Old Mar 02, 2010, 09:51 PM
Blue Falcon is offline
Find More Posts by Blue Falcon
Chicago
Joined Jul 2008
Build Log
Mosquito "Scratch" Build from Gus Morfis Plans
Hi Guys,
Wanted to share some pics of my Mosquito build in progress. I started a couple months ago, and have snapped some random shots along the way...
This is my first scratch build, and has proven quite a challenge. The plans are from Gus Morfis, and it's a 1/12th scale Mossy, with 54" wingspan. I plan to put twin Thunder Tiger .15's in the plane, which seems like more than enough power.
Anyone with experience with this plane before? I've seen a few Mosquito build logs, but none from these plans. One of the difficulties in this scale is that most of the warbirds are larger scale, so parts, canopy, etc. can be difficult to come by.
Any advice or tips would be great.
Blue Falcon is offline Find More Posts by Blue Falcon
Old Mar 02, 2010, 10:02 PM
Chicago
Joined Jul 2008
First set of pictures
Here are some of the first shots. I decided to start with the wing, since I knew I could do okay on that. I also started on the nacelles, since I dreaded doing them.
This plane is my first attempt at plancking. It's a steep learning curve, but I'm getting better....
Old Mar 02, 2010, 10:15 PM
Chicago
Joined Jul 2008
Wings Part II
Next steps were adding wingtips, and then figuring out how to mount engines.
After a great deal of planning, and with expert help, the engine mounts were designed and built from 1/8" ply and 5/8" square rails.
The engine mounts house the fuel tanks, and the engines are mounted on rail which ultimately is glued to wing spars. Landing gear mounts also transfer forces to spars, so hopefully any hard landings will be handled well.
Old Mar 03, 2010, 12:03 PM
CarreraGTSCS is online now
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
Looks like you've gotten a lot of work done already. Nice work.
CarreraGTSCS is online now Find More Posts by CarreraGTSCS
Old Mar 03, 2010, 05:40 PM
heli_madken is offline
Find More Posts by heli_madken
Liverpool, England
Joined Jan 2005
Looks great got this one bookmarked, keep it coming
heli_madken is offline Find More Posts by heli_madken
Old Mar 03, 2010, 07:46 PM
Chicago
Joined Jul 2008
Nacelle Work
My plan is to be able to remove both top and bottom of nacelles. The front ply ring behind the spinner is split, and attaches to the front of the rail of the engine mount. There are small tabs which hold each half of the ring together, thus holding the nacelle together in front. The top will have a small screw into ply block in top of wing. The aft portion of the nacelle will have tiny screws attaching to rear portion of wing.
I took 1/2" balsa sheets and glued together blocks. Then lots of sanding to shape into something resembling nacelles.
Old Mar 03, 2010, 07:52 PM
Chicago
Joined Jul 2008
More Nacelle Work
After some carving, beginning to take shape...
Lots of time with the sanding block.
Old Mar 07, 2010, 05:14 PM
Chicago
Joined Jul 2008
Fuselage Work
The fuselage of this plane is pretty simple. I used 3/32" plancks, about 1/4" width. I think that the nose block took more time than building the fuselage and the plancking.
Am starting work on the tail, where I want to design detachable surfaces and internal linkages.
Old Mar 11, 2010, 08:03 PM
ska2000 is offline
Find More Posts by ska2000
Mount Juliet, TN
Joined Feb 2008
Good luck Falcon,
Looks like a really cool project. It'll be fun to watch.
Tom
ska2000 is offline Find More Posts by ska2000
Old Mar 11, 2010, 11:07 PM
Chicago
Joined Jul 2008
Thanks Tom!
Will post more pics this weekend. I'm trying to fit wing to fuselage...
Old Mar 16, 2010, 09:08 PM
Chicago
Joined Jul 2008
More Fuselage. Tail assembly
Finally overcame the anxiety and made cut outs for the wings. A pretty good fit! Now starting to look more like an airplane.
For the tail, I wanted to design a tail assembly which can come apart for access to internal linkages as well as repairs (hopefully not necessary).
Old Mar 25, 2010, 04:53 PM
Joined Jan 2004
Progress? Looking good.
Old Mar 26, 2010, 10:53 PM
Chicago
Joined Jul 2008
Thanks Mike.
Progress is slow. Sanding and sanding, and filling gaps. Will post more when I start working on linkages and fit everything together before glassing.
Any color scheme ideas? Suggestions? I like the camo top and night flyer underside, and may go with that scheme.
Old Apr 01, 2010, 08:01 PM
Zor is offline
Zor
Find More Posts by Zor
Zor
Ontario,Canada
Joined Feb 2007
Originally Posted by Blue Falcon View Post
Thanks Mike.
What are you planning to use for "glassing" ? ? ?
Zor is offline Find More Posts by Zor
Reply With Quote  (Disabled)
Old May 09, 2010, 11:47 AM
Joined Jan 2004
Did I ever email you those color profiles? I can't remember if I did or not.
Discussion Gus Morfis Plans phoneguy Parkflyers 0 Mar 01, 2010 09:10 PM
For Sale Gus Morfis plans with McClain wing cores Scratchbuilder Aircraft - Electric - Airplanes (FS/W) 6 Nov 05, 2009 05:52 PM
Sold TurnkeyRC/Gus Morfis 1/12 Mosquito semi-kit trident58 Aircraft - Electric - Airplanes (FS/W) 5 Jun 01, 2009 09:15 AM
Anyone use Gus Morfis plans Scratchbuilder Scale Kit/Scratch Built 1 Apr 02, 2003 12:11 PM
Gus Morfis Plans? Slope Nut Scale Kit/Scratch Built 11 Jul 21, 2001 12:10 AM
