Old Mar 07, 2010, 06:16 PM
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
EPP Foam Sloroller 3D Biplane
The New Sloroll biplane is based on the World famous Slofly28 made famous by Sloper steve and Gene bond, for years now I had started this project only to be side track with other builds and projects, I decided yesterday to revisit my project And the Sloroll was invented.
I came up with my Name after testing here indoor and the fact that she rolls slow and smooth.
Download the free PDF and build yours today.
"Printer tip"
Make sure that when you print the file you check
these two boxes under print the page scaling option.
Fit To Printable Area
Auto-Rotate And Center
Ok Fist off the items I had planed on using for the plane were simple items for the pilot and the builder on a budget.
1. Motorfly 2205-1350 More Information here
1. 10 amp brushless esc
2. 5 gram bluebird 306 servos for the Rudder + Elevator + 1. 9 hxt900 gram for the Ailerons
I would be using a gws tyrp 4 channel receiver
gws 9050 prop
9mm 1.3# epp foam for the fusealge + Rudder + Elevator
5mm 1.3# for the wings since there are now 2
and 5mm for the new wing braces.
3mm carbon was used for the fusealge + elevator
5mm flat carbon was used in both the wings
a motor mount the kind I sell on my site was used
I also went with 2mm carbon rods for the x bracing for the wings
and the control rods and Aileron linkage,
grabed some stir sticks from starbucks for the control horns for the ailerons
This plane can be built using all the plans from the original sloyfly28 with a few minor mods I will post pictures so you can see how I did what I did!
Pictures speak volumes so as soon as I get home I will upload..
First Look Video
Sloroll Epp foam Biplane (2 min 28 sec)
Sloroll EPP Foam Airplane Movie #1 (4 min 4 sec)
tallflyer is offline Find More Posts by tallflyer
Old Mar 08, 2010, 12:08 AM
tallflyer's Avatar
Joined Jul 2002
Pictures!
Ok here are the long awaited Photos of the slobipe It's a little plane jane " Only white EPP for the demo.
Old Mar 08, 2010, 12:18 AM
tallflyer's Avatar
Joined Jul 2002
More Pictures
Here is a few more pictures!
Old Mar 08, 2010, 12:36 PM
tallflyer's Avatar
Joined Jul 2002
I will try and make the plans tonight with the upgrades using google sketchup so I can create a PDF for you scratch builders
as I posted before the only things changed on the original plane was I added a top wing piece of foam to the original fuselage I moved teh location of the wing straight down to the lowe part of the fuselage and straight up for the top section.
the wings are made of 5mm epp with flat carbon bracing used.
the wing struts are also made of 5mm epp
The rest of the plane is built stock
The demo model uses dubro ez-connectors I think I would do z-bends as getting to the little set screws can be a little tough.
the carbon pushrod method used for the top ailerons was a idea that I got from a kit I built from my friends over at www.budgetrc.com
as I tried control rods but there was way to much play and the Ailerons were flapping around.
I hope to get out and fly the prototype in the next couple days so stay tunned for the video.
Old Mar 09, 2010, 03:38 AM
BOXFUSE KING!
Kronikpilot's Avatar
NO WIND CITY GUAM U.S.A
Joined Jan 2009
Awesome work Robert, can't wait for the flight vid. Thanks for sharing.
Mayday.
Kronikpilot is offline Find More Posts by Kronikpilot
Old Mar 09, 2010, 08:37 AM
tallflyer's Avatar
Joined Jul 2002
Sloroller
I have to be honest this plane came out better then I thought it would.
I hope to get a video up in the next couple of days so stay tuned!
Old Mar 10, 2010, 02:46 AM
sturdybird46's Avatar
Hayward, Ca
Joined May 2004
That is a really sick bipe Rob. You make flying that thing look wayyyyyy toooo easy! Are you going to be cutting any as kits in the future? How about full sized plans?
sturdybird46 is offline Find More Posts by sturdybird46
Old Mar 11, 2010, 08:22 AM
Heart of Dixie
Joined Oct 2009
Thanks for designing a great plane. I hope you will include a full size pdf or Sketchup format file, they are much easier work with when printed full size, knowing ever body does not have "E" size printing, but Quick-print and the UPS store does.. Thanks Jack
Blackcloud is offline Find More Posts by Blackcloud
Old Mar 13, 2010, 09:25 PM
tallflyer's Avatar
Joined Jul 2002
People the video Is on youtube! log into youtube and do a search for sloroll!
I just checked the post from work and I cant do links until I get home
But doing a search for sloroll pull up the video under sloroll movie! Just remember What I told you about Slow!
Old Mar 13, 2010, 09:32 PM
flyvertigo
Orlando FL
Joined Aug 2009
Looks like a sweet flying plane. I may have to build one...now where can I get 5mm foam?
Jim
flyvertigo is offline Find More Posts by flyvertigo
Old Mar 13, 2010, 10:51 PM
tallflyer's Avatar
Joined Jul 2002
5mm EPP
If you cant find 5mm you can build the whole plane out of 6mm and it should work great!
Old Mar 14, 2010, 08:10 AM
tallflyer's Avatar
Joined Jul 2002
Video Grabs
Gotta love shooting with HD you can capture some great video grabs and turn them into cool Pictures.
Old Apr 24, 2010, 05:28 PM
United States, AZ, Eloy
Joined Aug 2008
Tall Flyer,
I just got my EPP foam in and it's all 9mm. Do you see any major (or minor) issues with using all 9mm EPP? I already have the templates made and traced out on the 9mm ready to start cutting. I'm really looking forward to a good slowflyer in flight!
pdown1231 is offline Find More Posts by pdown1231
Old Apr 24, 2010, 05:42 PM
tallflyer's Avatar
Joined Jul 2002
pddown1231 if you use all 9mm the wings are going to add a bunch of weight
thats why i went with 5mm as the weight was about the same.
Old May 10, 2010, 01:40 PM
Roll Tide!
Joined Oct 2005
What kind of battery are you using and how much time are you getting with that prop? Thanks for the info. I might build one using all 9mm (in spite of extra weight) a blue wonder with a gws 8043 curved prop and 360 to 460 mAh 3S lipos. Thanks!
amigo is offline Find More Posts by amigo
Build Log Superslo28" Build,Tip,Tricks thread! tallflyer Foamies (Scratchbuilt) 2325 May 05, 2013 04:39 AM
Video Slofly28 Superslo tallflyer Electric Plane Talk 2 Nov 15, 2008 10:01 AM
Sold Slofly28" Superslo kit tallflyer Aircraft - Electric - Airplanes (FS/W) 1 Sep 11, 2008 10:33 AM
Video slofly28" super slow tallflyer Electric Plane Talk 2 Apr 27, 2008 08:56 PM
