Old May 09, 2010, 10:09 PM
DrZiplok is offline
Find More Posts by DrZiplok
USA, CA, San Francisco
Joined Feb 2004
Keep the FreeBird away from your new toy, or the Rifle will catch something nasty. 8)
= Mike
DrZiplok is offline Find More Posts by DrZiplok
Old May 10, 2010, 10:30 AM
super kupfer is online now
Find More Posts by super kupfer
Anything that gives me a High
super kupfer's Avatar
Canada, BC, Richmond
Joined Jan 2010
Would love to see other paint jobs if anybody is up for the task.
super kupfer is online now Find More Posts by super kupfer
Old May 10, 2010, 11:15 AM
keehopper is offline
Find More Posts by keehopper
keehopper's Avatar
Albuquerque NM
Joined Mar 2009
I just purchased the Rifle and this is my first go fast small plane like this. I purchased the HS 45 and have some of the HS 65s.
The HS 65 is working for the Elev. and the HS 45 for the wings
Had to lift the 45's, too deep of a servo. Had to shim the HS 65 due to the size of servos and shape of fuse.
I am using the Himax 20xx 4200 motor, but the shaft is 2mm rather than the 4mm for the spinner. Hard to find something to fit the 2mm shaft of the motor in a collar that fits spinner, but in initial run up with 30 amp control, hyperion 1800 35c and the 4.75x4.75, wow! the heat is high on static test. Ran a little over 30 amps and from what i could tell....short burst around 400watts...or more. I may go to the smaller prop with less amps. 4.1x4.1
I am at high altitude also....5100 ft. What is everyone else finding.
I don't like the heat.....real hot! even with no spinner and added air flow.
keehopper is offline Find More Posts by keehopper
Old May 10, 2010, 12:04 PM
bosco49 is offline
Find More Posts by bosco49
bosco49's Avatar
USA, CA, Shasta Lake
Joined Mar 2005
I might have miss it.....but what the price of this bird?
bosco49 is offline Find More Posts by bosco49
Old May 10, 2010, 12:08 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
$109. Has anyone flown theirs yet? I am still waiting for my servos.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old May 10, 2010, 12:34 PM
DrZiplok is offline
Joined Feb 2004
@keehopper - that motor is bad for direct drive; you will demag it pretty quickly (speaking from experience). Pick another motor around 3000Kv.
= Mike
Old May 10, 2010, 01:58 PM
keehopper's Avatar
Albuquerque NM
Joined Mar 2009
DRziplock,
Thanks, why don't they tell you this? nothing mentions the warning or fact that it is not good for this type of application or needs gearing ...says up to 40k rpm! have you had problems with this motor running on its own without gearing?
thanks
Old May 10, 2010, 02:06 PM
You down with EPP?
Houston, Tx
Joined May 2009
Originally Posted by keehopper View Post
DRziplock,
thanks
The kv is too high. Not enough airflow and you would be pushing that motor with 4.1x4.1 prop.
I'm running a 3750kv motor on a 4.1x4.1. In a pylon I probably won't prop up from there. If I had more airflow I might be able to get a 4.5 prop on it.
Old May 10, 2010, 02:25 PM
mumblety-peg is offline
Find More Posts by mumblety-peg
mumblety-peg's Avatar
USA, CA, Martinez
Joined Feb 2001
keehopper... that 2mm shaft is VERY easy to break. I think I ran it on 2s in a hummer.
mumblety-peg is offline Find More Posts by mumblety-peg
Old May 10, 2010, 02:43 PM
DrZiplok is offline
Joined Feb 2004
@keehopper - I think the Maxxprod site is pretty clear about the 4200's application constraints, and the second page of the manual that comes with the motor (and is linked on their website) contains a graph that shows very clearly that you hit the motor's maximum current (20A) with a 4.5x3 prop at less than 8.5V.
Maxx are considerably better than many other motor vendors in this regard, in that their data tends to be reasonably accurate and their claims modest and consistent.
I have used several of the 2025/4200s in EDF applications. They work well as long as you don't overheat them, which you will surely do with the setup you proposed. As others have noted, the 2mm output shaft is also not well suited to direct drive use.
= Mike
Old May 10, 2010, 04:22 PM
dalehart is offline
Find More Posts by dalehart
dalehart's Avatar
United States, PA, Allentown
Joined Jun 2005
From my experience flying a Sokhol pylon racer on Medusa motors, I found that a 3500 kv motor with a 4.1 x 4.1 prop gives great speed and a 2800 kv motor with a 4.7 x 4.7 prop gives very good speed with a much easier launch because of the increased static thrust from the larger prop. Both setups were flown with 3S 1500 lipos and a Phoenix 25 amp speed control. My favorite of the two motors was actually the 2800 kv because I liked being able to casually throw the plane and know it would climb out without having to accelerate first.
Dale Hart
dalehart is offline Find More Posts by dalehart
Old May 10, 2010, 08:46 PM
keehopper's Avatar
Albuquerque NM
Joined Mar 2009
Thanks guys! I am taking the motor back and getting the one they mention goes with the rifle. Most of the plane is together except the motor and it looks pretty cool!
I have never had a pylon plane. Mostly casual planes. I have a new 25 pulse that I love flying on strong 4s with a 12x10...lot of fun going faaaaaaaaaassssssssssssst!
Old May 10, 2010, 09:17 PM
oragami is offline
Find More Posts by oragami
Joined Sep 2005
RRE models has them for 99.99. Only 2 Left. Picked up mine today.
oragami is offline Find More Posts by oragami
Old May 10, 2010, 09:39 PM
DT56 is offline
Find More Posts by DT56
Joined Aug 2005
Originally Posted by super kupfer View Post
What do you mean REASONABLE USE ,We are going to fly these things and I or WE intend to have the Throttle at full as long and as much as possible ,That's why you guys named it RIFLE.
Perhaps the name "Rifle" refers to the roll rate instead of top speed!
DT56 is offline Find More Posts by DT56
Old May 11, 2010, 12:19 AM
Joined Jan 2010
The video shows/talks all about the speed ability of this bird ,Looks like that's what they are Marketing it for.
Sold Lr-1 Pylon Racer New in the box thunderfrog Aircraft - Electric - Airplanes (FS/W) 6 Feb 22, 2010 09:53 PM
Discussion LR-1 Pylon racer New in the box thunderfrog Other Websites 0 Feb 09, 2010 08:26 PM
Sold CSD Twister Pylon racer kit - new in box SPasierb Aircraft - Electric - Airplanes (FS/W) 2 Nov 16, 2009 12:11 AM
FS: Flea sport / pylon racer - RTF kyril Aircraft - Electric - Airplanes (FS/W) 4 Mar 01, 2004 03:29 PM
