Old Nov 12, 2012, 06:32 PM
E1Allen is offline
Find More Posts by E1Allen
UH60 Pilot
E1Allen's Avatar
United States, KY, Fort Campbell
Joined Jan 2010
Originally Posted by Lee View Post
The elevons need the laminate to be stiff enough for aerobatics. I have left the E-Tape off the Scythe to save weight but still done the laminate. It is the choice of motor, battery, Esc, and servos that makes the biggest difference.
I did one layer of laminate on my elevons. They seem plenty stiff for a super light wing.
E1Allen is offline Find More Posts by E1Allen
Old Nov 12, 2012, 07:24 PM
t.edwards is offline
Find More Posts by t.edwards
Joined Aug 2005
I have no laminate but did add (glued) a piece of 3.0mm x 0.5mm CF to the elevons trailing edge. The trailing edge happens to be ~3.0mm thick.
t.edwards is offline Find More Posts by t.edwards
Last edited by t.edwards; Nov 12, 2012 at 10:37 PM. Reason: oops, they're elevons on a flying wing not ailerons
Old Nov 12, 2012, 08:47 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
Originally Posted by elCapitan View Post
@ashdec87... You probably did before, but now that you've confirmed good fpv flight on a scythe, would you mind posting your fpv setup? And did you do anything different for motor/exc/batt than recommended for normal flight?
Thx
There's nothing really different as far as the power system, except that I'm running a 3s pack vs a recommended 2s (I think). Prop is a 5x5.5. Only thing I would really suggest is a GOOD quality esc. I have a cheap 15amp hobby king one and I CANT fly with less than 50% throttle because the switching is so noisy that the 72mhz rx cant handle it and the plane goes for a ride.
As for the FPV gear. Any micro camera will work, but I'm using the XM495 by hobbywireless. Its ok, but the resolution is kind of lacking and it doesnt like light changes. But its small and it fits. I also have a 500mw vtx, but I really think a 250mw would be fine, that's just what I had on hand.
Oh a would suggest a wide angle lens. I tried a pan servo, but it kept getting ripped off. Plus the plane rocks a lot in flight and that can get tough to see if the lens is too narrow.
Otherwise I love this little thing. One last thing. I did put another layer of the laminate on the bottom because of all the cutouts I had to make. I found the wing was getting a little soft.
ashdec87 is offline Find More Posts by ashdec87
Old Nov 12, 2012, 09:27 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
Originally Posted by t.edwards View Post
I have no laminate but did add (glued) a piece of 3.0mm x 0.5mm CF to the ailerons trailing edge. The trialing edge happens to be ~3.0mm thick.
Interesting. I'm looking forward to see how much my wing weighs.
Old Nov 13, 2012, 08:56 AM
blunight is offline
Find More Posts by blunight
Chess club geek with wings
blunight's Avatar
United States, FL, Cape Coral
Joined Aug 2008
I test flew my heavy weight Scythe last weekend...it flew GREAT!
It's as fast (but no faster) than my 4s Reaper but it's a lot quicker to turn and roll.
I'm going to try it out in combat against some Assassins and see if it's quickness allows my to out-fly my friends planes - I'll let anyone who is interested know how it turns out....
My build was stock with the exception of an additional wing spar, the gear is as follows:
Motor: Rewound Emax 2812 - 378 watts @ 32a with a Value Hobby 7x6 prop: (with an APC style 7x6 it was 311 watts @ 28a)
Hobbywing 30A esc with timing set to high
Battery: 3s 1300 mAh 40c
Servos: Towerpro 90s MG's
Trent
blunight is offline Find More Posts by blunight
Old Nov 13, 2012, 09:39 AM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
Wow, Scythe with a re-wound 2812, and a full 7x6 prop. Yeah, I bet that zooms.
My setup is the same, but I cut the prop down to 4.5 or 5" (can't remember) and I still feel like it's speedy
elCapitan is offline Find More Posts by elCapitan
Old Nov 13, 2012, 09:49 AM
Tom Eutsler is online now
Find More Posts by Tom Eutsler
Tom Eutsler's Avatar
Asheville,NC
Joined Jun 2002
MINE HAS a go brushless http://www.gobrushless.com/shop/inde...f=MD+1804-2500
with a GWS Prop ,GWS 4.5x4 DD prop with 1300 11,1v Batt
Tom Eutsler is online now Find More Posts by Tom Eutsler
Old Nov 13, 2012, 11:17 AM
Gonzo 1971 is offline
Find More Posts by Gonzo 1971
This is BAT country!
Gonzo 1971's Avatar
United States, MI, Ovid
Joined Nov 2003
What do you think of that motor? I have one on the way for a micro parkjet project. I am going to run it on 3s 450. It only pulls 8 amps! It will end up in a wing next. Depron doesn't last forever-
Gonzo 1971 is offline Find More Posts by Gonzo 1971
Old Nov 13, 2012, 05:55 PM
blunight is offline
blunight's Avatar
Joined Aug 2008
How does it's speed with the cut down prop compare to that of your Assassin?
And have you tried combat with it?
Old Nov 13, 2012, 06:46 PM
flitime is offline
Find More Posts by flitime
Joined Feb 2012
Man this thing rocks. I built the scythe last week and tried it out this weekend with two different motors.
First I put a microjet v3 from grayson hobbies with a 6x4 prop and a 1300 3cell. This motor gave it great thrust and a top speed of 75 mph. I was happy with this motor but i still wanted top end speed.
Then i installed a Don's wicked 2700 kv motor with a 4.1x4.1 prop and 1000 4cell.
This motor was absolutely insane. I was consistently reaching top speeds over 100mph.
I couldnt be more happy with this wing. When I purchased it I never thought i would be reaching 100 mph speeds for under $100. I have been flying an f27q for months and the scythe just blows it out of the water for speed, cost and just plain fun.
flitime is offline Find More Posts by flitime
Old Nov 13, 2012, 07:06 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
Every time I look at one of those motors from micro Dan I keep thinking I need to get one.
Old Nov 13, 2012, 07:28 PM
Gonzo 1971's Avatar
Joined Nov 2003
I thought the same thing. Finally pulled the trigger.
Old Nov 13, 2012, 07:43 PM
flitime is offline
Joined Feb 2012
I used this motor http://www.donsrc.com/cart/index.php...&product_id=12 from Dons RC for $20
Its out of stock now but he has these http://www.donsrc.com/cart/index.php...&product_id=65 which are even faster for $20 also.
Just be sure to run the recommended props or you may burn the motor up.
4.1x4.1 is perfect on 4s
Old Nov 13, 2012, 07:58 PM
Gonzo 1971's Avatar
Joined Nov 2003
The neat thing about the MicroDan is it draws under 8 amps with a 4x4 prop and you can run a little 450 3s pack. Pitch speed of 77mph. That makes for a light setup on a tiny wing! The motor is only 14g.
Old Nov 13, 2012, 08:29 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
Ug, I just see the money rolling down the drain
Discussion RCG Project Mini/Micro Electric Helicopter Silverexpress New Forum Requests 26 May 13, 2010 02:53 AM
Discussion tekin mini rage vs mamba micro pro size imgumby Micro Cars 23 Mar 19, 2010 09:08 AM
Sold 2008 Edition T.O.P Racing Scythe ARP Touring Car FL62 Cars - Cars and Parts (FS/W) 0 Aug 18, 2009 08:08 PM
Video: The Scythe and the Stone Lavawing Slope 27 Nov 15, 2005 11:01 AM
Video: The Scythe and The Stone Lavawing Dynamic Soaring 0 Nov 12, 2005 01:54 AM
