Old May 26, 2003, 03:00 AM
Fitz
Guest
n/a Posts
GP Super Skybolt is finally DONE.
Hi All,
I've been working on a Great Planes Super Skybolt for over a year now
and have just finished it up. It was only my 3rd kit, but am pretty happy
with how it turned out. It is just such a great looking plane I guess it
would be hard to make a ugly one! I only hope it will fly as good as it
looks.
If anyone cares to see the progress of how a box of sticks is made to
resemble a plane then feel free to check my website. Comments welcome.
http://home.maine.rr.com/wydah/index.html
-Fitz.
Old May 27, 2003, 03:00 AM
mk
Guest
n/a Posts
Re: GP Super Skybolt is finally DONE.
Good Job! I'm about ready to cover mine.
mk
"Fitz" <mcfitz@killspam.maine.rr.com> wrote in message
news:ktgAa.33687$pA2.6849@twister.nyroc.rr.com...
> Hi All,
> looks.
> -Fitz.
Fubar of The HillPeople
Guest
n/a Posts
Very impressive!
Much prettier than anything Ive been able to do to date without a doubt.
What engine did you use? Gonna give us a flight report or are you gonna just
admire it for a while first? I would!
Dan
KE6ERB
AMA605992
I've heard the screams of the vegetables...
http://fubar1.freeservers.com
> Hi All,
> looks.
> -Fitz.
kevie
Guest
n/a Posts
Very Nice!!!!!!!!! If I had a plane like that I would have to hang it up
and leave it. Best of luck
tomb
Fitz
Guest
n/a Posts
Well I've got a GMS .76 ringed in it currently. I'm not really heavy into
aerobatics and would be happy if this engine would just pull it around the
field. Maybe a loop and a roll or two and I'm happy. I'll post after the
first flight.
Later.
"Fubar of The HillPeople" <Fubar1@SPAMsocal.rr.com> wrote in message
news:0NrAa.3854$u91.181032@twister.socal.rr.com...
> Very impressive!
just
> Dan
> KE6ERB
> AMA605992
> > Hi All,
now
happy
it
> > looks.
to
> > -Fitz.
Guest
n/a Posts
I have a GMS .76 ringed that I powered my Super Stunts 60 with. Great
running engine. The idle is fantastic with excellent transition to full
power. Due to the plane having an abrupt meeting with a tree while inverted
(wish we had that on video!), the engine is going into an Ultra Stick 60. I
expect it to be more than enough power to do everything I want it to. If
your Skybolt flies half as well as it looks, you will have quite a plane
there!
Dan
KE6ERB
AMA605992
news:sgyAa.40786$pA2.26533@twister.nyroc.rr.com...
> first flight.
> Later.
> > Very impressive!
> just
> > Dan
> > KE6ERB
> > AMA605992
> > > Hi All,
> now
> happy
> it
it
> > > looks.
made
> to
welcome.
> > > -Fitz.
Fitz
Guest
n/a Posts
Hi Dan,
Sort of a postmortem question. (Sorry for your loss.) Do you know the
flying weight of your Super Stunts with the GMS .76? Also what size prop
were you running? Fuel? Plug?
I've only had a few tanks running through mine on the bench using
CoolPower 10%, and an A8 plug, with a 12X6 prop. I never had it stall when
running it in, idle is fine and slow, but I do get some hesitation or bog
when transitioning from idle to full throttle. I think I need to lean the
low end screw a bit more, but was wondering what you had for a setup and how
heavy that Stunts 60 was.
-Fitz.
newsWyAa.6803$u91.233496@twister.socal.rr.com...
inverted
I
> there!
> Dan
> KE6ERB
> AMA605992
into
the
the
> > first flight.
> > Later.
> > > Very impressive!
doubt.
gonna
> > just
> > > Dan
> > > KE6ERB
> > > AMA605992
> > > > Hi All,
year
> > now
> > happy
guess
> > it
as
> it
> > > > looks.
> made
> > to
> welcome.
