Old Mar 06, 2010, 10:46 PM
GNieuwoudt is offline
Find More Posts by GNieuwoudt
GNieuwoudt's Avatar
Joined Apr 2003
Budget Setup for Supra
I want to convert my Supra to Electric. I will compete in the limited height launch where the launch is limited to 200m and 30 seconds motor on. Would appreciate any advice on low cost motors, 3S (limited space) and prop sizing which would launch a 2-2.5kg glider in 30 seconds to 200m.
Cheers
Gert
GNieuwoudt is offline Find More Posts by GNieuwoudt
Old Mar 06, 2010, 11:42 PM
EricSoar is offline
Find More Posts by EricSoar
Slope and thermal
Christchurch, New Zealand
Joined Apr 2003
The following is copied from:
http://www.hyperflight.co.uk/products.asp?code=SUPRA-E
Powertrain Suggestions
Hacker A20-8XL geared 4.4:1, 3S 1.5Ah LiPo, 20x13 RF prop (1900 fpm, 45A) - recommended
Hacker A20-6XL geared 4.4:1, 3S 1.5Ah LiPo, 16x9 Aeronaut prop (1700 fpm, 46A)
Mega 16/25/2 geared 4.4:1, 3S 1.6Ah LiPo, 16x10 Aeronaut prop (1900 fpm, 57A)
Mega 16/25/3 geared 4.4:1, 3S 1.5Ah LiPo, 20x13 RF prop on +7 spinner (2000 fpm, 49A)
Mega 16/25/2 geared 6.7:1, 3S 1.6Ah LiPo, 20x13 RF prop (2200 fpm, 56A)
Mega 16/25/3 geared 6.7:1, 4S 1.3Ah LiPo, 23x12 RF prop on +7 spinner (2100 fpm, 42A)
Kontronik Fun 480-33 geared 5.2:1, 3S 2Ah LiPo, 18x12 prop (2700fpm, 95A) - tail weight reqd
EricSoar is offline Find More Posts by EricSoar
Old Mar 07, 2010, 07:34 AM
GNieuwoudt's Avatar
Joined Apr 2003
I was wondering if an outrunner would do the trick, like Suppo or E-flite. Does anybody know how much power is required for a 2-2.5kg model to launch at a respectable (not vertical!) speed.
Cheesrs
Gert
Old Mar 07, 2010, 09:18 AM
Ralph Weaver is offline
Find More Posts by Ralph Weaver
Ralph Weaver's Avatar
Indianapolis, IN USA
Joined Nov 2000
http://www.aircraft-world.com/shopexd.asp?id=7147
http://www.rcgroups.com/forums/showt...light=hyperion
I have an older version of the 3025 in my 3m sailplane and it flys great.
Ralph Weaver is offline Find More Posts by Ralph Weaver
Old Mar 07, 2010, 10:36 AM
GNieuwoudt's Avatar
Joined Apr 2003
Thanks Ralph. This looks promissing, and the price is also affordable!
Cheers
Gert
Old Mar 07, 2010, 01:37 PM
Joined Nov 2000
I'm a big fan of Neu motors etc. when you need the absoslute best, but like most things, you can get 80% of the performance for 30% of the price. I also have a couple Hyperion controllers and they perform well.
Old Mar 08, 2010, 01:56 AM
EricSoar is offline
Slope and thermal
Joined Apr 2003
I normally use outrunners too. However, the Supra fuselage is narrow.
Be careful !!
Old Mar 08, 2010, 04:07 AM
Neil Stainton is offline
Find More Posts by Neil Stainton
Neil Stainton's Avatar
United Kingdom, England, Stratford-upon-Avon
Joined Feb 2001
These two ARE outrunners. I don't think any DD outruner will fit (and give you the 8m/s climb rate), but these geared outrunners fit well, give excellent performance, and aren't too expensive.
I will probably use a geared A20-6XL on my next Supra-e. BTW my first Supra-e was also a modified glider. Cutting the glider fin and pod and using a stock electric nosecone makes this an easy modification.
Neil.
Cheesrs
Gert
Neil Stainton is offline Find More Posts by Neil Stainton
Old Mar 08, 2010, 04:09 AM
Joined Feb 2001
Thanks for attributing Hyperflight Eric.
Neil.
Old Mar 08, 2010, 06:53 AM
Joined Nov 2000
When using the Hyperion outrunner in my Topaz, I had to run the wires externally, but the new mounting method that Hyperion has for sailplanes might fix that.
Help! Supra setup dumb question and help with EVO setup tony w Thermal 32 Sep 22, 2009 11:14 AM
Discussion Budget setup for LT-40 on Floats. gotime242 Glow to Electric Conversions 7 May 24, 2008 08:40 PM
Discussion Budget warbird setup ipjodan GWS (Grand Wing Servo) 2 Feb 24, 2007 03:40 PM
AP setup from stock slowstick - budget? Hank_Scorpio Aerial Photography 15 Mar 27, 2003 01:23 AM
My low budget 120 Deg Eco8 setup All__talk Electric Heli Talk 2 Dec 12, 2002 01:09 AM
