Old Mar 13, 2010, 09:04 PM
Sorry, but they're all toys.
Eric Odle's Avatar
United States, WA, Bellingham
Joined Jun 2009
Parklite vs Laminate
Originally Posted by nalby View Post
OK here it is all complete except for some covering of the servo's (i'll cover after the maiden )
auw w/ 3s 460 is 5.5 oz
2-bluebird 303 (might swap for hxt500 if they can't handle it )
turnigy 1811-2000 w/gws 4540 prop
rhino 3s 460 mah
spektrum ar6110e
I really want to maiden today but it's pouring out and the forcast calls for almost 4 inches of rain this weekend...bummer
Can't wait to hear how it flies! It looks to me like you trimmed the tips to make the 24" wingspan, how much washout did you leave in it?
I just got my Scythes yesterday and measured and plugged the data into the wing calculator. Here is the link to a tip-trim approach resulting in a 24" wingspan:
http://fwcg.3dzone.dk/?wing_span=24&...ow_mac_lines=1
I also weighed the 18" x 49" piece of laminate included, and came up with a covering weight of 81 grams per square meter. Ultracote Parklite claims 36, less than half the weight. I figure that will translate to about a 10g difference on the finished wing. I'm going for light on the first Scythe to try and keep the wing loading around 4 oz/sq.ft if I can.
From what I'm seeing on the Assassin thread, I may still need the laminate on the EPP elevons to stiffen them. Maybe if I keep them short enough it won't need too much stiffening, we'll see!
Eric Odle is offline Find More Posts by Eric Odle
Old Mar 13, 2010, 09:25 PM
just an earth-bound misfit, I
Murman's Avatar
USA, NC, Huntersville
Joined Jul 2008
Originally Posted by scootty83 View Post
...Anybody have any input on this?
there would be no way to land the GR safely within a short enough time span. You would have to keep your eyes on the Reaper (not on the Scythe)in order to bring her in for a controlled landing. Then, once it has landed, your eyes will still not be on the Scythe, they will be on your controller while you change models. You would then have to be able to locate the Scythe in the sky if it hasn't crashed or floated too far away to see and hope you can gain control.
Murman is online now Find More Posts by Murman
Old Mar 14, 2010, 11:37 AM
fred_n's Avatar
Virginia Beach, VA
Joined Aug 2009
motor mount
I like nalby's motor mount, but here are some inovative ideas.
How-to install a motor Mount (3 min 30 sec)
How to Dremel a slot in a Motor Mount (2 min 17 sec)
http://www.dailymotion.com/video/k3aHgpMQZLprNDTPgY
http://www.rcpowers.com/forum/showthread.php?t=2372
fred_n is offline Find More Posts by fred_n
Old Mar 14, 2010, 03:53 PM
Professional Toothpick maker
nalby's Avatar
USA, NY, New Hampton
Joined Jan 2005
Here's a short vid of the maiden, it was way to windy for the little 24"er, 22 mph w/ gusts. I really couldn't get it trimmed out but it looks like it's going to be a fast fun wing. the bluebird servos gave out even before I got to launch it so I switched them out with some hxt-500's and I put a 3s 800 mah just to give it some more weight for the wind, it's real fat at 6.9 oz
Scythe (1 min 7 sec)
nalby is offline Find More Posts by nalby
Old Mar 14, 2010, 05:19 PM
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
http://vimeo.com/10160014
Sure do the first maiden flight in a hurricane!
I expect it will be fast with the 24" span at that weight. Mine range in width from 26"-30".
Lee is offline Find More Posts by Lee
Old Mar 14, 2010, 05:27 PM
nalby's Avatar
Joined Jan 2005
can't wait to see them and check out your setup's
Old Mar 14, 2010, 09:17 PM
fred_n's Avatar
Virginia Beach, VA
Joined Aug 2009
Check out the price of the AR6110e on this site.
http://www.bigskyhobby.com/
Old Mar 14, 2010, 10:16 PM
Eric Odle's Avatar
Joined Jun 2009
Brave of you to maiden in that kind of wind, and with obstacles galore! I was feeling a little skeptical that my Blue Bird 3615 servos would be enough, and seeing your experience with those 303's I think I'll just wait until I have my HXT-500's in hand.
The weight of the EPP material only for a stock-sweeped 24" wing with 2" cutouts at the tips (Assassin-style) and 8" elevons is 27g.
I know Lee doesn't recommend a finless approach but this is still a relatively thick airfoil so I'm going to give it a shot. If it doesn't work I may try some other drag-inducing trick at the tips, or put fins on. Plus I think it looks cool.
I'd put a photo up but my camera crapped out so I'll have to borrow one from my shipmates as I get further along.
Old Mar 14, 2010, 10:43 PM
Eric Odle's Avatar
Joined Jun 2009
That's the cheapest I've ever seen them, and the shipping was cheap also. Two 6110e's on the way! Thanks!
Old Mar 14, 2010, 11:24 PM
Eric Odle's Avatar
Joined Jun 2009
Suggested Thrust Angle
Lee, any suggestions for the thrust angle? I'm leaning towards parallel with the bottom of the foil, because it is conveniently flat. Once I cut the angle in I won't be able to modify it easily so I'm hoping to get it right the first time.
Old Mar 15, 2010, 12:43 AM
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
With a short span and a thin wing you will probably need the fins.
There is another idea I have had. If you cut the angle and put a fin that is only 2" tall only on each angle to get the drag on a thin wing without as much fin. (HUH?) Even I can hardly understand what I said but I think you get the idea.
I'm going to start with the motor on the same angle as the bottom of the airfoil.
Lee
Old Mar 15, 2010, 01:05 AM
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
I think I am going to Velcro the motor on my first plane so i can take it off for sloping.
Old Mar 15, 2010, 03:25 AM
Eric Odle's Avatar
Joined Jun 2009
Lee
I understand you here, more drag may be necessary. I'm guessing that the drag needs to be far enough aft, hence why you need a fairly swept wing for it to work. Have you ever tried a step, or a shoulder, instead of the angle? I suppose it could be as far aft as possible, just in front of the elevon perhaps. It might not look as pretty as a neat angle, though.
That'll be interesting just trying out the different fin/finless arrangements to see which one is acceptably stable for the smallest package. I'm already very encouraged by how well this thing will fold in half due to the flat bottom foil, it should go together into a nice little travel package.
Old Mar 15, 2010, 09:39 AM
fred_n's Avatar
Virginia Beach, VA
Joined Aug 2009
I don't know didilly about wings, but what if you put a short, thin fin on top of the wing toward the tips and not on the tips themselves? Anyone ever tried that?
Old Mar 15, 2010, 11:50 AM
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
To have the smallest fin with the greatest effect it needs to be slightly toed in at the back end of the wing.
I have been looking at trying the mini angle fins on the larger planes like the Titan and Grim Reaper. I will probably cut several designs and put velcro on the fin and the velcro on the angle and try them on the angles to see if they work.
Discussion RCG Project Mini/Micro Electric Helicopter Silverexpress New Forum Requests 26 May 13, 2010 02:53 AM
Discussion tekin mini rage vs mamba micro pro size imgumby Micro Cars 23 Mar 19, 2010 09:08 AM
Sold 2008 Edition T.O.P Racing Scythe ARP Touring Car FL62 Cars - Cars and Parts (FS/W) 0 Aug 18, 2009 08:08 PM
Video: The Scythe and the Stone Lavawing Slope 27 Nov 15, 2005 11:01 AM
Video: The Scythe and The Stone Lavawing Dynamic Soaring 0 Nov 12, 2005 01:54 AM
