Old Jan 06, 2013, 09:15 PM
harv_d is offline
Find More Posts by harv_d
Canada, BC, Surrey
Joined Apr 2008
I have question for you guys about regulating voltage. The plane im putting together has 8 servos. Im planning on using a castle BEC to regulate the voltage. my question is:
If i use a 3000mah 3s lipo, will that last longer than running a 3000mah 2s?
harv
harv_d is offline Find More Posts by harv_d
Old Jan 06, 2013, 09:49 PM
Lardog is offline
Find More Posts by Lardog
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
Considering some batteries (not hobby lipos) have their capacity indicated at "Watt hours" then it would stand to reason the a higher voltage 3000mAh pack should last longer at a given current rate.
Lardog is offline Find More Posts by Lardog
Old Jan 07, 2013, 06:26 AM
dand2k is offline
Find More Posts by dand2k
United States, WA, Seattle
Joined Mar 2012
If your BEC is a linear mode type, it will draw the same current from both batteries and they will last the same time, but it will dissipate more heat with the higher voltage battery as "waste" because it has to drop more voltage in the regulation process. Linear mode types are not very efficient.
If your BEC is a switching mode type, then it will be more efficient and will make use of the extra voltage and draw less current from the higher voltage battery, and it will last longer. But most inexpensive BECs are linear mode types.
However, if we consider the BEC as a constant load with resistance R, then the current I(2s) = V(2s) / R and I(3s) = V(3s) / R. In this case, the current is greater for the 3s battery, and therefore the 3s battery will not last as long as the 2s battery.
dand2k is offline Find More Posts by dand2k
Old Jan 07, 2013, 10:56 AM
MCSGUY is offline
Find More Posts by MCSGUY
aka JetMan Joe
MCSGUY's Avatar
Joined Feb 2010
harv
Since the CC Bec is a switcher as opposed to a linear and If I were doing the calculations I wouldn't model it as a constant load, I'm with Lardog. I think the 3S would last longer. You could do a test on both types for the same duration and load and see which one takes more mah to recharge. Maybe lock the same robust servo at full load for 60 seconds, or something similar.
MCSGUY is offline Find More Posts by MCSGUY
Old Jan 07, 2013, 12:22 PM
mark_q is online now
Find More Posts by mark_q
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
3S will last longer. It's a power problem, plain and simple.
If you disregard losses and inefficiencies...
At 1C:
A 3S 3000mah battery will provide 3 amps x 11.1 volts for one hour or 33.3 watt/hours.
A 2S 3000mah battery will provide 3 amps x 7.4 volts for one hour or 22.2 watt/hours.
If your electrical system, on average consumes 25 watts, the 3S battery will give you 79.9 minutes of run-time.
On 2S you will get about 53.3 minutes of run-time.
So, the 3S will last 1-1/2 times longer.
mark_q is online now Find More Posts by mark_q
Old Jan 07, 2013, 03:19 PM
cryhavoc38 is offline
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
harv
One thing that the others might be forgetting is that the CC BEC Pro reduces max amp output as the input voltage climbs.
it would be advisable to use no more than a 3s pack for input voltage with those 8 servo's.
Max continuous current varies with the input voltage. The ratings are:
Input Voltage: Max Continuous Output Current
16V 15A
24V 13A
32V 11A
40V 9A
48V 8A
cryhavoc38 is offline Find More Posts by cryhavoc38
Old Jan 07, 2013, 10:39 PM
egaus is offline
Find More Posts by egaus
Quadrophenia
egaus's Avatar
Seattle
Joined Mar 2009
I'm curious about your 2s/3s plane with eight servos.
e
egaus is offline Find More Posts by egaus
Old Jan 07, 2013, 11:07 PM
SupaTim is offline
Find More Posts by SupaTim
Owner/Operator at NorthWest RC
SupaTim's Avatar
United States, WA, Orting
Joined Jan 2010
Don't get too excited, it's still pumpin gas through the business end...
SupaTim is offline Find More Posts by SupaTim
Old Jan 08, 2013, 12:23 AM
cryhavoc38's Avatar
Joined Mar 2007
e
I'm fairly certain he is planning out the electronics power for a gasser
Old Jan 08, 2013, 08:15 AM
harv_d is offline
Canada, BC, Surrey
Joined Apr 2008
Chip Hyde double vision
Old Jan 08, 2013, 09:27 AM
cryhavoc38's Avatar
Joined Mar 2007
Harv, assuming the roads are clear..what day were you thinking of coming down?
Old Jan 08, 2013, 10:27 AM
harv_d is offline
Canada, BC, Surrey
Joined Apr 2008
Yes. I plan on coming down Friday evening. Figured I'll stop by your place first on the way down. Pm me your address.
Old Jan 08, 2013, 11:33 AM
cryhavoc38's Avatar
Joined Mar 2007
done
thanks
Old Jan 08, 2013, 12:15 PM
stevelmaa is online now
Find More Posts by stevelmaa
Renton, Wa.
Joined Feb 2006
Hey guys. I've got a couple large outrunners for sale if anyone is interested, priced cheap to sell
http://www.rcgroups.com/forums/showthread.php?t=1804350
http://www.rcgroups.com/forums/showthread.php?t=1804344
Each one would work great in a 10s set up for a 12-13 Ilb plane. Also have some 18x8 Xoar props
http://www.rcgroups.com/forums/showthread.php?t=1804363
And I have 2 TFR6 FR Sky Futaba Fasst compatable receivers, I'd let both go for 30.00. Thanks everyone.
Steve
stevelmaa is online now Find More Posts by stevelmaa
Old Jan 08, 2013, 02:40 PM
Vitter is offline
Find More Posts by Vitter
Gas Monkey Vic
Vitter's Avatar
Snohomish, WA
Joined Jan 2005
NICE! I love biplanes
Vitter is offline Find More Posts by Vitter
For Sale 3DHS Aspera - p/u only, Seattle or Portland Earthbound Aircraft - Electric - Airplanes (FS/W) 1 Feb 26, 2009 07:16 PM
Cool seattle area pilots b36roxs Slope 0 Jul 26, 2008 12:32 PM
A Few Wood Built-up 3D Planes in the Seattle Area xwingnut Non R/C Items (FS/W) 4 Jan 07, 2008 07:12 PM
Sold Parkzone Typhoon 3D (Seattle area only) price reduced to $100 corsha99 Aircraft - Electric - Airplanes (FS/W) 3 Feb 04, 2007 11:44 AM
Seattle Area Pilots, lets fly this weekend Todd Long Electric Plane Talk 9 Sep 08, 2001 03:40 AM
