Old Mar 10, 2011, 07:13 PM
oly_rcer is offline
Find More Posts by oly_rcer
what ya mean i have to land?
DesMoines,Wa
Joined Feb 2008
would a 16/25/3 be any good in the rifle?if so what prop?thx
oly_rcer is offline Find More Posts by oly_rcer
Old Mar 10, 2011, 07:28 PM
KRProton is online now
Find More Posts by KRProton
Tim Lampe; Hobbico R&D
KRProton's Avatar
Champaign, IL
Joined Dec 2009
Originally Posted by gotboostedvr6 View Post
I have one or two 15/2 motors
Must be nice.
KRProton is online now Find More Posts by KRProton
Old Mar 10, 2011, 07:31 PM
KRProton's Avatar
Champaign, IL
Joined Dec 2009
Here's what's been keeping me back from getting much done on my Sunracer...
Let me tell you, metallics are difficult to work with! The neon red is no picknic either. Many light coats of each (like twenty?). One coat of clear.
Old Mar 10, 2011, 09:16 PM
jackosmeister is offline
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Not really. For a pylon racer its kV is too low and its too heavy.You could make it work, but its far from ideal.
Something like a small 6S (like a 1000mah 50C) pack with a 5-6" prop would work. But it'd be heavy and not particularly efficient as the motor isnt "in the zone" and finding batteries that can support the amp draw, and still fit in the rifle would be tricky.
You could set it up as mini hotliner, turning a 8x7+5degree aeronaut folder on 3S which would work, but not as a pylon racer. And dont expect much gliding as the wingloading will be quite high
That looks MINT KRProton
jackosmeister is offline Find More Posts by jackosmeister
Old Mar 10, 2011, 10:44 PM
KRProton's Avatar
Champaign, IL
Joined Dec 2009
Thanks jackosmeister!
Say jackosmeister, I'm already running a 16/15/2 in one of my Rifles from last summer, but if I can't get another one soon for my new Rifle (got one on order from MEGA Cz, but don't know when I'll get it), what do you think would be a comparable motor? What about a Neu 1105/2.5Y @ 3900kV? The MEGA is 4180kV, so the Neu is slightly lower.
I tried a Neu 1105/2Y last summer, but on run up on the bench it pulled 58A, 615W, 34,000rpm so I flew it a few times on 2S, then sold the motor. At the time I thought that was way too much, but my MEGA pulls 60A, 610W, 38,000rpm and I've flown that setup many times. Do you think the 2Y can take it, or would I be better off with the 2.5Y?
Or, what other motor out there will turn a 4.1 x 4.1 around 39,000rpm and withstand the heat?
Do tell.
I don't know if I want to wait two weeks, three weeks, four weeks...for my MEGA.
Thanks!
Tim
Old Mar 10, 2011, 11:12 PM
Thekid3418 is offline
Find More Posts by Thekid3418
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
3s and a 7x9 (likely would have to trim it to something like 6.7x9) would be an interesting solution for that motor. It'd be like a 4-stroke compared to the high RPM/small prop solutions
Kid
Thekid3418 is offline Find More Posts by Thekid3418
Old Mar 10, 2011, 11:14 PM
gotboostedvr6 is offline
Find More Posts by gotboostedvr6
zoom zoom
gotboostedvr6's Avatar
USA, NJ, Mt Laurel
Joined Oct 2007
Tim,
I have a 15/2 i can sell. Its in good shape.. lmk
BTW your far better off running a 4.75x5.5 at a lower rpm then the 4.1 at those rpm.
-Dave
gotboostedvr6 is offline Find More Posts by gotboostedvr6
Old Mar 10, 2011, 11:22 PM
Auckland NZ
Joined Aug 2007
I dont know much about Neu's sorry man, I hear and read good things but have never played with em.
In terms of the fastest speed 400 pylon setup, bearing in mind what will fit...
Im liking the idea of a Mega 16 EDF (15 grams heavier than a 16/15 with a kV of 3370) on 4S, it'd likely make some awesome numbers.
Old Mar 11, 2011, 04:55 AM
biskit is offline
Find More Posts by biskit
United States, AL
Joined Apr 2007
I had a medusa 28-32-4200 that did exactly that on 3s. They're out of business now but can still be found out there. They weigh about 70g. That was on a pack that got pulled down to almost 10v also, so a new quality pack would probably break 40k rpm.
biskit is offline Find More Posts by biskit
Old Mar 11, 2011, 05:13 AM
KRProton's Avatar
Champaign, IL
Joined Dec 2009
Tim,
-Dave
Thanks Dave. I'll PM you about the motor.
You can't put a 4.75 x 5.5 on that 15/2 though. You'd need a motor with a much lower kV, or go 2S, right?
You're recommending the larger prop at lower rpm than the smaller prop at higher rpm because you get more thrust from the larger prop, right?
I gotta say though, I have no problems with the 4.1 x 4.1 at 39,000 during any aspect of the flight. Launches are no problem at all.
Tim
Old Mar 11, 2011, 05:14 AM
KRProton's Avatar
Champaign, IL
Joined Dec 2009
I think that's the "sweat spot," 4,000-ish kV on a quality can that can take the heat.
Thanks for the tip.
KRProton's Avatar
Champaign, IL
Joined Dec 2009
I don't think I want to stuff 4S in there. Worth thinking about, but not inclined to do so at this moment.
Old Mar 11, 2011, 10:38 AM
MikeRx is offline
Find More Posts by MikeRx
MikeRx's Avatar
Dallas, Texas
Joined Dec 2009
Very nice indeed.. I bet it really shines in the sun!
What does your modded/painted version weigh?
MikeRx is offline Find More Posts by MikeRx
Old Mar 11, 2011, 11:29 AM
MikeRx is offline
MikeRx's Avatar
Dallas, Texas
Joined Dec 2009
That purpose built mega combined with 4s, say 1600 45c, could be a more efficient way to spin that 4.1" to near 40k. With two shallow 1600 2s, end to end, one could get optimal cooling from front to rear. Im thinking the my Ice 50 would work nicely with in-air currents under 50a.
This could be a light, efficient option to 160+. Has me thinkin'..
Old Mar 11, 2011, 12:29 PM
oly_rcer is offline
DesMoines,Wa
Joined Feb 2008
okay,happy now,just traced package and it is out for delivery,had to call usps to find it.kinda upset cause the seller didn't ship it for a week after i paid for it but that's okay now,gave me time to finish my other 3 planes,2 strykers and an f-15 twin fan jet.so now my build table is clear and waiting for something to build lol
Sold Lr-1 Pylon Racer New in the box thunderfrog Aircraft - Electric - Airplanes (FS/W) 6 Feb 22, 2010 09:53 PM
Discussion LR-1 Pylon racer New in the box thunderfrog Other Websites 0 Feb 09, 2010 08:26 PM
Sold CSD Twister Pylon racer kit - new in box SPasierb Aircraft - Electric - Airplanes (FS/W) 2 Nov 16, 2009 12:11 AM
FS: Flea sport / pylon racer - RTF kyril Aircraft - Electric - Airplanes (FS/W) 4 Mar 01, 2004 03:29 PM