> > > > -Fitz.
mireuste
Guest
n/a Posts
Xref: news.newshosting.com rec.models.rc.air:138379
I really enjoyed the step by step pics. If you are so kind I would like to
make a question, How did you put you black trim over wings and fuse?
Thanks and congratulations
"Fitz" <mcfitz@killspam.maine.rr.com> escribió en el mensaje
> first flight.
> Later.
> > Very impressive!
> just
> > Dan
> > KE6ERB
> > AMA605992
> > > Hi All,
> now
> happy
> it
it
> > > looks.
made
> to
welcome.
> > > -Fitz.
Guest
n/a Posts
I have no idea what the flying weight of the Super Stunts was as I havent
got access to a scale. The plane is designed pretty light with the fuse made
up of struts and not sheeting except in the radio and fuel tank areas. The
81" wing makes it a real floater. I built it using standard gear with 4
servos in the wing. If I recall correctly, I was using a 14X6 Master
Airscrew prop. I usually ran it on 5% nitro with an off the shelf
castor/synthetic blend which is what they recommended. I believe its
Performance Plus. Ran it once on 15% Powermaster when I ran out of the 5%
and all I had at the field was 15%. Tore the fin clear off the plane! That
got pretty exciting in a hurry. Had to replace the wing and fab up a new fin
and rudder. 5% is plenty for this engine although it seems to be a bit
pickier about the weather than the engines I run on 15%. I run all my 2
strokes with OS 8 plugs including the .76. I dont remember if I had to
adjust the low end or not but it would hesitate a little when it was still
fairly new but that went away after I ran about a gallon thru it. Ringed
engines take a bit longer to break in than ABC engines so I would run a few
more tanks thru it before adjusting the low end. If you have high speed
access, I have a couple videos of the Super Stunts on my website:
http://fubar1.freeservers.com/RC/Movies/Movies.html
The shorter one is about 5 megs and the longer one is about 15 megs. The
longer one shows 2 flameouts caused by running too lean. The day started out
cold and drizzly and the engine was running fine then the sun came out and I
had to richen it up a bit. Other than that, its a great running engine and
probably about the most reliable I own.
Was bummed about the crash because the Super Stunts was a blast to fly but
it is being replaced by the Ultra Stick. Going full quad flaps with that!
Dan
KE6ERB
AMA605992
newspAAa.21450$e11.7089@twister.nyroc.rr.com...
> Hi Dan,
the
when
how
> Thanks
> -Fitz.
> inverted
60.
> I
> > there!
> > Dan
> > KE6ERB
> > AMA605992
> into
> the
> the
> > > first flight.
> > > Later.
> > > > Very impressive!
> doubt.
> gonna
> > > just
> > > > Dan
> > > > KE6ERB
> > > > AMA605992
> > > > > Hi All,
> year
> > > now
pretty
> > > happy
> guess
> > > it
> as
> > it
> > > > > looks.
> > made
> > > to
> > welcome.
> > > > > -Fitz.
Old May 28, 2003, 03:01 AM
Fitz
Guest
n/a Posts
Hi, thanks for all the info. I was just trying to figure out how well that
engine will pull a 10lb plane. It sounds as if your Super Stunts was quite
a bit lighter, but I'm still hoping it will at least pull mine up and around
the field.
The movies are great. Especially like the onboard flight video.
Later.
news:dcEAa.6868$u91.293857@twister.socal.rr.com...
havent
made
fin
few
out
I
> Dan
> KE6ERB
> AMA605992
> > Hi Dan,
> the
prop
> when
bog
the
> how
> > Thanks
> > -Fitz.
Great
full
> > inverted
> 60.
> > I
If
plane
> > > there!
> > > Dan
> > > KE6ERB
> > > AMA605992
heavy
> > into
around
> > the
after
> > the
> > > > first flight.
> > > > Later.
> > > > > Very impressive!
> > doubt.
