Old Jan 04, 2011, 07:38 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Anyone need a new Rifle wing, H-Stab, two spinners, wing skids, servo tray......
$50
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Jan 04, 2011, 09:23 PM
gotboostedvr6 is offline
Find More Posts by gotboostedvr6
zoom zoom
gotboostedvr6's Avatar
USA, NJ, Mt Laurel
Joined Oct 2007
How much for the stab?
Its keeping me from maiden 800 watts
gotboostedvr6 is offline Find More Posts by gotboostedvr6
Old Jan 04, 2011, 09:26 PM
You down with EPP?
Houston, Tx
Joined May 2009
How about I just send you some parts with a cracked up hotliner fuse, as long as I get the fuse back?
Old Jan 04, 2011, 10:07 PM
zoom zoom
USA, NJ, Mt Laurel
Joined Oct 2007
Some parts?
Old Jan 04, 2011, 10:10 PM
You down with EPP?
Houston, Tx
Joined May 2009
Originally Posted by gotboostedvr6 View Post
Some parts?
What do you want, I'll send it
Old Jan 04, 2011, 10:14 PM
zoom zoom
USA, NJ, Mt Laurel
Joined Oct 2007
Send what you've got and ill send you back a working fuse A bit stronger this time too
Old Jan 04, 2011, 10:15 PM
You down with EPP?
Houston, Tx
Joined May 2009
Deal.
Old Jan 04, 2011, 11:33 PM
KRProton is offline
Find More Posts by KRProton
Tim Lampe; Hobbico R&D
KRProton's Avatar
Champaign, IL
Joined Dec 2009
You're kidding, right?
If you're not kidding, I KNOW you reinforced the wing with carbon spars, right.
I'd be interested to hear how it goes. I've flown one of mine at 610 Watts.
KRProton is offline Find More Posts by KRProton
Old Jan 05, 2011, 07:46 AM
zoom zoom
USA, NJ, Mt Laurel
Joined Oct 2007
Its taken care of
The single servo design is long gone and i went with 2 thin wing servos
As far as carbon goes: 12" 1.5x6mm, nearly full length .210 tube, 16" 4 oz fiberglass mesh top and bottom.
Old Jan 05, 2011, 02:02 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Only 800W? add another cell already
jackosmeister is online now Find More Posts by jackosmeister
Old Jan 08, 2011, 07:58 PM
robertbrol is offline
Find More Posts by robertbrol
Joined Sep 2008
Can I use a 30 amps ESC for the ammo 24 33 3180 motor?
robertbrol is offline Find More Posts by robertbrol
Old Jan 08, 2011, 09:20 PM
KRProton is offline
KRProton's Avatar
Champaign, IL
Joined Dec 2009
Do you know how many Amps are you pulling? If you're using a 4.75 x 4.75 prop and a 1500 25C battery (3S) you'll be pulling about 28A static and about 20A in flight. I'd use a 25A ESC--that's what we use.
KRProton is offline
KRProton's Avatar
Champaign, IL
Joined Dec 2009
Niiiiiiiice.
Old Jan 09, 2011, 07:46 AM
hugofly is offline
Find More Posts by hugofly
Wallington, New Jersey, USA
Joined Apr 2010
If you follow the 80% rule, you should use a 35 amp ESC if you're pulling 28 amp static. Just saying.
hugofly is offline Find More Posts by hugofly
Old Jan 09, 2011, 07:59 AM
KRProton is offline
KRProton's Avatar
Champaign, IL
Joined Dec 2009
I've never heard of the 80% rule. I understand the concept of being over-cautious just in case (like running a glow engine a click or two on the rich side of maximum rpm), but with all the motors I've run in the Rifle I've found that the actual, in-flight current is about 32% less than the static current.
If, in the case of a "seed 400-size" pylon like the Rifle, the in-flight current drops, I wonder why you would go the other way and increase the ESC capability?
Sold Lr-1 Pylon Racer New in the box thunderfrog Aircraft - Electric - Airplanes (FS/W) 6 Feb 22, 2010 09:53 PM
Discussion LR-1 Pylon racer New in the box thunderfrog Other Websites 0 Feb 09, 2010 08:26 PM
Sold CSD Twister Pylon racer kit - new in box SPasierb Aircraft - Electric - Airplanes (FS/W) 2 Nov 16, 2009 12:11 AM
FS: Flea sport / pylon racer - RTF kyril Aircraft - Electric - Airplanes (FS/W) 4 Mar 01, 2004 03:29 PM
