Old May 30, 2010, 10:11 AM
volcomsnows2k is offline
Find More Posts by volcomsnows2k
Spicy Torque Roll!
volcomsnows2k's Avatar
USA, CA, Pasadena
Joined Dec 2006
Originally Posted by Zero3803 View Post
Began the mods on my airframe tonight. I used a dremel to slice 2 slots in the underside of the wing. I then inserted a 3mm x 1mm carbon strip in each slot and glued them in with 30 minute epoxy. The strips were placed in upright which in that orientation are extremely rigid. I also 'glassed' the front wing tab with carbon fiber strands and epoxy (not pictured). The strips are flush with the wing, and honestly don't look bad when placed on the fuselage and viewed from the bottom.
edit: Not sure why the top slot looks jagged in the picture, but it is actually quite straight. I blame the terrible cell phone camera.
Thanks for sharing the mod. Looks excellent! Most definitely will help with the strength. I just wish I had the time to mod my wing. I'm more than sure your Rifle will hold up wayyyyyy better than most of ours. Happy Memorial Day!
Happy Flying,
Pete
volcomsnows2k is offline Find More Posts by volcomsnows2k
Old May 30, 2010, 11:21 AM
G-Forse is offline
Find More Posts by G-Forse
Denver, CO
Joined Nov 2007
--Mounted vertically, that is a very stiff mod. I use that style carbon frequently. Maybe overlap and take a section of carbon past the end of the aileron.
G-Forse is offline Find More Posts by G-Forse
Old May 30, 2010, 11:52 AM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
I've had better results with these strips oriented vertically than simple rods, so with two I think it should be fine. Regardless of these mods, I won't be full speed cranking through turns. I just wanted to try to make the stock bird safer with very easy to do mods.
That should probably do the trick. Good call on the CF strips rather than rods. Small yet effective.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old May 30, 2010, 04:49 PM
MikeRx is offline
Find More Posts by MikeRx
MikeRx's Avatar
Dallas, Texas
Joined Dec 2009
Contrary... I just went to the hobby shop and bend tested various widths of both hollow rod and strip... the strips when bent vertically will CURL under load, therefore pushing its foam mountings in various directions, whereas the 1/8" hollow rod under the same load would bend the same amount, but only in one direction. Thats why the boys here dont use em' in there 140mph foam wing things. Ridged, yes, but its design can lead to early fatigue of its foam mounting if it flexes at all. This can be fixed by doubling up material in the center section. I opt to keep it simple. The method I explained earlier leaves no ridges and concealed with white filler. Test for yourself.
Cabon strips are designed to be attached to a ridged surface or under hard layer... I believe "jackomiester" has the most correct fix in mind using laminate..
MikeRx is offline Find More Posts by MikeRx
Old May 30, 2010, 10:03 PM
G-Forse is offline
Denver, CO
Joined Nov 2007
--I use the carbon strips mounted vertically in foam planes like the Ph3 F16 and the Funjet with speeds up to 140 mph and 30 to 40 oz weight range. It works very well when glued in place and flexes far less than the round rod. Size I usually use is around 1.5mmx4mm I think. I also use 1/8x1/8 inch square carbon rod. Very stiff when glued in place also. Rifle may, however be best served with a different application. Maybe even use 3/4 wide carbon tape ribbon glued to a sanded surface of the bottom of the wing available from Dave Brown Products. Probably good for fusealage reinforcment also.
https://www.dbproducts.com/index2.htm
Old May 30, 2010, 10:45 PM
MikeRx is offline
MikeRx's Avatar
Dallas, Texas
Joined Dec 2009
I have that stuff..it comes on a cardboard roll and is a great idea. I mentioned it in an earlier message as a laminate between glass and foam from factory. That's would fix our problems for sure. I used it pressed between balsa skined foam with no failure with no spar at max g turns at 170 and 3.5 lb. Soaks up glue and presses thin. One could take out 20% of the glass/epoxy and still increase strenth by a great %.
Old May 31, 2010, 10:45 AM
Spicy Torque Roll!
