temperature, among other things. The new OSD also has audible warnings as well as an audio variometer function. Basically, just about everything is better, smaller, lighter and vastly cheaper.
At this point I've retired the older DragonOSD project and am not developing the firmware anymore. To see some of the feature set, you can check the first column in the follow spreadsheet:- http://spreadsheets.google.com/pub?k...jg&output=html The plan is that we will sell a number of these units at a lower than usual introductory price. The units have already been made but we are waiting to test a few sensors to make sure they all work. John (JMSTECH) has the OSDs in his house right now. Daniel |
Joined Aug 2005
That's to help you maintain an optimal approach for landing. You basically try to keep the indicator at the center of the scope while maintaining your landing speed.
The following links explains how it works:- http://www.navfltsm.addr.com/gs.htm http://www.flightsimaviation.com/avi...lideslope.html Daniel |
Joined Aug 2005
The following link (listed above) details this:-
http://forum.tsebi.com/viewtopic.php?f=7&t=62 The specific pinout of the GPS port can be seen in the second photo in the following link (also listed above):- http://forum.tsebi.com/viewtopic.php?f=7&t=63 Daniel |
Joined Aug 2005
For the introductory units, probably not. I have no money to buy a bunch of GPS units anyway.
The horizon draws a line for when the IMU is attached, or when the magnetic compass is attached. The magnetic compass from SFE contains a 3-axis accelerometer. While this does not really work well in a dynamic situation (ie. when moving or accelerating) it should work okay in more static scenarios. In the latter case, I just added it for fun. With the IMU, it should reflect the roll and pitch of the sensor/plane. Like in the following video:-
I am not happy with the performance of the earlier IMU/INS prototypes though, so I'm still working on it. Daniel |
| Thread Tools | |
| For Sale New Intelligent Flight Dragon OSD | bfischer | Aircraft - Electric - Miscellaneous (FS/W) | 7 | Jul 19, 2010 11:56 AM |
| Discussion FS Ready to fly Intelligent Flight Dragon OSD | bfischer | Video Piloting (FPV/RPV) | 0 | Mar 03, 2010 05:57 AM |
| Discussion Co Pilot and Dragon OSD - Jitters | russc243 | Video Piloting (FPV/RPV) | 10 | Jan 18, 2010 10:07 AM |
| Discussion RV OSD or Dragon OSD | djdaveq | Video Piloting (FPV/RPV) | 1 | Feb 06, 2009 12:18 AM |
| Discussion RV OSD and Dragon OSD - so near to being Really good! | magnetman | Video Piloting (FPV/RPV) | 8 | Nov 11, 2008 05:13 AM |
