Old Jun 08, 2010, 05:13 PM
Shpook is offline
Find More Posts by Shpook
What's that button do?
Shpook's Avatar
Hollywood, FL
Joined Feb 2008
BTW, I'll be lucky to come out under 20oz AUW. Right now I'm at 21.2oz, but that's with the heavier batteries. This isn't gonna end well...
Shpook is offline Find More Posts by Shpook
Old Jun 09, 2010, 07:34 PM
Shpook is offline
Shpook's Avatar
Hollywood, FL
Joined Feb 2008
I decided on HS-65HB's. I refuse to use 45's at these speeds, and the 65's are only a hair bigger than 55's.
Of course, they're much taller than the thickness of the wing, maybe 4-6mm. So I'm gonna have to use a hardwood riser to mount them to.
This causes another major problem. The servo sticks pretty far down into the fuse. Which means I have to push the battery further forward than I wanted. Now I have a severe nose heavy situation.
Let's see how far back I can get the receiver. I really enjoy working on my Magpie or SlowStick much more.
Old Jun 09, 2010, 08:29 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
The 45's worked fine. Carbonite gears and they are the right size.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Jun 10, 2010, 08:36 AM
hugofly is offline
Find More Posts by hugofly
Wallington, New Jersey, USA
Joined Apr 2010
My CG is right on (as per the manual) with the battery in the nose (3 cell 1300mAh 30C), so I don't think you should have any issues with the bigger servo in terms of getting in the way of the battery. Have you checked your CG yet and are you sure you have to have the battery in the area where it would interfere with the servo / push rods?
hugofly is offline Find More Posts by hugofly
Old Jun 10, 2010, 08:53 AM
MikeRx is offline
Find More Posts by MikeRx
MikeRx's Avatar
Dallas, Texas
Joined Dec 2009
Id put money on those 45's geartrain! Ive rebuilt a few 65hbs so I outta know..
Its the torque that I question. At max speed and deflection the 45s have gone soft on ailerons. Also, the elevator does always return to center after moderate deflection. The 65s are probably a better choice in that they have a better center hold to deal with the draggy pushrod hardware and torque for the super-tight ailerons. The 45s work ok on ailerons in normal use and it would be very hard to strip them with an out of place battery or wire. Id say 45s if I can loosen up the controls.
MikeRx is offline Find More Posts by MikeRx
Old Jun 10, 2010, 03:53 PM
Straight Up is online now
Find More Posts by Straight Up
Vertical Unlimited
Straight Up's Avatar
Mandurah, Western Australia
Joined Mar 2007
I picked up a Rifle from the LHS a few weeks ago, then began reading this thread. Egads, the wing strength issue is a concern! However, the Electrifly R&D rep claimed (in an early post) they did high-speed dive tests with aggressive pull-outs and didn't have a problem. I wonder why the kits aren't able to stand-up to similar?
As for the sheared stab screw, why not twist out the remaining shaft using a pair of pliers? I use nylon bolts to hold on my undercarriages (in my other planes), and when these shear due to a hard landing I just twist out the remaining threaded section using pliers and install a new bolt. There seemed to be some threaded shaft still protruding in the pic - enough to grip and twist?
My kit came with 2 x 3mm shaft collets. I attempted to drill one out, but it is no longer concentric. I ordered this replacement spinner, which is also 30mm in diameter and according to the second-top review, can be forced onto a 3.2mm (1/8") shaft:
http://www.hobbycity.com/hobbycity/s...idProduct=4103
I ordered these servos, having used them for 2 seasons in my ExtremeFlight RC Vanquish, with no slop and incredible resolution + centering power:
http://www.hobbycity.com/hobbycity/s...idProduct=6341
Straight Up is online now Find More Posts by Straight Up
Old Jun 10, 2010, 05:08 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Straight up, you'll need to order another spinner, I bought one of those a couple of weeks ago, they are made out of shiny cheese not metal. I stripped mine by looking at it funny, and they dont really fit speed 400 props without modification.
