Espritmodel.com Heli Air
Old Apr 15, 2010, 08:49 AM
Tim Lampe; Hobbico R&D
KRProton's Avatar
Champaign, IL
Joined Dec 2009
...Nope. Can't do it. Can't jamb a collet for a 3.0mm motor shaft onto a 3.2mm motor shaft. All of you probably already knew that. Now I do too.
If you use a motor that has a 3.2mm shaft you'll have to purchase a different spinner (the TruTurn I mentioned previously will work).
I did drill out one of the prop adapters (collets) with a 1/8" drill (3.175mm). I did this with the collet mounted in the spinner back plate with a prop, washer and prop nut. This gives you somewhat of a "handle" to hold onto. Then, the collet fit quite nicely onto a 3.2mm motor shaft. Unfortunately, done by hand there is no way to assure concnetricity.
KRProton is offline Find More Posts by KRProton
Old Apr 15, 2010, 09:10 AM
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
The ARC 28-37-2 I have should get this pylon moving on a 4.1x4.1.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Apr 18, 2010, 03:15 PM
ED3
100% RC ADDICT
ED3's Avatar
USA, CA, Los Angeles
Joined Aug 2007
will definitely get one
ed
ED3 is offline Find More Posts by ED3
Old Apr 22, 2010, 07:13 PM
Fast? I got something 4 ya!
United States, WI, Oak Creek
Joined Oct 2007
$cant beat it for 105.00 bucks!! cant wait till it comes out
XtremeWingRC is offline Find More Posts by XtremeWingRC
Old Apr 24, 2010, 08:42 AM
Mini Raven!!
austinman's Avatar
Joined Jun 2008
I have been thinking for a while if I could use my 2100 mah lipos without weight issues. The electrifly 1500's weigh 121g and my hyperion g3 2100's weigh 163g. A 42g or 1.5oz difference. Is that enough to affect the turn diameter and landings?
Austin
austinman is offline Find More Posts by austinman
Old Apr 24, 2010, 10:06 AM
Joined Oct 2007
Austin
its going to make it float longer on landings. As far as turning, it might make it feel heavy, that is if u have already felt the nature of a 1500 pack. So going to a 2200 will make a difference. You will have to make your loops, banks, turns, a lil bigger my man.
for instance i was running a 1800 pack 3S in my microjet, then i put in a 2200 3S. it definately felt like a pig and alot heavier to fly, not crazy but you could feel it in flight.
Old Apr 24, 2010, 06:05 PM
Mini Raven!!
austinman's Avatar
Joined Jun 2008
Alright, so I think my setup will be:
Ammo 24-33-3500 motor $40
EMP Scimitar 4.5x4.5 prop $2
Silver Series 25 esc $35
2x HS-65hb servos 2x - $46
Hyperion g3 3s 2100mah to start out with and if it feels to heavy i'll buy some 1600's
For the reciever I bet I can find a spektrum ar6100 lying around
Total of electronics: $123 Weight of electronics (with 2100 bat) 282g or 10oz
Total with Rifle: $233
Sounds like a great deal to me considering most other pylon airframes cost that much alone!
Old Apr 24, 2010, 06:26 PM
Joined Oct 2007
Sounds like a great deal austin! Just remember to check things out first. This isn't a european composite gem. Its prolly not built like some of the really expensive missiles on soaringusa.com. So be sure to check things like stress points, and epoxy things you might think are weak in certain areas. Becuase for $105.00 bucks this might be a ship you can only push so far. I think your setup at the top you listed will be the sweet spot.
casey
Old Apr 24, 2010, 07:06 PM
Mini Raven!!
austinman's Avatar
Joined Jun 2008
Thanks for the heads up Casey!
Old Apr 25, 2010, 12:29 AM
You down with EPP?
Houston, Tx
Joined May 2009
My likely setup
ARC 28-37-2
APC 4.1x4.1
Castle Phoenix 45
HS-55's
Old Apr 25, 2010, 08:40 AM
Mini Raven!!
austinman's Avatar
Joined Jun 2008
I see that you are planning to use hs-55's. I was planning to use them too but I was worried about stripping the gears, should I not be worried?
Thanks for all the help guys!
Austin
Old Apr 25, 2010, 09:50 AM
Joined Oct 2007
You should be ok austin. Get the hs-5055 digital servos. Metal gear. when you install the servos put wax paper behind them before u epoxy them in, or make a servo mount, then you can remove the servos if any strippage occurs.
casey
Old Apr 25, 2010, 10:05 AM
You down with EPP?
Houston, Tx
Joined May 2009
casey
I use hs-55's in my other pylon with no problem. In fact everyone I know uses them in their VIP-1's. It depends on the throws and the ease of movement of the control surfaces.
Old Apr 25, 2010, 11:37 AM
Joined Oct 2007
I also used hs-55's in my VIP-1 and i think in my escape pylon plane. Sold it but i think that was in there.
Old Apr 25, 2010, 12:28 PM
Joined Jan 2007
KRProton,
What is the spacing of the motor mount screws 16mm or 19mm? I found a Black Mantis motor but all 4 screw holes are 16mm between the holes.
Thanks.
moreskovich is offline Find More Posts by moreskovich
Sold Lr-1 Pylon Racer New in the box thunderfrog Aircraft - Electric - Airplanes (FS/W) 6 Feb 22, 2010 09:53 PM
Discussion LR-1 Pylon racer New in the box thunderfrog Other Websites 0 Feb 09, 2010 08:26 PM
Sold CSD Twister Pylon racer kit - new in box SPasierb Aircraft - Electric - Airplanes (FS/W) 2 Nov 16, 2009 12:11 AM
FS: Flea sport / pylon racer - RTF kyril Aircraft - Electric - Airplanes (FS/W) 4 Mar 01, 2004 03:29 PM
