Old Mar 08, 2010, 01:22 PM
Capt.Crash is offline
Find More Posts by Capt.Crash
**NOT GUILTY**
Capt.Crash's Avatar
Millbrook, Alabama
Joined Jun 2004
Help!
Vinyl Graphics Workshop
I need some help in appling my first set of vinyl graphics.
This set is rather complicated as can be seen in the attached pic.
I can't find much on the subject in the boat threads, so I thought a new thread might help me.
I need the do and don't of how to apply this expensive eye candy.
I look forward to hearing from all you experienced modelers.
Crash
Capt.Crash is offline Find More Posts by Capt.Crash
Old Mar 08, 2010, 02:27 PM
toesup is offline
Find More Posts by toesup
USA'd ex Brit
toesup's Avatar
Back.. In California
Joined Aug 2006
Are you going to attempt the checkerboard in vinyl?...
.... or just the name?...
toesup is offline Find More Posts by toesup
Old Mar 08, 2010, 03:23 PM
**NOT GUILTY**
Capt.Crash's Avatar
Millbrook, Alabama
Joined Jun 2004
The whole deal....I have the checkerboard graphics and it will be quite the challenge to figure out how they go. Right now I need the experience of how to actually apply them. I'm undecided on the soapy water (wet) method or just go for it and put em where they first touch. I can't find anyone who has actually used this set of checkers. I have a week before my paint will be dry enough...maybe I'll figure it out by then...lol
Old Mar 08, 2010, 03:39 PM
norgale is offline
Find More Posts by norgale
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
I've not used any vinyl graphics before but I can tell you that it's way better to be able to move them around some while putting them on. I assume you can use soapy water ,slide the graphics around to where you want them and then squeege the water out. Vinyl sticks instantly and easily tears when you try to pull it up to move it. I'd sure want to use the water if it were me. Pete
norgale is offline Find More Posts by norgale
Old Mar 08, 2010, 04:28 PM
Bob Bighinatti is offline
Find More Posts by Bob Bighinatti
Weare NH
Joined Nov 2007
I have seen sign guys that do vans use a sheetof somesort of low stick paper over the letters and then peel off the backsid of the vinel I think they use window cleaner to move it around and sqeagie it out when it it is all set and then slowy peel back the low stick paper. I would call a sign shop or Cali graphics or were you bougth them from
Bob Big
Bob Bighinatti is offline Find More Posts by Bob Bighinatti
Old Mar 08, 2010, 05:02 PM
Jacques Flambeau is offline
Find More Posts by Jacques Flambeau
Restful User
Jacques Flambeau's Avatar
Backwoods Alabama
Joined May 2000
You have a yellow-painted boat and you want to put the black checkreboard squares on it? What is the brand-name (or source) of the vinyl graphics? We need a littlr more info on what you are using.
There are compound curves on the hull and it's going to be a bit tricky to get everything to line up just so.
--Bill
Jacques Flambeau is offline Find More Posts by Jacques Flambeau
Old Mar 08, 2010, 05:36 PM
Restful User
Backwoods Alabama
Joined May 2000
Been wracking my brain... in the '80's there was a guy who did amazingly beautiful Monokote (heat-activates aircraft film covering) work. Wrote a book or two on the secrets. I've got one, somewhere. Although you are using vinyl graphics, the layout work will be the same. Anyone remember his name?
Anyways, finding Monokote techniques will be the key, IMO.
--Bill
Old Mar 08, 2010, 06:34 PM
toesup is offline
USA'd ex Brit
toesup's Avatar
Joined Aug 2006
That's an understatement!
I would paint the boat yellow and then paint on the black squares.. that's going to be a lot easier than trying to line up 'squares' on all those compound curves... plus, the square's are not square...
Old Mar 08, 2010, 08:25 PM
420TEE is offline
Find More Posts by 420TEE
North Central TN USA
Joined May 2006
Non square question. What in the world is that thing behind the drivers head? Some sort of early aero design?
420TEE is offline Find More Posts by 420TEE
Old Mar 08, 2010, 08:29 PM
jjac is offline
Find More Posts by jjac
I'm tired.....
jjac's Avatar
Conway,Myrtle Beach SC
Joined Jul 2009
You need to mask the vinyl with some masking first. If it is a good grade of vinyl it will conform to the curves of the boat. Look on ebay and buy a small bottle of rapid tac and spray the boat down with it apply vinyl and squeegee the vinyl down. On some of the tighter curves you can wave a heat gun over the vinyl for a second or two to make it more pliable. I am a sign guy and do vinyl everyday! Been building signs for 15 years now.
jjac is offline Find More Posts by jjac
Old Mar 08, 2010, 11:28 PM
mr_impervious is offline
Find More Posts by mr_impervious
mr_impervious's Avatar
Detroit Metro, MI, USA
Joined Dec 2007
The guys on Two Guys Garage spray blue Windex all over where they're going to put the vinyl graphic. This lets them reposition a little bit, then when it is in it's place they squeegee the liquid out. They use an Xacto knife to open air bubbles out and for curves.