USA, CA, Pasadena
Joined Dec 2006
After seeing Zero3803's mod with the carbon spars, I decided to try it as well. I actually opted to use 1.4mm x 4.5mm carbon strips from Midwest Products. It is a pretty good size in height where it fits perfectly. I think this will for sure add strength. The vertical strength is awesome. I think in longer strips there is a chance of the carbon twisting, however, the strips used on the Rifle's wing are short enough where I don't think it will twist. I don't have a drill press or anything so Mr. Dremel and I went to town on the wing. 15 minute epoxy and denatured alcohol and she's ready. This is my already crashed Rifle. It now has the carbon in the wing and bass wood for a wing tab. I am literally going to yank and bank this thing as hard as I can. We will see how she hold together. Thanks Zero3803!
Happy Memorial Day!
Pete
Old May 31, 2010, 07:30 PM
Zero3803 is offline
Find More Posts by Zero3803
Zero3803's Avatar
Kennesaw, Georgia
Joined Jul 2007
I anticipate slight wing flex, but at the point to which my particular length of cf strip starts to curl significantly, I don't believe the wing would survive. I have the dave brown cf 'tape' which I had considered using on the underside as well similar to the discus launch glider from mountain models.
Zero3803 is offline Find More Posts by Zero3803
Old Jun 01, 2010, 02:31 AM
Ebolavoodoo is offline
Find More Posts by Ebolavoodoo
Ebolavoodoo's Avatar
United States, CA, Pinole
Joined Jan 2007
Hi all,
My friend flew his rifle for the second time yesterday. This thing really hauls the mail. Fastest plane he has next to his blizzard. His other planes are edf (Habu, L-39, F-18).
On his first day of flying, he had to increase his recommended elevator throws. Flew much better second day. Wow this thing lands pretty hot. Broke a carbon prop! Do they make small folding props? Worth looking into? Told him about the few concerns on the wing and firewall. Rarely does go full throttle and when he does it's for just a second or two! It's my turn to take the Rifle plunge! Great looking and flying plane! Even in the air, it doesn't look or feel too small.
Thanks for the heads up and info.
jerry
Ebolavoodoo is offline Find More Posts by Ebolavoodoo
Old Jun 01, 2010, 02:56 AM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
4.7x4.7 folder - Theyre not cheap, but look awesome
http://www.eflight.ch/shop/USER_ARTI...41517939e4efea
jackosmeister is online now Find More Posts by jackosmeister
Old Jun 01, 2010, 03:48 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
...Or you can buy a MP-Jet folding spinner 30mm + foldingblades at HC 5x5, works very good and will hold up to 500-600 watts easy..
I can take picture later in week so you can see...
sebbe is offline Find More Posts by sebbe
Old Jun 01, 2010, 04:11 AM
Auckland NZ
Joined Aug 2007
I have some of those HC blades. Never been game enough to spin them up look like tooth picks.
Old Jun 01, 2010, 09:00 AM
Spicy Torque Roll!
USA, CA, Pasadena
Joined Dec 2006
Does anyone know where to purchase a spinner/prop adapter for this thing? The stock set up. I went to test yesterday in the morning and the high end vibes were terrible. Any ideas? Thanks!
Pete
Old Jun 01, 2010, 09:14 AM
You down with EPP?
Houston, Tx
Joined May 2009
Pete
I have the stock spinner and will probably never use it.
I would go with a 28mm motor with a larger shaft, then prop accordngly. Better results, less heat. It's summertime!!! Time to burn up motors. I have burnt two in the last two weeks.
Old Jun 01, 2010, 09:18 AM
MikeRx is offline
MikeRx's Avatar
Dallas, Texas
Joined Dec 2009
Pete
I had the same problem untill i realized my prop was unbalanced (even after checking), and another time when the firewall was cracked. Is your shaft bent? The kit somes with a duplicate aluminum prop shaft. Try to reinstall also. Make sure you torque evenly upon application... that soft prop shaft can bend.
Sold Lr-1 Pylon Racer New in the box thunderfrog Aircraft - Electric - Airplanes (FS/W) 6 Feb 22, 2010 09:53 PM
Discussion LR-1 Pylon racer New in the box thunderfrog Other Websites 0 Feb 09, 2010 08:26 PM
Sold CSD Twister Pylon racer kit - new in box SPasierb Aircraft - Electric - Airplanes (FS/W) 2 Nov 16, 2009 12:11 AM
FS: Flea sport / pylon racer - RTF kyril Aircraft - Electric - Airplanes (FS/W) 4 Mar 01, 2004 03:29 PM
