Old Jun 25, 2010, 08:22 AM
volcomsnows2k is online now
Find More Posts by volcomsnows2k
Spicy Torque Roll!
volcomsnows2k's Avatar
USA, CA, Pasadena
Joined Dec 2006
Originally Posted by jackosmeister View Post
Gotta have a spar for it too be inadequate Pdawg
Im looking forward to the V2 Rifle, with a better wing and less paint.
Has GP announced a V2 Rifle yet? I was going to pick up a second Rifle, but I think I want to hold off and wait for a few revisions.
volcomsnows2k is online now Find More Posts by volcomsnows2k
Old Jun 26, 2010, 12:59 AM
airplanenut1 is offline
Find More Posts by airplanenut1
buffalo NY
Joined May 2010
i cant wait i just got an email from towers i'm gettin my rifle in next week i've got all the gear for it already i'm gonna try and keep it some what on the light side i am gonna stiffen the wing like said in previous posts and the wing tab fix
3S 1100 mah 45C hyperion lipo
ES55 servos
electrifly 25 amp speed control
24-40-3500Kv ammo motor (left over from GP L-39)
i'm gonna try 4.5 x 4.1 first and i got a couple 4.75 x 4.75 after i get used to the sensation of speed
all on a futaba 10C radio
i know no matter what the landing is gonna be long and shallow and quick but i was wondering if putting 2 servos in the wing and running it with flaperons would help to slow this slippery ship down but i gotta imagine that the roll control might go the crap but i might give it a shot i'll try in stock form first to see if i like it
airplanenut1 is offline Find More Posts by airplanenut1
Old Jun 26, 2010, 01:35 AM
verticalspark is online now
Find More Posts by verticalspark
Aut Viam Inveniam Aut Faciam
verticalspark's Avatar
United States, CO, Colorado Springs
Joined Oct 2008
flaperons always help on any quick plane but I dont know if it would be worth it on this slippery little bird. You most likely wouldnt notice a really big difference until there is so much travel set on the flaperons that controlling it would be rather difficult at those low speeds. This has always been my experience but I havent tried it with a rifle yet.
verticalspark is online now Find More Posts by verticalspark
Old Jun 26, 2010, 01:52 AM
buffalo NY
Joined May 2010
maybe a parachute out of the tail
Old Jun 26, 2010, 01:54 AM
Joined Oct 2008
Sounds like something I will have to try with my slow stick first
Old Jun 26, 2010, 05:33 AM
Ben D Wing is offline
Find More Posts by Ben D Wing
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
Spoilerons (up ailerons) would work, but are only really effective on such a slippery model on a windy day. They'll do nothing for you in calm conditions. If you try this method be sure to mix in about 1-1.5mm of down elevator if your transmitter will allow. This will stop the model from ballooning up when they're deployed during the landing.
Ben D Wing is offline Find More Posts by Ben D Wing
Old Jun 26, 2010, 05:46 AM
wastegate is offline
Find More Posts by wastegate
Annoying people since 1970 :)
United Kingdom, England, Taunton
Joined Nov 2005
Ben, do you happen to know if these are available in the UK as I can't find them listed anywhere?
Thanks.
wastegate is offline Find More Posts by wastegate
Old Jun 26, 2010, 05:51 AM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Ben D Wing you have that backwards. Spoilerons (ailerons up) cause a big dump not ballooning. Flaperons, ailerons down, cause ballooning. Spoilerons Up youll like need up elevator trim, Flaperons down youll need down elevator trim (too keep the plane flying level)
In my experience, spoilerons dont really work on speed 400 sized planes. You just end up landing a fast plane that drops like a stone. (ive pancaked a few into the strip while experimenting )
Flaperons do help, they dont add much in the way of drag but they do lower the stall speed allowing you fly slower, and land slower.
Im not talking big aileron throws, 5mm (MAX!)
jackosmeister is online now Find More Posts by jackosmeister
Old Jun 26, 2010, 06:19 AM
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
Thanks.
Try Sussex Model Centre.
Old Jun 26, 2010, 06:43 AM
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
[QUOTE=jackosmeister;15406407]Ben D Wing you have that backwards. Spoilerons (ailerons up) cause a big dump not ballooning. [\QUOTE]
I currently have 5 gliders and 1 motor glider in my hangar that employ the techique I described and none of them react like you say. There can be differences between models of course, but in my 41 years of active modelling I have not seen what you describe happen.
Old Jun 26, 2010, 07:49 AM
Auckland NZ
Joined Aug 2007
Spoilerons up dumps lift, the further they go up the more lift the dump (until they become drag) , in the same way you reflex a gliders wing to go faster (too a point) How would raising the TE create lift and cause ballooning?
ie. When you mix snap flap into a glider, Too pull a quick turn, TE of the wing goes down as you give up elevator input.
I agree though, there will be some difference between planforms, but ive never flown one that behaves 180 degrees different.
Old Jun 26, 2010, 08:19 AM
old_dude is offline
Find More Posts by old_dude
Groundloop World Champion
old_dude's Avatar
USA, AZ, Glendale
Joined Jan 2002
Or perhaps a tail hook deployed to catch the arresting line you've strung across the field !!
ps: don't use a bungee...most planes don't fly well backwards ... LOL
old_dude is offline Find More Posts by old_dude
Old Jun 26, 2010, 09:23 AM
Joined Nov 2005
Will do. Thanks.
Old Jun 26, 2010, 09:26 AM
Joined Nov 2005
Will do. Thanks.
Edit: 136.50 I'd rather spend 13.50 more and get a proper pylon racer like the Sunracer!
Old Jun 26, 2010, 10:14 AM
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
Or spend just 24 on a Slipso 400 short kit and build your own. You'll get the satisfaction of creating something yourself and it will be a lot quicker than the Rifle equiped with a similar power train.
You can buy one here...www.Fine-Flight.com
Sold Lr-1 Pylon Racer New in the box thunderfrog Aircraft - Electric - Airplanes (FS/W) 6 Feb 22, 2010 09:53 PM
Discussion LR-1 Pylon racer New in the box thunderfrog Other Websites 0 Feb 09, 2010 08:26 PM
Sold CSD Twister Pylon racer kit - new in box SPasierb Aircraft - Electric - Airplanes (FS/W) 2 Nov 16, 2009 12:11 AM
FS: Flea sport / pylon racer - RTF kyril Aircraft - Electric - Airplanes (FS/W) 4 Mar 01, 2004 03:29 PM