> > gonna
> > > > just
> > > > > Dan
> > > > > KE6ERB
> > > > > AMA605992
> > > > > > Hi All,
a
> > year
> > > > now
> pretty
> > > > happy
> > guess
> > > > it
good
> > as
> > > it
> > > > > > looks.
is
> > > made
> > > > to
> > > welcome.
> > > > > > -Fitz.
Fitz
Guest
n/a Posts
Hi,
Glad you liked the site. I'm by no means an authority on film coverings.
It really is the part I dread the most when it comes to building. The
Skybolt is only my 3rd kit and covering job. I've used both Monokote and
Ultracote and have found that the Ultracote is much more forgiving. My
Skybolt is entirely Ultracote. (Bright Yellow, Black, and their 1"
Black/Yellow checkered.) My method for putting on the black trim is far
from flawless. It looks pretty good, but does contain some bubbling and
wrinkles. I started by misting some Windex cleaner on the spot to be
trimmed, so I can basically slide the trim piece into position. Then I
squeegee as much of the Windex out from under the trim piece as I can and
let it dry for a few minutes10-15. (I understand this works much better
using monokote. In fact people claim this is all they do when using
monokote and it sufficiently activates the glue and bonds the trim down. It
doesn't seem to be the case when using Ultracote. My pieces would start to
curl up if left to dry fully.) So after a squeegee and short wait I would
go over the trim piece with my iron set to a very low temp. (This is the
benefit of Ultracote. The glue seems to activate at a much lower temp.)
This seems to be the key to minimizing the bubbles. I think my iron was at
around 120-130 degrees, but if you hold the iron on a spot of trim for 5-8
seconds and it causes bubbles then your iron is too hot. You need it to
keep a lower temp to just activate the glue but not cause bubbling. I
seemed to do great on flat surfaces such as the fuselage sides and even the
wing tops over the rib bays. I did have some bubbling near the wing tips
for instance since I needed some more heat to shrink the trim to conform to
the tip. There's a few bubbles there, but from a few feet away it still
looks great.
Well I hope this helps, but I'm sure there are others on this group who have
more experience with these coverings who can give you some help.
-Fitz.
"mireuste" <mireuste@hotmail.com> wrote in message
news:3ed30e1a$1@news.vodafone.es...
into
the
the
> > first flight.
> > Later.
> > > Very impressive!
doubt.
gonna
> > just
> > > Dan
> > > KE6ERB
> > > AMA605992
> > > > Hi All,
year
> > now
> > happy
guess
> > it
as
> it
> > > > looks.
> made
> > to
> welcome.
> > > > -Fitz.
mireuste
Guest
n/a Posts
Thanks again.
news:cXVAa.32480$e11.23646@twister.nyroc.rr.com...
> Hi,
coverings.
It
to
at
the
to
> looks great.
have
> -Fitz.
to
> into
> the
> the
> > > first flight.
> > > Later.
> > > > Very impressive!
> doubt.
> gonna
> > > just
> > > > Dan
> > > > KE6ERB
> > > > AMA605992
> > > > > Hi All,
> year
> > > now
pretty
> > > happy
> guess
> > > it
> as
> > it
> > > > > looks.
> > made
> > > to
> > welcome.
> > > > > -Fitz.
Old Jun 03, 2003, 03:01 AM
3Don_this
Guest
n/a Posts
Very nice Fitz- I think it looks better than the one on the box in those
colors it looks a little beefier- And that's a heck of a lot of pictures
on your website... nice job on that too.
I'm sure if I look, I can see it, but what engine do you have on there?
I have one of these kits I need to build some day, and I was gonna put an OS
120 twin on it- maybe a little heavy, but it makes up for it in coolness ;-)
Congrats- Paul
> Hi All,
> looks.
> -Fitz.
Discussion Any convert a GP Super Skybolt to elec? jcm1010 Electric Plane Talk 1 Aug 08, 2006 09:44 PM
NIB GP Super Skybolt kit (FREE SHIPPING) Biper/Piper Aircraft - Fuel - Airplanes (FS/W) 8 Feb 06, 2005 12:44 PM
