Old Oct 02, 2012, 09:13 PM
samc99us is online now
Find More Posts by samc99us
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
This thread is fantastic. One day I'll post some of my how-to's when working with complex parts and things that don't want to loft easily.
samc99us is online now Find More Posts by samc99us
Old Oct 06, 2012, 03:33 AM
kipecoul is offline
Find More Posts by kipecoul
France
Joined Jan 2006
HI,
Very good topic.
Do you know if there is similar tread concerning fuselage design with solidworks?
Best regards
Nicolas
kipecoul is offline Find More Posts by kipecoul
Old Oct 17, 2012, 02:50 AM
ThomasLee is online now
Find More Posts by ThomasLee
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
Thanks for the thread, I'm starting to learn SW as well, very helpful!!
ThomasLee is online now Find More Posts by ThomasLee
Latest blog entry: Vibe Assembly Instructions
Old Oct 17, 2012, 06:28 PM
dlpaul is offline
Find More Posts by dlpaul
not bad for one eye
atlantic canada
Joined Jun 2008
I'm working on a new project and have a few questions about my method for setting the trailing-edge gap.
Instead of using profili, I used the set T.E. gap in XFLR. I did so by dividing the desired T.E. gap by the airfoil chord length, then multiplying by 100 (for ex., .3mm/50mm x 100=.6mm). I then entered the resulting .6mm into the T.E. gap value box and used the hinge line % as the blend distance value. I exported the foil from XFLR as .txt and added the column of zeros in notepad.
Because I work in metric, when I imported the profile to SW, it was 1mm so scaling was easy, as I just multiplied it by the chord length and moved it.
So, my questions are:
1) Is the hinge suitable as the blend distance in XFLR? And,
2) Is this crap? In other words, am I just distorting the foil?
Paul.
dlpaul is offline Find More Posts by dlpaul
Old Nov 02, 2012, 07:35 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
If you are adding TE thickness the airfoil is being distorted. That's where XFLR5 comes in. You can analyze the see how much it's changed. I can't see you doing much about it, however. The airfoil must have a reasonable thickness on the TE at model scale.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Feb 27, 2013, 10:11 AM
jtprouty is offline
Find More Posts by jtprouty
Inherent Tinkerer
Wichita, Kansas, USA
Joined Jul 2003
Anyone know why my drawing sizes are limited to 500mm in SW 2012? I can't extrude a fuselage or wing beyond 500mm due to limitations in the drawing size and can't figure out why.
Thanks!
Jimmy
jtprouty is offline Find More Posts by jtprouty
Old Feb 27, 2013, 07:31 PM
ptxman is online now
Find More Posts by ptxman
Calgary, AB, Canada
Joined Oct 2002
Are you talking about a limitation you are experiencing within the 3D model itself? (like a problem extruding or lofting using a command within the features tab)? Or do you mean difficulties trying to make aterations pertaining to the 'drawing' (SW lingo for the paper hardcopy representation of the model?
A drawing issue may simply be a function of the paper size &/or scale setup or drawing template used. Its just trying to fit the model views based on the X:Y scaling values you define, but that does not affect the 3D model itself. I think you can actually make alterations to model within the drawing & SW is smart in that it updates the model so everything is current. But generally I think you want to make changes to the model & let the drawing come out as a product.
There should be no limit I can think of just increasing the geometry of the underlying sketches or planes or whatever in order to extrude distances as long as the math is valid & nothing funky going on. Did you import as one set of units into a SW template of different units? For example when you dimension a section or chord, does it show proper mm as units or whatever you are working in? And same test in the drawing?
ptxman is online now Find More Posts by ptxman
Old Feb 28, 2013, 12:24 AM
awkward is online now
Find More Posts by awkward
awkward's Avatar
New Zealand, Auckland, Pukekohe
Joined Apr 2011
Is it possible to post a copy of the file so we can go through the settings.
awkward is online now Find More Posts by awkward
Old Feb 28, 2013, 09:29 AM
jtprouty is offline
Inherent Tinkerer
Joined Jul 2003
Here's a drawing that I have the problem with. I think I may have found the problem. I found that the units for the drawing was set to meters, not millimeters. I had changed the units to MM but it evidently doesn't save your preferences in SW2012 like it did in 2008. I saved a new template and hope that will take care of the issue.
Thanks again for your help,
Jimmy
Old Mar 01, 2013, 12:56 PM
SB7 is offline
SB7
Find More Posts by SB7
SB7
I am actually really slow
Brisbane
Joined Jun 2008
How do you guys get solidworks? Im not in school, dont own a business and would like to begin learning it for hobby purposes. Is there a way? Or is out of reach for the everyday person?
Im know my way around Rhino pretty well, but would like to try solidworks.
SB7 is offline Find More Posts by SB7
Old Mar 01, 2013, 02:17 PM
Aurora Builder
Joined Nov 2003
www.google.com
Old Mar 01, 2013, 08:23 PM
SB7 is offline
SB7
SB7
Brisbane
Joined Jun 2008
Thanks Sam, your post was about as informative as a bag of sticks. Thanks.
Anyone with a more usefull response? Already looked at their website. Found no licensing options for 'normal people'
Old Mar 02, 2013, 06:22 AM
Psionic001 is offline
Find More Posts by Psionic001
Psionic001's Avatar
Australia, NSW, Sydney
Joined Apr 2006
Here: http://bit.ly/Yfk8MY
EDIT>>> Just ask someone you might know who's a student, and they could purchase for you.
Psionic001 is offline Find More Posts by Psionic001
Old Mar 02, 2013, 11:07 AM
SB7 is offline
SB7
SB7
Brisbane
Joined Jun 2008
Alright thanks guys
Old Mar 02, 2014, 07:16 AM
GootyS is offline
Find More Posts by GootyS
Joined Mar 2008
Please keep this thread alive also more vids on doing wings in CAD. There is some valuable info here
GootyS is offline Find More Posts by GootyS
Discussion Please help! Solidworks airfoil design, trouble with wing/airfoil tips! elipsfire CAD/CAM 1 Feb 24, 2010 09:22 AM
Discussion Solidworks airfoils to wing generation??? kcaldwel The Builders Workshop 10 Jan 31, 2010 11:59 PM
Discussion Solidworks wing modeling kostixx007 The Builders Workshop 7 May 14, 2007 08:52 PM
Question Loft elliptical wing in SolidWorks erazz The Builders Workshop 3 Jul 09, 2004 12:14 AM
Converting straight wing mold Mig 27 to swept wing? AMTJIM Electric Ducted Fan Jet Talk 0 Nov 07, 2002 03:25 PM
