Old Jan 09, 2011, 08:17 AM
Straight Up is offline
Find More Posts by Straight Up
Vertical Unlimited
Straight Up's Avatar
Mandurah, Western Australia
Joined Mar 2007
Originally Posted by hugofly View Post
If you follow the 80% rule, you should use a 35 amp ESC if you're pulling 28 amp static. Just saying.
I agree with your approach. I don't use any formal "rule", except that I ensure the ESC is rated to take more than the maximum possible current, whether that occurs on the ground or in the air. If the person asking the question has a 30A ESC, use it. No sense buying a 25A ESC when it potentially puts you close to the edge, saves negligible weight and incurs unnecessary cost (assuming the 30A ESC).
Straight Up is offline Find More Posts by Straight Up
Old Jan 09, 2011, 10:00 AM
hugofly is offline
Find More Posts by hugofly
Wallington, New Jersey, USA
Joined Apr 2010
The 80% rule says that you should, if you can, load any piece of electronics to a max of 80% of its rating. So if an ESC is rated for 100amp continuous, you should only load it to 80amp static at the most. This is for longevity. Yes, a 100amp rated ESC can probably be loaded to 120amp, 140amp or even more, but the risk gets higher and higher the more you load it. If you load a 100amp to 80amp, you can be 99.9999999% sure that you won't overload the ESC.
That's all. I used to not follow the 80% rule either and never had a problem, but it's just a matter of lowering the risk of an ESC failure and then have an 80mph rifle hit whatever happens to be in it's path while the ESC fails.
The glow engine rule of running it a few clicks richer is because in the air the engine leans out a bit.
I'm not saying that you all have to change your ESC now, but if somebody asks me if a 30amp ESC is fine, then I say yes, if your static full throttle amp draw is not more than 24amp. Safety margin, margin of error, etc., even if you're using a high quality ESC. If you're using a cheap Chinese ESC, it's even more important to leave some head room.
hugofly is offline Find More Posts by hugofly
Old Jan 09, 2011, 12:53 PM
KRProton is offline
Find More Posts by KRProton
Tim Lampe; Hobbico R&D
KRProton's Avatar
Champaign, IL
Joined Dec 2009
That sounds good. I wonder how they came up with 80%? I wonder why you wouldn't go with like a 50% rule or maybe a 75% rule? I guess it comes down to some statistical data in a study someone somewhere must have done where you get into the law of diminishing returns. Something to keep in mind though.
KRProton is offline Find More Posts by KRProton
Old Jan 09, 2011, 02:29 PM
hugofly is offline
Joined Apr 2010
I guess it's a rule of thumb. Just like the 80% rule of LiPos, where you're supposed to discharge it to about 20% (e.g. you should discharge a 1000mAh LiPo down to 200mAh and not lower), that's also a give-or-take kind of rule.
It all comes down to how long you want your equipment to last.
Old Jan 09, 2011, 02:48 PM
robertbrol is offline
Find More Posts by robertbrol
Joined Sep 2008
My Rifle is coming on tusday and I'm planning to use a 4.75 x 4.75 prop, 1800 lipo 25c (3s) battery, ammo 24 33 3180 motor. I have the option to go with an eflite 25 amp (heat sink) ESC 2 years old or the volcano series 30 amps from hobby partz. Eflite weights 32g and the volcano 25g.
I'm trying to save weight also, so thats why I was asking for an advice with the ESC.
robertbrol is offline Find More Posts by robertbrol
Old Jan 09, 2011, 03:10 PM
Driggs is offline
Find More Posts by Driggs
USA, FL,
Joined Dec 2008
has the wing been reinforced on the new rifle?
Driggs is offline Find More Posts by Driggs
Old Jan 09, 2011, 03:17 PM
Vantagepoint is offline
Find More Posts by Vantagepoint
United States, TN, Nashville
Joined Aug 2008
I am just curious, has anyone tried launching their Rifle using the same bungee launch system that comes with the Evader.