A friend of mine is happy with these, near MPJet quality is the word.
http://www.hobbycity.com/hobbycity/s...idProduct=9073
Ive ordered some but my package has been awol for 3 weeks during this Lipo fiasco.
I agree with ya on those servos, they are very good, little bit noisy, I have 16 of them scattered through the fleet and havent had one dud.
jackosmeister is online now Find More Posts by jackosmeister
Old Jun 10, 2010, 09:26 PM
Shpook is offline
Shpook's Avatar
Hollywood, FL
Joined Feb 2008
I checked CG with my 1800mAh batteries, and they had to be pushed pretty far aft. I've got some 1300mAh on the way, but I don't feel I'll be able to get them far enough forward. I think I'll make up a fake pack the same weight, and see where everything sits.
The torque was the main thing I was worried about. I got the ailerons as loose as possible, but they're still tight. I wanted to make sure I didn't overload the servos at speed, which is why I went with 65HB's.
On mine, the bolt sheared off pretty low. I tried using an EZ-Out, but didn't have one small enough. I ended up drilling 2 1/32" holes on either side and using some precision needle nose pliers to work it out slowly. What a pain in the arse. I used 3mm x 14mm countersunk screws instead.
The collet included in the hardware bag fit a 3.2mm shaft for me, albeit a bit tight, it was much looser than the one on the spinner.
Old Jun 11, 2010, 01:52 AM
DrZiplok is offline
Find More Posts by DrZiplok
USA, CA, San Francisco
Joined Feb 2004
The HS45s have far more torque than you'll need for the tiny control surfaces and minimal deflection you'll use at any sort of speed on the Rifle.
= Mike
DrZiplok is offline Find More Posts by DrZiplok
Old Jun 11, 2010, 04:45 PM
Shpook is offline
Shpook's Avatar
Hollywood, FL
Joined Feb 2008
= Mike
I'd agree with you, if the control surfaces weren't so friggin tight.
Old Jun 11, 2010, 08:52 PM
_HypnoToad_ is offline
Find More Posts by _HypnoToad_
_HypnoToad_'s Avatar
Joined Jul 2007
I just received my wing from GP,problem is that the creases in this wing are much worse than the one I sent in.They run the entire chord of the wing.
Tim
_HypnoToad_ is offline Find More Posts by _HypnoToad_
Old Jun 11, 2010, 10:07 PM
JohnM is offline
Find More Posts by JohnM
Lifetime Member
JohnM's Avatar
Providence, RI, USA
Joined Dec 1996
I still can't understand why GP didn't put a carbon tube in the wing. It would have prevented all of these wing folding issues.
John
JohnM is offline Find More Posts by JohnM
Old Jun 11, 2010, 10:15 PM
verticalspark is offline
Find More Posts by verticalspark
Aut Viam Inveniam Aut Faciam
verticalspark's Avatar
United States, CO, Colorado Springs
Joined Oct 2008
that sucks hypnotoad, The more I read about the rifle the less likely I am to buy it. That being said I still want it
verticalspark is offline Find More Posts by verticalspark
Old Jun 11, 2010, 10:20 PM
HugoCraft is offline
Find More Posts by HugoCraft
Aerobatic Fanatic
HugoCraft's Avatar
United States, KY, Louisville
Joined Sep 2007
I feel the exact same. I still feel the need for speed but now looking at the e-flite pogo.
HugoCraft is offline Find More Posts by HugoCraft
Old Jun 11, 2010, 10:26 PM
Joined Oct 2008
that is a cool looking plane, i just love the look of a clean underside with no landing gear.
Sold Lr-1 Pylon Racer New in the box thunderfrog Aircraft - Electric - Airplanes (FS/W) 6 Feb 22, 2010 09:53 PM
Discussion LR-1 Pylon racer New in the box thunderfrog Other Websites 0 Feb 09, 2010 08:26 PM
Sold CSD Twister Pylon racer kit - new in box SPasierb Aircraft - Electric - Airplanes (FS/W) 2 Nov 16, 2009 12:11 AM
FS: Flea sport / pylon racer - RTF kyril Aircraft - Electric - Airplanes (FS/W) 4 Mar 01, 2004 03:29 PM
