Old Mar 05, 2010, 03:53 AM
Ruyman is offline
Find More Posts by Ruyman
Tenerife (Spain)
Joined Feb 2007
¿Het Super Sniper 90mm?
Hello Friends!!
I am interested in finding other edf jet, I have several 70mm and 110mm one that I have collecting dust until they know the best landing, but I have concluded that as the model increases the visual effect of decreasing speed!
Then I was thinking about buying one for a 90mm edf with an acceptable size to view it in the air and not on a budget!
I had thought of the HET Super Sniper 90, is an acceptable price and certainly by the profile that has a good engine will become one of the fastest 90mm edf its range.
Who has one or where can I get information to see which engines do you use?
Thank you.
Ruyman is offline Find More Posts by Ruyman
Old Mar 05, 2010, 04:56 AM
Erik v. Schaik is offline
Find More Posts by Erik v. Schaik
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
http://www.rcgroups.com/forums/search.php?f=12
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Old Mar 05, 2010, 06:51 AM
Ruyman is offline
Tenerife (Spain)
Joined Feb 2007
6S4000 or 8s2500??
Thanks Erick!
But the fact that not much is known about the Super Sniper 90. These motors have some interesting results with the Midi Fan Pro that would be that you would!
36-55-1.5W 1850Kv
6s4000mah: 21.41v / 79.94A / 1716W / 34,850rpm / 2.65KG thrust / 1617Kv under load
ARC 3655-2 1400Kv
8s 4000mah: 30.16v / 64.1A / 1933W / 36,960rpm / 3.0kg thrust / 1225Kv under load
ARC3665-1 2080Kv
6s 5000mah: 21.73v / 91A / 1980W / 39,660rpm / 3.6kg thrust / 1825Kv under load
ARC 3675-1 1680Kv 350 grams
6s 4000mah: 22.39v / 70A / 1567W / 34,440 rpm / 2.6kg thrust / 1538kv under load
8s 4000mah: 26.79v / 90.4A / 2424W / 41,640rpm / 4.0kg thrust / 1554Kv under load
But I have to analyze the following, I have batteries 4S 2500 45C/90 Polyquets and 6S 4000 40C Zippyflymax! Connecting the serial Polyquets would take 8S but so long only 2500 amps do not know how many minutes I could take flight, then Zippyflymax are 4000 amps but dercarga not know if that will give the 1900 watts even with the ARC3665 -1 2080Kv!
The ARC3665-1 2080Kv with 6S Zippyflymax or ARC 3675-1 1680Kv with 8S 2500 Polyquest
Old Mar 05, 2010, 09:40 AM
AceMigKiller is online now
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Comprehensive build thread:
http://www.rcgroups.com/forums/showt...t+super+sniper
AceMigKiller is online now Find More Posts by AceMigKiller
Old Mar 05, 2010, 10:07 AM
Joined Dec 2003
Short summarize: >1000W=RIP
Help! Het super sniper battery mounting redrumm101 Electric Ducted Fan Jet Talk 1 Mar 05, 2010 02:37 AM
Wanted 90MM Super Sniper J03yT Aircraft - Electric - Jets (FS/W) 1 Dec 19, 2009 04:22 PM
Sold HET SUPER SNIPER 90mm steve morris Aircraft - Electric - Jets (FS/W) 6 Nov 16, 2009 08:56 PM
Sold HET Super Sniper NEW! craigmel Aircraft - Electric - Jets (FS/W) 6 Aug 26, 2009 08:10 PM
For Sale Het Super Sniper / Het F-16/ Het F-18 steve morris Aircraft - Electric - Jets (FS/W) 17 Jul 18, 2008 08:53 AM
