Old May 26, 2010, 11:57 AM
flyinguy is offline
Find More Posts by flyinguy
flyinguy's Avatar
California
Joined Apr 2008
Tip
Matt,
I used the sweep tool on my tips. I took the tip airfoil sketch and swept it using the trailing edge as the guide curve and the leading edge as the path I think, or maybe they were flipped, but never the less they came out really nice!
I attached a pic, but it doenst display the tip so well.
Jacob
flyinguy is offline Find More Posts by flyinguy
Old May 27, 2010, 12:39 AM
erazz is offline
Find More Posts by erazz
erazz's Avatar
United States, NJ
Joined Jun 2004
Originally Posted by Psionic001 View Post
Hi Erazz,
just found this thread and read the lot. I can see you've gone through what I did earlier in the year with almost the same steps too.
I used about 6 span stations along the span of one half a wing rather than a root and tip. I also created a 0.5mm thick trailing edge in profili so I didn't have to do the thickening in SW. Profili has some really good tools to modify every aspect of the wing like that.
I really only had one problem and that was to achieve a perfect finish on the tips. I see that you have done the same as I had done and loft to a very small tip profile. I never found a way to finish it off and it remains as a 1mm high (max thickness), and 24mm long chord giving my 1.5 meter wing a little flat tip.
I know it's not that important in the scheme of things, but did you ever find a way of doing a perfect tip finish?
I have another mould splitting question too, but I'll ask that later.
best
Matt
You can't really loft or sweep a shape into a point. Geometrically it's not possible. I know it's not "perfect" but it's possible.
erazz is offline Find More Posts by erazz
Old May 27, 2010, 01:01 AM
Psionic001 is offline
Find More Posts by Psionic001
Psionic001's Avatar
Australia, NSW, Sydney
Joined Apr 2006
Thanks Jacob. What happens to the profile when the sweep gets to the end of the Path (your Leading Edge)? Does it still have height? Does your LE intersect with your TE? Are you able to render a close-up or a screen grab of the loft in action?
Matt
Originally Posted by flyinguy View Post
Matt,
Jacob
Psionic001 is offline Find More Posts by Psionic001
Old May 27, 2010, 12:04 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
I couldn't get a sweep to work for a wing tip like that. I got some awkward geometry. Maybe 2010 is better at this than 2008. I'm using an RG14. I didn't try it with a symmetrical airfoil, but I suspect it might only work that way.
Greg
gkamysz is offline Find More Posts by gkamysz
Old May 27, 2010, 02:19 PM
erazz is offline
erazz's Avatar
United States, NJ
Joined Jun 2004
Greg
2010 is exactly like 2008. Sometimes it just takes some fiddling to do it right.
Don't give up. If you want to send the file to me and I'll try to see what I can do.
Old May 27, 2010, 10:11 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
I spent a bit of time messing with it. I can get a rectangle to sweep, although thickness doesn't scale with chord. I tried the RG15 and 64012 neither one will sweep. Thinking I had a problem with my file, I drew up the tail surface you did exactly and still nothing. I added pierce relations just in case. If I select just one guide curve it will follow the curve, but it refuses to cooperate with both selected.
My file is here. Right click, save as.
Grega
Old May 29, 2010, 01:44 AM
Fabrice67 is offline
Find More Posts by Fabrice67
mcz-model
Fabrice67's Avatar
France, Alsace, Strasbourg
Joined May 2009
Hello,
i'm Fabrice from FRANCE, i have a question for erazz and all people : what is a TE channel and wich is the use?
Thank you.
Fabrice67 is offline Find More Posts by Fabrice67
Old May 29, 2010, 04:12 PM
flyinguy is offline
flyinguy's Avatar
California
Joined Apr 2008
Tip
Matt,
Sorry for the delay. I tried to render it so the tip can be seen. Let me know if you want any other views.
Jacob
Old May 30, 2010, 12:27 AM
erazz is offline
erazz's Avatar
United States, NJ
Joined Jun 2004
Originally Posted by Fabrice67 View Post
Hello,
Thank you.
Hi Fabrice,
The channel is used to allow excess fabric and resin to overflow. Without it it's harder to close the mould. It also helps highlight the TE and makes trimming easier.
Old May 30, 2010, 03:31 AM
mcz-model
Fabrice67's Avatar
Joined May 2009
OK,
Thank's erazz.
Old Jun 21, 2010, 08:44 AM
erazz is offline
erazz's Avatar
United States, NJ
Joined Jun 2004
Not doing a lot of building lately but the CNC is working overtime
Old Jul 28, 2010, 04:47 AM
dazou171 is offline
Find More Posts by dazou171
Joined Jul 2010
I have a question
Originally Posted by roger2525 View Post
I tryed to load a airfoil that way and it comes up invalid file. what am I doing wrong I uploaded the file. I am new to all this and i want to learn this.
Roger
I have a question that what kind of airfoil did you use in your solid file, i found it very good for my project. Is it like NACA[what]?
dazou171 is offline Find More Posts by dazou171
Old Jul 29, 2010, 10:38 AM
flyinguy is offline
flyinguy's Avatar
California
Joined Apr 2008
Cutting!
I finally started cutting my mold! Just a few quick shots to share.
Old Jul 29, 2010, 05:19 PM
Psionic001's Avatar
Joined Apr 2006
Nice,
keep sending through progress images.
Matt
Old Jul 29, 2010, 05:44 PM
flyinguy is offline
flyinguy's Avatar
California
Joined Apr 2008
Thanks! I am going back in 30 min to go add the some locating holes and take a final cut along the trailing edge then hopefully load the other half so it can run all night!
Discussion Please help! Solidworks airfoil design, trouble with wing/airfoil tips! elipsfire CAD/CAM 1 Feb 24, 2010 09:22 AM
Discussion Solidworks airfoils to wing generation??? kcaldwel The Builders Workshop 10 Jan 31, 2010 11:59 PM
Discussion Solidworks wing modeling kostixx007 The Builders Workshop 7 May 14, 2007 08:52 PM
Question Loft elliptical wing in SolidWorks erazz The Builders Workshop 3 Jul 09, 2004 12:14 AM
Converting straight wing mold Mig 27 to swept wing? AMTJIM Electric Ducted Fan Jet Talk 0 Nov 07, 2002 03:25 PM
