Old Mar 03, 2010, 03:19 AM
patricklupo is offline
Find More Posts by patricklupo
Joined Jul 2009
Question
Best plane for FPV while on vacation?
I've got an EasyStar for FPV and am now wrapping up a coax heli for slow and low FPV, but can't decide on a good portable plane for FPV while on vacation. Here's the attributes I'm looking for...what do you guys suggest?
-Cheap (so if it doesn't come back, it's not a huge loss)
-Stable glider or simple controls
-Easy to stuff into a suitcase
-Will support ~70 grams extra weight ($25 board cam, 500mW VTx & LC filter)
-Handles windy locations (such as off a cliff or at the beach)
-Looks close enough to a toy plane so as not to confuse TSA into thinking it's some sort of dangerous object with blades. i.e a folding tricopter
-Main battery is 11.1v to power cheap and plentiful 12v cameras and VTx's
I keep looking at the upcoming $50? HobbyKing fox/merlin clone but wonder if it'll support the weight of the components above and a 3S battery. It's also more of a hotliner and may be too much for my skill level.
patricklupo is offline Find More Posts by patricklupo
Old Mar 03, 2010, 05:38 AM
Capy-Norway is offline
Find More Posts by Capy-Norway
Capy-Norway's Avatar
Norge
Joined Feb 2009
What about an foldable wing?
Capy-Norway is offline Find More Posts by Capy-Norway
Old Mar 03, 2010, 06:02 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Take a Parkzone Stryker and cut the fuselage down the middle. Then embed two interlocking carbon spars in the front and rear of the plane along the cut. This will make a good stable FPV plane that can travel easily.
IBCrazy is offline Find More Posts by IBCrazy
Old Mar 03, 2010, 06:31 AM
jimbob00 is offline
Find More Posts by jimbob00
Joined Aug 2009
i thought about doing something like that but wasnt too sure, did you make it?
how are the interlocking spars done?
thx ^^
jimbob00 is offline Find More Posts by jimbob00
Old Mar 03, 2010, 08:14 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Use a carbon tubes 12" long. One tube fits inside the other. You want a thick wall carbon tube for both.
With the Stryker still in one peice take a soldering iron and heat it up. Drag it across the center of the plane so you melt a groove into the fuselage. You want an 18" groove in the rear and a 12" in the front.
Now slice the plane in half with a hobby knife. Embed the carbon spars into the grooves. There will be 3" sticking out in the rear and 6" in the front on each half. Slide the spars together and then glue them in place with hot glue or Shoe Goo making sure that you only glue one spar in each track. Slide them back apart once dray and finish the gluing.
Now drill two holes down the nose of the plane, one on either side. Drive two spars 6" long through those holes, throught the nose and 3" into the fuselage. This will keep the front from separating. The rear is kept together by the motor mount.
-Alex
Old Mar 03, 2010, 08:23 AM
lilphil26 is offline
Find More Posts by lilphil26
Toronto Canada
A 100meter glider? You load up your easy star, fly the glider to vacation, and back. Sounds simple enough Might not be the cheapest if you crash it, thats the only thing
lilphil26 is offline Find More Posts by lilphil26
Old Mar 03, 2010, 09:28 AM
ssassen is offline
Find More Posts by ssassen
Netherlands, NH, Edam
Joined Jul 2004
Can't really go wrong with a FunJet. If you apply the factory supplied stickers it sure looks like a kid's toy
Cheers,
Sander.
ssassen is offline Find More Posts by ssassen
Reply With Quote  (Disabled)
Old Mar 03, 2010, 11:16 AM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
Any small wing would work too...
ashdec87 is offline Find More Posts by ashdec87
Old Mar 03, 2010, 12:18 PM
Joined Jul 2009
Thanks! I was thinking along the lines of a wing. All the folks at my local park fly them and they're simple, usually cheap and hold up well to crashes. Gotta get one and learn how to fly it now.
Old Mar 07, 2010, 12:01 PM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Look for MPX Xeno, it is foldable by design. But a bad FPV choice
renatoa is offline Find More Posts by renatoa
Old Mar 07, 2010, 12:10 PM
jimbob00 is offline
Joined Aug 2009
my portable fpv gear is my blade msr xD
20x10cm box! lol
Old Mar 08, 2010, 12:33 AM
etman is offline
Find More Posts by etman
Flying with the eagles
etman's Avatar
Eagle's nest
Joined Nov 2008
Tricopter!
Very easy to stuff into a suitcase.
etman is offline Find More Posts by etman
Old Mar 08, 2010, 07:27 AM
tushev is offline
Find More Posts by tushev
tushev's Avatar
USA, NY, New York
Joined Nov 2008
Sander is right, it must look like a toy plane, for no hassle on airports.
tushev is offline Find More Posts by tushev
Old Mar 08, 2010, 05:02 PM
Kmart is offline
Find More Posts by Kmart
Kmart's Avatar
United States, CO, Boulder
Joined Sep 2008
MS Composit Mini Swift. Easy. Hands down. 23 inches of full EPP foam deliciousness.
Throw a super light/ extremely powerful RC system on it (look at the RCGroups.com Review ), and you've got over 3:1 thrust- weight from the start. Add your FPV gear, and you probably only drop to maybe 2.5:1 (plane weighs around 4oz RTF, and Subsonic Planes gear spits out around 12 oz of thrust ).
Get the red one too- red can be a good toy color, but also easy to see.
I'd post a video of mine, but I busted my video TX, and it's currently at the repair man's workshop.
Kmart is offline Find More Posts by Kmart
Old Apr 18, 2010, 03:19 PM
jakerevs is offline
Find More Posts by jakerevs
Joined May 2009
mpx easy glider pro
cant go wrong with a easy glider pro!!!! much easier and slower than an easystar but it isn't that good with wind but, just an idea
jakerevs is offline Find More Posts by jakerevs
Discussion Best FPV camera for UHF system FutureVRPilot FPV Talk 2 Mar 02, 2010 08:56 PM
Question Do you take your FPV setup on vacation? patricklupo FPV Talk 3 Aug 24, 2009 04:00 AM
Yippee! FPV on vacation in Italy dadde FPV Talk 0 Jun 24, 2009 02:45 AM
Question Traveling on a plane for vacation jet-ster Electric Plane Talk 13 Aug 10, 2007 02:34 PM
Discussion Why I didn't fly FPV on my vacation PeteSchug FPV Talk 2 Jul 08, 2007 09:25 AM