Vantagepoint is offline Find More Posts by Vantagepoint
Old Jan 09, 2011, 03:37 PM
strictlyscale is offline
Find More Posts by strictlyscale
Dream Build Fly Scale
strictlyscale's Avatar
Philadelphia, PA
Guys, some time back I picked up an ARC 28-37-2 for a rifle, but they seem like they are forever on backorder. Back in the beginning of 2005 I scratchbuilt a Microjet2 from MAN plans with an enya .09 in it. Flys great. I've been converting over to electric the past year or so and am curious about doing the same with the microjet2.
Do you think it's too much motor for the microjet?
Here's some video and pics of the model.
micro jet (1 min 51 sec)
Hope it's not deemed off topic for this thread...but I was shooting to get a rifle....or something 'spirited'...
strictlyscale is offline Find More Posts by strictlyscale
Old Jan 09, 2011, 04:22 PM
Jocke is offline
Find More Posts by Jocke
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
I maiden my Rifle the other day, considering the battery used and outside temp it had about 700-750watt power.
With a 2150 50C pack, i am up to 850watts, and yes its fast
Pletti Moskito 3
CC ICE 50
5,2x5,2" prop Graupner CAM
Futaba 3114 and 3115 servos.
My friends will be using Mega 16/EDF, we messured one with a good 3s 30C 2200 packs to 74Amps using a 5,2x4,5" prop.
Jocke is offline Find More Posts by Jocke
Old Jan 10, 2011, 05:45 AM
KRProton is offline
KRProton's Avatar
Champaign, IL
Joined Dec 2009
Pletti Moskito 3
CC ICE 50
WOW! And congratulations Jocke. You bested my hottest Rifle setup (610W--MEGA 16/15/2, Hyperion 3S 1800mAh 35C, 4.1 x 4.1) by about 250 Watts! That's incredible. And just a 50A ESC.
How long do you go full-throttle? Do you throttle back at any time during the flight--as in the turnarounds?
How did you reinforce your wing?
I love the colors you used. Very classy. Nice job!
Old Jan 10, 2011, 05:51 AM
KRProton is offline
KRProton's Avatar
Champaign, IL
Joined Dec 2009
Well robertbrol, we just went through a little discussion about your very question. Have you read the previous posts? But now that I read your question a little more carefully I think the answer is obvious--the Volcano is both lighter and higher Amp, so that's the one I'd go with.
We have used the 25A ESC time and again with the same Ammo and prop you are using, but with a 1500mAh battery. As you are using a slightly larger battery I would go with the 30A ESC.
Tim
Old Jan 10, 2011, 06:14 AM
Jocke is offline
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
I have 2 flights now, and i would guess full power has been in a few sec bursts, and will fly like that for a while to see have everything performs. I have used same setup in FunJet, and flight time at WOT is just under 3min. Castle ESC is modifyed some, and current limit disabled. This is the "new" version, so i havent done any extra reinforcements to the wing.
Colours done by a friend who is a car painter.
Old Jan 10, 2011, 06:19 AM
Jocke is offline
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
Some paint jobbs on my friends Rifles.
Old Jan 10, 2011, 08:43 AM
KRProton is offline
KRProton's Avatar
Champaign, IL
Joined Dec 2009
Jocke, I am impressed with your creativity and flying your Rifle at 700W - 850W, but please remember the limit specified in the instructions is 300W. You may get away with this power if using it only in bursts when flying straight-and-level, but if you use too much power in the turns you may apply too much stress to the wings. Please reinforce the wing, or use extreme care when turning.
Old Jan 10, 2011, 08:53 AM
Jocke is offline
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
No problem, im well aware that its designed for 300watts, and i might reinforce the wing in the future. Its not the first plane i overpower
Sold Lr-1 Pylon Racer New in the box thunderfrog Aircraft - Electric - Airplanes (FS/W) 6 Feb 22, 2010 09:53 PM
Discussion LR-1 Pylon racer New in the box thunderfrog Other Websites 0 Feb 09, 2010 08:26 PM
Sold CSD Twister Pylon racer kit - new in box SPasierb Aircraft - Electric - Airplanes (FS/W) 2 Nov 16, 2009 12:11 AM
FS: Flea sport / pylon racer - RTF kyril Aircraft - Electric - Airplanes (FS/W) 4 Mar 01, 2004 03:29 PM
