Old May 11, 2010, 12:07 AM
tallflyer is offline
Find More Posts by tallflyer
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
I think if you build it all out of 9mm it will still fly if you use a bluewonder since its all about weight use a small 3 cell battery like a 300 mah and do anything you can to keep weight down.
tallflyer is offline Find More Posts by tallflyer
Latest blog entry: Yunnec Typhoon H Review
Old May 11, 2010, 02:04 PM
amigo is offline
Find More Posts by amigo
Roll Tide!
Joined Oct 2005
thanks. I may just order the 6mm epp from rcfoam--they don't have 5mm--for the wings. But you didn't mention what kind of lipo you use for the Sloroller and the time you got from it with the specified prop. Best to you.
amigo is offline Find More Posts by amigo
Old May 11, 2010, 10:11 PM
tallflyer's Avatar
Joined Jul 2002
I like the motrofly 1350 with a 2 cell 360 rhino pack 7.4 volt 2 cell and a GWS 9050 prop battery is a (20 C ) pack I then went to a 2 cell pack that is a 350 (30c) pack and get about 7 minutes of good flying just don't hover for too long this plane will suck up the battery.
Old May 13, 2010, 02:09 PM
amigo is offline
Roll Tide!
Joined Oct 2005
2 questions for you Tall: 1. Where's the CG? 2 Did you do a 45 degree bevel on the ailerons and the trailing edge of the wings (where the ailerons attach) or did you just do 45 degree bevels on the ailerons?
thanks for any info.
Old May 15, 2010, 02:39 AM
tallflyer's Avatar
Joined Jul 2002
cg is right on the wingspar of the top wing
And yes I put 45 bevels on all control services.
Old May 15, 2010, 11:42 AM
amigo is offline
Roll Tide!
Joined Oct 2005
Thanks! I'll post a picture when I'm done.
Old May 21, 2010, 10:24 AM
amigo is offline
Roll Tide!
Joined Oct 2005
It's coming along. Differences from plan: all 1.3, 9mm EPP, side braces instead of carbon tube along fuselage and home-made firewall mount.
Old May 24, 2010, 10:10 PM
amigo is offline
Roll Tide!
Joined Oct 2005
Hey Tall,
Maidened it this evening. Man, that was fun! 8.25oz AUW with a 3S460mAh rhino, but it was still very floaty. It was even floatier with a 3S 360mAh rhino and hovered just as well. I can finally enjoy a biplane. My tensor keeps me on edge and that's not as fun as when you can relax.
Flights were typically 4 minutes hover and 4 to 5 minutes of flying around. It almost hovers itself and if you can get it in the right spot it almost knife-edges by itself too. It's a good design, but you have to use the rudder. I don't have a video camera, but if I ever get a chance I'll get somebody to video. Thanks for a great design!
Is your super-slo 28 as fun as the Sloroller? If it is, I'll have to start building. I almost did start the SS-28 but another project got in the way.
Old May 25, 2010, 01:14 AM
tallflyer's Avatar
Joined Jul 2002
yes Its a fun plane and the way you built it using foam as side braces makes the plane stiff and light enough to have fun.
I want to make a version out of all 6mm foam the weight saved would make this plane a Superslobipe that might just hover own its own.
The superslo28 is a floater but not like the bipe but will do better 3D
Version 2 is in the works so stay tuned.
Old May 25, 2010, 03:10 PM
amigo is offline
Roll Tide!
Joined Oct 2005
I think I'll do that too--use 6mm. I'm assuming you mean 1.3# 6mm EPP, not depron, for your new Sloroller. Thanks for all your help in building and giving info and tips.
Old May 26, 2010, 02:24 PM
amigo is offline
Roll Tide!
Joined Oct 2005
Here's the finished product after putting on a landing gear. I thought about leaving it without the gear (and extra weight), but I love doing touch and gos. AUW with gear and no battery: 6.84 oz. Thanks again, Tall for such a neat design.
Old Jun 19, 2010, 06:46 AM
Thanos is offline
Find More Posts by Thanos
Athens, Greece
Joined Apr 2009
Help It's heavy!!
I just finished my Sloroller but it came up 285gr (10oz). It's all 6mm depron and my setup: HXM2730-1300 motor (http://www.hobbyking.com/hobbyking/s...idProduct=2069), 12A esc, 500mAh 3s lipo, two 5gr and one 9gr servos. I tried 8x3.8 and 9x6 props but no luck! Motor gets really hot (80 C) and it hovers at almost full throttle. Any suggestions for another motor at 12A?
Thanos
Thanos is offline Find More Posts by Thanos
Old Jun 19, 2010, 10:36 AM
tallflyer's Avatar
Joined Jul 2002
Thanos
You might need to use a Motor like this one
Turnigy C35 From Hobby City
Old Jun 20, 2010, 07:03 AM
Thanos is offline
Athens, Greece
Joined Apr 2009
Thanks TallFlyer. It seems kind of heavy and too big though!! 77gr motor?
I know it won't be match of a slow-roller with 300gr but I hope it will fly decently. I looked up a bit and found http://www.hobbyking.com/hobbyking/s...idProduct=2111.
Thanks for your input and time. (Definitely big thanks for the free plans... slofly28 is my everyday plane!!)
Thanos
Old Jun 20, 2010, 05:43 PM
amigo is offline
Roll Tide!
Joined Oct 2005
Hi Thanos, I used pretty much the same set-up as you. I use this motor with a GWS curved 8043 prop, a 10 amp esc and a 3s 460mAh rhino:
http://www.headsuprc.com/servlet/the...lectric/Detail
I used .047 carbon rods for pushrods. I get about 4 minutes of pure hover and the motor gets a little hot. I get up to 10 minutes of easy flying and the motor gets a little warm. So I don't know what to suggest. Maybe depron is much heavier than 9mm 1.3# EPP.
My AUW with the 3s 460mAh rhino is 8.34 oz. Best of luck!
Build Log Superslo28" Build,Tip,Tricks thread! tallflyer Foamies (Scratchbuilt) 2566 Jun 24, 2016 01:13 AM
Video Slofly28 Superslo tallflyer Electric Plane Talk 2 Nov 15, 2008 10:01 AM
Sold Slofly28" Superslo kit tallflyer Aircraft - Electric - Airplanes (FS/W) 1 Sep 11, 2008 10:33 AM
Video slofly28" super slow tallflyer Electric Plane Talk 2 Apr 27, 2008 08:56 PM
