Old Jun 26, 2010, 10:39 AM
wastegate is offline
Find More Posts by wastegate
Annoying people since 1970 :)
United Kingdom, England, Taunton
Joined Nov 2005
Yes but I've already built a 125% Slipso from scratch
Thanks for the link though.
wastegate is offline Find More Posts by wastegate
Old Jun 26, 2010, 12:01 PM
MikeRx is offline
Find More Posts by MikeRx
MikeRx's Avatar
Dallas, Texas
Joined Dec 2009
Originally Posted by Ben D Wing View Post
Or spend just 24 on a Slipso 400 short kit and build your own. You'll get the satisfaction of creating something yourself and it will be a lot quicker than the Rifle equiped with a similar power train.
You can buy one here...www.Fine-Flight.com
Im all for creating! however.. The stock Rifle power system pushes the plane to 120 mph. Slipso would not go faster than that on 300w. Rifle is t-tail, moulded, and well airfoiled. A slipso would have to be well crafted to equal the Rifle's dynamics. In real world conditions it is about energy retention through turns and heading on the course, and very few whittled down balsa jobbers are gonna beat a molded t-tail at the 3-600 watt level.
With that said, I want one of those short kits so I can do a light carbon/glass/paint, possible t-tail slip of my own. I may bless it with a neu 1105 having put up with all that sanding dust!
MikeRx is offline Find More Posts by MikeRx
Old Jun 26, 2010, 01:45 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
I received a response from Hobby Services. It loks like they are going to replace my Rifle whenever it becomes available.
I don't anticipate it being equipped with a wing spar "v2". But I will definitely make the wing mods this time around.
Until then, I have a 1700w Mega setup to try out in a stryker, Yippee!
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Jun 27, 2010, 08:03 AM
Straight Up is offline
Find More Posts by Straight Up
Vertical Unlimited
Straight Up's Avatar
Mandurah, Western Australia
Joined Mar 2007
Originally Posted by wastegate View Post
Edit: 136.50 I'd rather spend 13.50 more and get a proper pylon racer like the Sunracer!
136.50 .... how does a $110 plane become 136.50??? That's a really bad exchange rate combined with some really expensive shipping costs. So glad I don't live in the UK!
Straight Up is offline Find More Posts by Straight Up
Old Jun 27, 2010, 08:53 AM
Joined Nov 2005
Yes it's rediculous and pretty much pointless at that price!
How $110 becomes 136.50 which is equivalent to $205 is beyond most sane people!
Old Jun 28, 2010, 06:52 PM
flyingwing12 is offline
Find More Posts by flyingwing12
Master of Flying Wings......
Joined Jul 2008
whats a slipso???
flyingwing12 is offline Find More Posts by flyingwing12
Old Jun 29, 2010, 12:02 AM
Ben D Wing is online now
Find More Posts by Ben D Wing
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
Originally Posted by flyingwing12 View Post
whats a slipso???
A very nice all wooden Speed 400 class pylon racer; Google it.
Ben D Wing is online now Find More Posts by Ben D Wing
Old Jun 29, 2010, 01:59 PM
airplanenut1 is offline
Find More Posts by airplanenut1
buffalo NY
Joined May 2010
alright so im tryin to balance these props but i think the props are not heavy enough for my balance shaft that the prop sits on The shaft is like 3 to 5 times heavier than the prop
i can't see not balancing the props the rpm achieved has gotta be in the high 20's to 30,000 I've never had to balance such a small prop before so if you guys have any tips that would be great since i got my rifle coming tomorrow and hopefully a maiden flight this weekend
airplanenut1 is offline Find More Posts by airplanenut1
Old Jun 30, 2010, 11:17 AM
MikeRx is offline
MikeRx's Avatar
Dallas, Texas
Joined Dec 2009
I think a great planes magnetic balancer is a must. I would not recommend changing the blades (sanding or adding tape), instead add a small bead of med ca to the light side hub inside where the spinner fits..use accelerator when you achieve balance. If it takes a large amount, discard the prop and start over. Double and triple check, changing sides to make sure its correct.
Old Jun 30, 2010, 11:48 AM
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
Agreed on the magnetic balancer, but I've not had any trouble using Scotch Diamond tape for balancing the blades. In the unlikely event of the tape becoming tatty at the edges and starting to lift (the prop usually breaks first!) it's easy enough to peel off and start over.
Old Jun 30, 2010, 05:13 PM
MikeRx is offline
MikeRx's Avatar
Dallas, Texas
Joined Dec 2009
Ive just been worried about the thickness of the tape on these tiny props effecting dynamics.. thats why i have used glue on the non-working inside portion of the prop. I heard the #1 cause for any apc prop to not balance is the center NOT CENTERED. Go to DUB JETT's site and he has a discussion and the conclusion for high rpm racing is that if it falls hard to one blade, throw it away. He also sold an adaptor that helped fix this. Ive been known to "swap" them at the LHS.. or even better, bring the balancer and check on the spot BEFORE buying. (the q40 and q500 props cost more)
Old Jun 30, 2010, 05:17 PM
MikeRx is offline
MikeRx's Avatar
Dallas, Texas
Joined Dec 2009
thats good! but its kinda sad to think they wouldnt update the plane..
Old Jun 30, 2010, 06:09 PM
You down with EPP?
Houston, Tx
Joined May 2009
Well I just received the replacement Rifle airframe in the mail today.
So.... time to beef up that wing.
What size CF strips did you guys use in the wing? Also, what were you guys replacing the wing tab with?
Old Jul 01, 2010, 08:39 AM
volcomsnows2k is online now
Find More Posts by volcomsnows2k
Spicy Torque Roll!
volcomsnows2k's Avatar
USA, CA, Pasadena
Joined Dec 2006
Johnny,
I used Midwest Carbon Fiber Strips, Stock #5742. They are 1.4mm x 4.5mm comes in a bag of 2 strips of 610mm each. The are the rectangular strips. I found this to be the perfect size and with the amount of flight under her with some intense pylon turns, she has help up more than great. The wing tab I replaced with Basswood. Hope this helps! Get er' flying!
Pete
volcomsnows2k is online now Find More Posts by volcomsnows2k
Old Jul 01, 2010, 12:21 PM
You down with EPP?
Houston, Tx
Joined May 2009
Originally Posted by volcomsnows2k View Post
Johnny,
Pete
Thanks Pete.
Sold Lr-1 Pylon Racer New in the box thunderfrog Aircraft - Electric - Airplanes (FS/W) 6 Feb 22, 2010 09:53 PM
Discussion LR-1 Pylon racer New in the box thunderfrog Other Websites 0 Feb 09, 2010 08:26 PM
Sold CSD Twister Pylon racer kit - new in box SPasierb Aircraft - Electric - Airplanes (FS/W) 2 Nov 16, 2009 12:11 AM
FS: Flea sport / pylon racer - RTF kyril Aircraft - Electric - Airplanes (FS/W) 4 Mar 01, 2004 03:29 PM
