Old Nov 03, 2012, 08:16 AM
E1Allen is offline
Find More Posts by E1Allen
UH60 Pilot
E1Allen's Avatar
United States, KY, Fort Campbell
Joined Jan 2010
If you were pulling 25a on a 2812 rewind, maybe I should grab a 30a esc instead of 25a
E1Allen is offline Find More Posts by E1Allen
Old Nov 03, 2012, 08:22 AM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
That is a lot of power if it is for a Scythe. It will be fun to fly but you may have torque roll the opposite direction of the prop rotation. Once you are up and flying you should be OK but the plane will roll faster one way than the other.
Do a ground test on the motor and let it run for a couple of minutes and see how hot the ESC gets. I usually like an ESC rated 1.5X the peak amps of the motor.
Lee is offline Find More Posts by Lee
Old Nov 03, 2012, 03:19 PM
Whomprat is offline
Find More Posts by Whomprat
Joined Jun 2011
I would definitely run a 30 amp on the rewind. I pull a static 34 amps with a full battery, although It doesn't get super hot when flying. I don't get any torque problems when flying mine, it's very stable and rolls fairly evenly. It's a blast.
Whomprat is offline Find More Posts by Whomprat
Old Nov 05, 2012, 04:31 PM
hdxtac is offline
Find More Posts by hdxtac
United States, AK, Dillingham
Joined Mar 2012
Yeah I was running the rewound 2812 with a 7x6 prop on the Scythe and it ran good. Right now I'm using the emax 2805 2840 kv motor with a 4.75x4.75 prop and it's been working good for me. It's a lot quieter and doesn't have that roll. I use the rewound 2812's on the widomakers and it's a joy with them.
hdxtac is offline Find More Posts by hdxtac
Old Nov 05, 2012, 06:30 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
Just ordered the wings and electronics for a light wing and a fast wing. Now wait three weeks on hobby king...
Old Nov 05, 2012, 11:37 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Scythe Target Practice (3 min 32 sec)
Old Nov 06, 2012, 09:21 AM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
Here is the setup I have so far for the light build.
Motor HK Ap05 3000kv: http://www.hobbyking.com/buddy.asp?c...C-6DEBF4A5DEEB
ESC Turnigy plush 6a: http://www.hobbyking.com/buddy.asp?c...2-1D7357467380
Batts nano tech 2s 300mah: http://www.hobbyking.com/buddy.asp?c...F-690DE55C2527
Servo HXT 500 5g: http://www.hobbyking.com/buddy.asp?c...6-9B8C5EB2C8D6
RX Orange 6ch rx with cover removed: http://www.hobbyking.com/hobbyking/s...dProduct=11965
Props 5030: http://www.hobbyking.com/buddy.asp?c...F-DD228000C166
Connectors 0.8mm: http://www.hobbyking.com/buddy.asp?c...7-7F2B4BDF5E1B
Heat Shrink for 0.8mm connectors: http://www.hobbyking.com/buddy.asp?c...F-093D243DD9AB
Wing and Elevons 36.8g
rx 3.7
motor 5.4
servos 10g for both
esc 6g
prop 3g ish
batt 17g
Total for these is 86g or 2.91 oz. The supposed motor and prop combo is about 3.9g of thrust. I'm sure there will be a little bit of weight for the connectors and stuff but I think I can build this fairly light. Plus I will loose a little bit of weight taking out the foam for the electronics. I'll let you know how the light build goes and what it weighs when complete.
Does anyone have a rough estimate of the servo horns, control cables and a rough estimate to tape the elevons on?
Eric
Old Nov 06, 2012, 10:33 AM
sredlin is offline
Find More Posts by sredlin
My dog ate my airplane
United States, CA, San Diego
Joined Dec 2008
Eric, don't forget weight of glue and tape and laminate for strength. I tried the light build on page 36, post #534, but didn't get the CG without using a much larger battery than I planned for. I ended up at 5.5 oz with similar components, but it flies great at slow speeds and is very durable even with minimal laminate. And the bonus of the 800mah 2s battery instead of the intended 350mah is 20+ min flights with moderate throttle required at the small park I fly in.
sredlin is offline Find More Posts by sredlin
Old Nov 07, 2012, 06:04 AM
blunight is offline
Find More Posts by blunight
Chess club geek with wings
blunight's Avatar
United States, FL, Cape Coral
Joined Aug 2008
I couldn't resist posting a photo of my Scythe build in progress.
It's build heavy to take the extra weight and power of a rewound 2812 and 1300 3s battery - I'm building it with hopes that it will be faster than my Grim Reaper on 4s
I added additional Extreme tape and extra spars in the wing tips; so far it weighs
3.8 oz.
Thanks for another great wing Lee - when completed I'll have 4 of your designs....darn things are as addicting as 3D profile planes!
blunight is offline Find More Posts by blunight
Old Nov 07, 2012, 08:49 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
I built an assassain and I used hot glue and made a little hole right where the cg was. Then I used a little eyehook and hung it from the ceiling. I made a rough layout of where the esc, rx, and batt would go and I would have it balance on the wing. Then I cut all my holes for everything except the battery and I redid the cg with just the battery left then I cut the battery hole and that worked really well.
Old Nov 07, 2012, 09:39 PM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
I think it was the Reaper forum where we talked about the hanging method resulting in a different CG than the holding-up-from-the-bottom method.
It may well be that on a wing as small as the Scythe, the difference is very small to even nothing, but do be aware that at least on the bigger ones, like the Reaper, if you balance it at 10.5" by hanging, it won't be balanced at 10.5" by holding it from the bottom. (and CTH has pretty much said go with holding from the bottom, if you're seeing a difference.)
@E1Allen, without an Assassin easily at my disposal, I'm wondering if you'd mind double checking your suspended CG, then also holding it up from the bottom at the exact same spot to see if it's balanced or not.
elCapitan is offline Find More Posts by elCapitan
Old Nov 07, 2012, 10:17 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
I would love to. A year ago I attached my phone to it to see how fast it would go. It flew away, never to be seen again in the woods somewhere along with my phone. And yes it flew away perfectly level and I just taped the phone on top.
Old Nov 08, 2012, 06:23 AM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
hehehe Nice
Old Nov 08, 2012, 10:05 AM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
hehehe Nice
My wife disagreed
Old Nov 08, 2012, 11:52 AM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
Now that's a creative way to justify getting the new phone you wanted
Discussion RCG Project Mini/Micro Electric Helicopter Silverexpress New Forum Requests 26 May 13, 2010 02:53 AM
Discussion tekin mini rage vs mamba micro pro size imgumby Micro Cars 23 Mar 19, 2010 09:08 AM
Sold 2008 Edition T.O.P Racing Scythe ARP Touring Car FL62 Cars - Cars and Parts (FS/W) 0 Aug 18, 2009 08:08 PM
Video: The Scythe and the Stone Lavawing Slope 27 Nov 15, 2005 11:01 AM
Video: The Scythe and The Stone Lavawing Dynamic Soaring 0 Nov 12, 2005 01:54 AM
