Old Mar 08, 2010, 03:55 PM
ICRSHLTS is offline
Find More Posts by ICRSHLTS
Two Rivers, WI
Joined Mar 2003
adding wing center section
I have a built up wing- ARF that is supposed to be glued together with a 1/4 spar in it as well. what would you guys do to add 2 1/5 inches to the middle to make the wingspan longer. 2 1/5" is a little much to just make a buch of plywood ribs. any help appreciated. Ryan
ICRSHLTS is offline Find More Posts by ICRSHLTS
Old Mar 08, 2010, 05:38 PM
rotccapt is offline
Find More Posts by rotccapt
that tree ate my plane
rotccapt's Avatar
oklahoma city oklahoma
Joined Apr 2004
your best bet would be to make templets of the root ribs and make duplicates glue them in and sheet the section
rotccapt is offline Find More Posts by rotccapt
Old Mar 09, 2010, 05:09 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
A block of foam could be used and shaped to suit, then a glass bandage wrapped around for strength.
eflightray is offline Find More Posts by eflightray
Old Mar 09, 2010, 11:38 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
seconded.
also saw in a couple of ply braces running vertically.
Wanted 2.5M Organic Center Section dang Aircraft - Sailplanes (FS/W) 0 Mar 05, 2010 08:41 PM
Wanted Valenta Dogan wing center section or entire wing Cruzsin Aircraft - Sailplanes (FS/W) 2 Aug 25, 2009 07:44 AM
wnt: airtronic legend center wing section kjkavaney Aircraft - Sailplanes (FS/W) 3 Jul 04, 2003 09:58 PM
To fiberglass or not to fiberglass wing center section? Muah Electric Plane Talk 23 Dec 05, 2002 07:42 AM