I'd try this Windex method on a scrap piece first, though. Just in case.
I'd also check the import car tuners websites. Those guys are putting vinyl graphics everywhere. They should be able to help.
mr_impervious is offline Find More Posts by mr_impervious
Old Mar 08, 2010, 11:48 PM
Ron Olson is offline
Find More Posts by Ron Olson
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
Instead of using soapy water you can use a Windex type of glass cleaner or windshield washer fluid, the latter being cheaper as you're going to be using a lot on a design like that. It does work well as my sister and brother-in-law have a laser cutting business and after I told my bro-in-law about windshield washer luid that's all he uses now when putting vinyl lettering on store windows.
Avery makes a good vinyl or Top Flite's TrimKote which is easier to get unless you go through a signmaker's shop.
There are some people who can do wraps for your hull also but from what I've seen, that can be tough to lay on.
Ron Olson is offline Find More Posts by Ron Olson
Old Mar 09, 2010, 07:01 AM
**NOT GUILTY**
Capt.Crash's Avatar
Millbrook, Alabama
Joined Jun 2004
Yes
What is the brand-name (or source) of the vinyl graphics? Wesley's Custom Graphics
--Bill
I've read that you do NOT want to use anything with ammonia in it like Windex because it will ruin the tacky on the vinyl....but I also hear from others that Windex works pretty good.
I read that I need to mask a piece of tape across the top of the piece to be laid then fold the graphic over using the tape as a hinge to keep things lined up. That may work on some pieces but I don't know about masking on top of newly laid vinyl for some of the other pieces.
I remember doing the "monocoat" graphics on a few planes back in the day and I used soapy water for that, but that was also on a wing surface that was fairly flat, or a fuselage that was mostly flat.
420TEE the thing behind the head is a head rest. A lot of the boats at this period of time used this configuration. The reason I chose this boat to build is because of that headrest and the cool graphics. I started a build thread here:
http://www.rcgroups.com/forums/showthread.php?t=1159612
It seems there are a number of articals available on the web...I guess I should have done a search there first, but having that info here is not a bad thing. Below are several sites that I found with useful information.
http://www.customvinylgraphics.com/a...-graphics.aspx
http://www.associatedcontent.com/art...rs.html?cat=24
http://www.buildasign.com/p/How-Tos/Vinyl_Graphics.aspx
Here is where I'm at on the build.
Crash
Old Mar 09, 2010, 07:54 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
I have a friend who is pretty big into Bardahl. Let me ask him.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Mar 09, 2010, 08:01 AM
CornelP is offline
Find More Posts by CornelP
CornelP's Avatar
Bucharest, RO
Joined May 2009
Windex is ok only for decals... it will ruin the glue.
I would say use some soapy water (dish detergent is very good...). Cut the graphic into 3 or 4 main parts, to apply easier. Think about the angles of view of the boat to make sure that a small error will not show.
I suugest you cut as in the attached pic. Use plenty of soap, better if you use a spray for it, and make sure you mark before applying, just a thin line with a pencil is enough. I do not know what transfer media you have, but the paper based one is a bit better. The transparent vinyl one is very good when positioning, but a nightmare to flex on surfaces....
Two more suggestions: buy another set of graphics, just in case, and, if were you, I would still do this with an airbrush, much easier and more precise...
CornelP is offline Find More Posts by CornelP
Discussion Kirby's Vinyl Graphics -- Great product Garret H Hot Online Deals 26 Feb 10, 2010 11:21 PM
FS: Custom Vinyl Graphics for iStar Pattern Parkflyer Andy Steere Aircraft - Electric - Airplanes (FS/W) 3 Feb 12, 2005 07:16 PM
Custom cut vinyl graphics kdill2160 Product Announcements 0 Nov 02, 2004 03:29 PM
Vinyl graphics Doc Data Electric Plane Talk 7 Aug 30, 2004 08:29 AM
Computer Cut Vinyl Graphics rcbrust Hand Launch 0 Sep 23, 2002 11:48 AM
