Old May 24, 2010, 07:16 AM
jackosmeister is offline
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
HXT900's and pylon racers dont mix. Sure they may be the equal in terms of speed and torque to an HS55 but they have horrific resolution and shocking QC, its a friggin $3 servo haha!, stick them in foam parkflyers and such. Putting them in a plane doing 120mph is not wise, and personally I wouldnt wanna be within 2km of it in flight.
Dont cheap out on servos, You need zero slop, ultra high resolution, and perfect centering over everything else in a pylon racer.
jackosmeister is offline Find More Posts by jackosmeister
Old May 24, 2010, 03:50 PM
keehopper is offline
Find More Posts by keehopper
keehopper's Avatar
Albuquerque NM
Joined Mar 2009
did some testing with stock motor and a Hyperion 1800 35c 3s battery. with props. 4.1x4.1 fewest amps (20) and highest rpm, 4.75x5.5 most amps (30+) fewest rpm but only 5mph faster. I am 5100 ft. altitude. Anyone do any testing with the stock set up? Nothing came over 125mph on the scale. The 4.75x4.75 came in at 112....kind of surprised!
keehopper is offline Find More Posts by keehopper
Old May 24, 2010, 07:52 PM
keehopper's Avatar
Albuquerque NM
Joined Mar 2009
Where are all of the videos of everyones planes? Anyone actually get one of these things to fly and capture it on video? I did see these on this thread...cool stuff!
Old May 24, 2010, 07:57 PM
Bajora is online now
Find More Posts by Bajora
AA6JB
Bajora's Avatar
Joined Sep 2004
I tried but the cameraman blinked and missed it.
Bajora is online now Find More Posts by Bajora
topher is offline
Find More Posts by topher
denver colorado
Joined Jan 2004
Check out page 27. There,s a video of a hopped up one (arc motor) and a link to my video of a bone stocker
topher is offline Find More Posts by topher
Old May 25, 2010, 04:19 AM
airplanenut1 is offline
Find More Posts by airplanenut1
buffalo NY
Joined May 2010
dammit towers move back the date again its now late june
airplanenut1 is offline Find More Posts by airplanenut1
Old May 25, 2010, 07:21 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
They had better gear up for a big shipment if this thread is any indication of how many want it.
GregG is offline Find More Posts by GregG
Old May 25, 2010, 07:53 AM
keehopper's Avatar
Albuquerque NM
Joined Mar 2009
I better not fly maden until I know I can get parts... You don't have to fly these at high speed at first do you? How slow can you fly these just to learn how they react? Is there a better prop to use than the speed prop and get these trimmed out...I can just see me throwing it in the air, hit the gas..... and by - by, see ya! Anyone seen my plane?
Old May 25, 2010, 09:53 AM
MikeRx is offline
Find More Posts by MikeRx
MikeRx's Avatar
Dallas, Texas
Joined Dec 2009
Not to scare you, but this plane is hard to slow down..even at its lowest practical speeds, it appears fast because of its size. With that said, you may want to try a 5x3 or 5x4 prop for possibly more thrust at lower speeds.On the other hand, the rifle tracks very well and offers no surprises. Wind helps slow landings, which as the instructions say, will take a much longer and shallower approach than usual. Use an experienced launcher. Keep the plane in a constant turn with ̃he top of wing facing you as often as possible. You do not need parts..if you destroy one part, the rest will likely need replacing. The biggest danger is the firewall coming out, and the fuse developing cracks and seam splits.. Repairable with the usual glassing methods. Now go fly!
MikeRx is offline Find More Posts by MikeRx
Old May 25, 2010, 10:07 AM
Thekid3418 is offline
Find More Posts by Thekid3418
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
An APC 5.7x3 draws about the same amps as the 4.75x4.75. So you could try that out for "lower" speeds.
Also, it makes a killer noise when it fully unloads in the air
Thekid3418 is offline Find More Posts by Thekid3418
Old May 25, 2010, 11:06 AM
tman52804 is offline
Find More Posts by tman52804
tman52804's Avatar
United States, IA, Eldridge
Joined Aug 2003
So, what does everyone recommend for servos?
tman52804 is offline Find More Posts by tman52804
Old May 25, 2010, 12:17 PM
MikeRx is offline
MikeRx's Avatar
Dallas, Texas
Joined Dec 2009
the ones recommended are good. Im using hitec 45s... they seem to work ok now that ive upgraded my esc. I want to try the dymond d47s
Old May 25, 2010, 12:19 PM
tman52804's Avatar
Joined Aug 2003
Yeah, but the recommended ones are out of stock to late June. My rifle should be here today.
Old May 25, 2010, 12:37 PM
keehopper's Avatar
Albuquerque NM
Joined Mar 2009
I have a 6x4 that I ran up on the plane and drew about 30amps with the stock motor and the Hyperion 1800 battery. May try that and see how it goes! It should give me better lift and maybe not so much speed.....maybe!
Old May 25, 2010, 12:43 PM
johnnyrocco123 is online now
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
I would'nt go any bigger than maybe a 5.25 diameter prop. I would keep tham square. Start with a 4x4 and work up from there. I would imagine that the stock motor on a 4x4 prop would be easily manageable.
johnnyrocco123 is online now Find More Posts by johnnyrocco123
Sold Lr-1 Pylon Racer New in the box thunderfrog Aircraft - Electric - Airplanes (FS/W) 6 Feb 22, 2010 09:53 PM
Discussion LR-1 Pylon racer New in the box thunderfrog Other Websites 0 Feb 09, 2010 08:26 PM
Sold CSD Twister Pylon racer kit - new in box SPasierb Aircraft - Electric - Airplanes (FS/W) 2 Nov 16, 2009 12:11 AM
FS: Flea sport / pylon racer - RTF kyril Aircraft - Electric - Airplanes (FS/W) 4 Mar 01, 2004 03:29 PM
