May 27, 2003, 07:39 PM
Tigard, Oregon USA
Joined May 2003
basket,
glad to hear you got a raptor! i love this plane! anyways, im not an expert on it but i do would like to share some experience i've had with this plane. i'm on my 3rd raptor now and each ones just gets better.
my first raptor, i just left everything stock except for the motor. i was just using the mega 16-7-8 on 10 AAU 1100 MaH on an apc 7x5. i'd tried a gunther 5x5 but it took too long to get to speed but it was fast when it got there though. i should've tried with a 6x5 but the LHS didn'nt have any.
my second raptor i put a mega 16-15-3 on 6x5 with 10 cp1300scr's. way too much! didn't have motocalc then. anyways on the stabilator. i left the aluminum torque rod and the plastic bushings alone but decided to beef up the two appendages where the stabilator mechanism sits in. the reason why was that i figure i would want the aluminum tube to bend rather than losing them appendages. i don't know if that is good reasoning but thats what i thought and did. well i crashed this plane cus the low voltage cut off on me too early and i didn't know what to do except just to let it crashed. the front of the plane was gone, the wings were ok, my batteries disintegrated, the vert. stabs were ok, the stabilator was ok, but the aluminum tube was bent and i still have those appendages! all this from about 65 mph at about 70 feet up. i somehow manage to rebuild the plane and was able to fly again, this time was with a wattage ducted fan mounted between the vert. stab.
my third raptor, i just transfered everything from my second plane to the new fuselage and saved all the new parts. i could've just ordered a replacement fuse, but i didn't want to be missing anything. now that i got it built i'll just order a spare fuse.
so, from the experience i've got. i don't see the use of the cf rod in the aluminum tube. it might do more damage than good. if you really want to use it, put it in the wing to beef it up. other than beefing the stabilator appendages, i left the mechanism stock. they seem to work for me so far. my second plane AUW was 25 point plus ounze. i left the linkages stock also.
the way i look at it is that i might crash the plane before it'll disintegrate on me so i will try to have as much fun as i can flying it than worry too much about building it. its foam!
i know there are others that have way more experience than me on it. but i haven't seen there remarks yet so i figure maybe my 2 cents might be worth something to you. have fun with it, its an awome flyer!
sokhena
