Old May 06, 2010, 01:16 PM
Huck1199 is offline
Find More Posts by Huck1199
Joined Feb 2009
KRProton
Here are the pics of the guide tubes inside and the bend needed outside the fuse to reach the elevator horns.
[IMG]c:\outsideevader.jpg[/IMG]
[IMG]c:\insideevader.jpg[/IMG]
Huck1199 is offline Find More Posts by Huck1199
Old May 06, 2010, 01:21 PM
Huck1199 is offline
Joined Feb 2009
Reply to KRProton
This time the pics are loaded
Old May 06, 2010, 02:27 PM
Evan D is offline
Find More Posts by Evan D
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
Paul, where did you read or hear this? How long have you been using the internal BEC on 4S?
I have a Ph45 I can use, but from what I know none of the CC Phoenix intenal BECs can be used on 4S.
Evan D is offline Find More Posts by Evan D
Old May 06, 2010, 02:37 PM
Paul-RC is offline
Find More Posts by Paul-RC
Let me Fly please :^)
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Well I havn't been using any external BEC since I use the CC35A
Just look at the specs again and it does say LiPo cells NO Bec 5s max
LiPo Cells with Bec 3s max
Paul-RC is offline Find More Posts by Paul-RC
Old May 06, 2010, 02:40 PM
Evan D is offline
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
How long have you been using it on 4S? Just in the Evader? Maybe OK since ther's only 2 servos....
Old May 06, 2010, 02:43 PM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Only in the Evader, and yes maybe because of only 2 servos but they dont mention that restriction just that without BEC 5s max
Old May 06, 2010, 02:52 PM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Now I just went in the manual and it does mention in the Phoenix BEC APP Chart that if we use more then 3s Lipo not to use the internal BEC
This is confusing now
So if I have no problem I guess its because of the 2 servos or low amp draw maybe.
Old May 06, 2010, 03:03 PM
Evan D is offline
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
That's what I'm thinking too. How many flight have you made with it?
Old May 06, 2010, 03:07 PM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
With the 4s only 1 so far since it wasn't my batt.
Again went to a castle link and it does mention Lipo Cells NO BEC 4S max
Specs
Part # PHX-35
Volts w/BEC 12.6 max
Volts NO BEC 19.2 max
Lipo Cells w/BEC 3S max
NiCad or NiMh Cells w/BEC 12 max
NiCad or NiMh Cells NO BEC 16 max
Continuous 35 amps
Switching Rate Programmable
(11, 22, or 41 khz)
Resistance 0.0045 ohms
Brake Yes
Reversible Yes - change any two wires
Low Voltage
Cut-off Programmable
Size 0.95 x 1.72 x 0.4"
Weight
(w/wires) 0.9 oz (24.5g)
Connector Type Universal
Old May 06, 2010, 07:19 PM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
I will get a CC BEC 6s to use with my 4s, I will feel safer even if it seems to be ok
Old May 06, 2010, 08:34 PM
Evan D is offline
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
Good idea Paul.
Old May 06, 2010, 08:38 PM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Yes, I really did read it wrong, I'm getting too old
Thanks for bringing this up .
Old May 06, 2010, 09:24 PM
KRProton is online now
Find More Posts by KRProton
Tim Lampe; Hobbico R&D
KRProton's Avatar
Champaign, IL
Joined Dec 2009
Paul, I like your Evader. My wife likes the mapleaf as she has Canadian citizenry. Nice job on the stand too!
KRProton is online now Find More Posts by KRProton
Old May 06, 2010, 09:28 PM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Thanks, I wanted to do it a bit different since we will be 3 at my club with Evaders
Old May 07, 2010, 07:29 AM
ex-racr is online now
Find More Posts by ex-racr
AKA Terry Till
ex-racr's Avatar
Alexandria, VA
Joined Apr 2002
Looks like the guide tubes were installed crooked, instead of a straight shot. I suggest you try to pull them out and re-glue them. If you think pulling them out will damage the fuse, then cut them off, drill out the tube at the fuse attachment point and install new guide tubes.
It's a relatively easy fix-even though you shouldn't have had to.
Do it and you'll be flying in no time.
My .02
Terry
ex-racr is online now Find More Posts by ex-racr
Found Trainer 60 KIT by Great Planes wfortney99 Aircraft - Fuel - Airplanes (FS/W) 5 Feb 28, 2010 07:37 PM
For Sale RIOT - Great Planes ElectriFly TTT1111 Aircraft - Electric - Airplanes (FS/W) 2 Feb 27, 2010 11:05 PM
Sold Great Planes Extra 300 SP in NC Steve H. Aircraft - Fuel - Airplanes (FS/W) 3 Feb 27, 2010 03:03 PM
For Sale re-listed bah7566 Aircraft - Electric - Power Systems (FS/W) 0 Feb 26, 2010 08:48 PM
Found Great Planes Ultimate Bipe 160 CptnBE20 Aircraft - Fuel - Airplanes (FS/W) 0 Feb 26, 2010 02:10 PM
