Old Jun 20, 2010, 11:22 PM
Thanos is offline
Find More Posts by Thanos
Athens, Greece
Joined Apr 2009
Thanks amigo. 1,9oz could not make that big af a difference!!? Maybe it was my esc whitch got burned after my second -in the house- trial. Maybe I'll try again with another esc. Thanks,
Thanos
Thanos is offline Find More Posts by Thanos
Old Jun 23, 2010, 07:17 PM
makeitworst is offline
Find More Posts by makeitworst
UH-1 Gunship, AH-1G jock 69-71
makeitworst's Avatar
So Cal ... Kingdom of Taxes
Joined Nov 2008
Motor mount source
Where did you buy the long in-fuse motor mount from? I thought that type has dried up. Haven't seen any on the net for quite a while. How much are they?
Links appreciated.
makeitworst is offline Find More Posts by makeitworst
Old Jul 28, 2010, 08:13 AM
tonystro is offline
Find More Posts by tonystro
TonyS
United States, AR
Joined May 2010
Links appreciated.
Apparently your post was missed. The motor mounts are available from the online store at sdparkflyers.com.
TonyS
tonystro is offline Find More Posts by tonystro
Old Jul 28, 2010, 10:27 AM
tallflyer is offline
Find More Posts by tallflyer
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
Thanks TonyS
Yes I have them in my online store and so do a few of my Online Friends
tallflyer is offline Find More Posts by tallflyer
Latest blog entry: Yunnec Typhoon H Review
Old Jul 29, 2010, 11:25 PM
Joined Nov 2008
Thanks for the info, will check out the site.
Old Aug 21, 2010, 08:36 AM
jclassic1 is offline
Find More Posts by jclassic1
jclassic1
New Houghton, Derbyshire, UK
Joined May 2006
Going to build mine from 6mm black depron.Always a bit breezy where I fly so a bit of extra weight won,t hurt.I have used epp before but prefer depron for building with.Should not need so much carbon stiffeners on this one.
John
jclassic1 is offline Find More Posts by jclassic1
Old Sep 16, 2010, 11:22 PM
Joined Nov 2008
Google Sketch file
Originally Posted by tallflyer View Post
I have to be honest this plane came out better then I thought it would.
I hope to get a video up in the next couple of days so stay tuned!
Robert,
Would you have a Google SketchUp file for this plane you might share? I'd like to play around with trying different scales for the plane (like in smaller) and some minor mods.
Old Sep 16, 2010, 11:40 PM
tallflyer's Avatar
Joined Jul 2002
Sketchup file!
Let me find the file and I will post it!
Old Sep 20, 2010, 11:53 PM
Joined Nov 2008
Robert,
Your link ( Motorfly 2205-1350 More Information here) on the first page of this thread is dead. Goes to a 404 Error.
Any luck on find the Sketch Up file for the SloRoller?
Old Sep 21, 2010, 01:02 AM
tallflyer's Avatar
Joined Jul 2002
Fixed the Link!
Found the file let me upload the sketchup file next post!
Old Sep 21, 2010, 01:05 AM
tallflyer's Avatar
Joined Jul 2002
Sketchup file.
Send me a email to thebigdog@san.rr.com and I will send you the file
Robert
Old Jan 19, 2011, 09:44 AM
Matt51 is offline
Find More Posts by Matt51
pattern
Matt51's Avatar
Indiana
Joined Oct 2009
how well does this fly
Matt51 is offline Find More Posts by Matt51
Old Jan 25, 2011, 11:11 AM
jclassic1
Joined May 2006
I saw this bipe a while back but forgot what it was called so have only just found it again.Plans printed and cut out.Going to be built with 6mm black depron for outdoor use only.
I will post some pictures of the build.
Thanks Tallflyer this looks like a good one.
John
Old Jan 26, 2011, 12:38 AM
tallflyer's Avatar
Joined Jul 2002
just make sure to put some type of landing gear on this plane otherwise the plane will be a little top heavy!
Old Jan 26, 2011, 01:34 AM
jclassic1
Joined May 2006
Thanks tallflyer for the advice about the landing gear.My problem is the field that I fly from is too rough for using landing gear on these lightweight foamies so none of mine have any.If I mount the battery low down near the bottom wing do you think that might help.This is going to be for outdoor use only so I am not after a super lightweight plane perhaps around 9-10 ozs rtf.
I will probably use the cruciform type of fuselage construction to cut down on tail twist or perhaps two fuselage sides with a narrow (1") former to make a narrow full fuse bipe.I don,t know how much weight that might add but foam is cheap so it must be worth a go.
Love the video on page one,never thought a plane could fly that slowly and still be controllable.
John
Build Log Superslo28" Build,Tip,Tricks thread! tallflyer Foamies (Scratchbuilt) 2568 Jul 26, 2016 03:21 PM
Video Slofly28 Superslo tallflyer Electric Plane Talk 2 Nov 15, 2008 10:01 AM
Sold Slofly28" Superslo kit tallflyer Aircraft - Electric - Airplanes (FS/W) 1 Sep 11, 2008 10:33 AM
Video slofly28" super slow tallflyer Electric Plane Talk 2 Apr 27, 2008 08:56 PM
