Old Dec 26, 2012, 02:00 PM
pro bro steve is offline
Find More Posts by pro bro steve
pro bro steve's Avatar
Sammamish WA
Joined Sep 2003
I saw your pic of build posts it looks great . If you need borrow any colors for it just let me know.
Chet it will be nice to see you and your family at the club again . I was wandering if you moved or what .
pro bro steve is offline Find More Posts by pro bro steve
Old Dec 27, 2012, 01:40 AM
Robert R is online now
Find More Posts by Robert R
It's a fine fiddly business.
Robert R's Avatar
United States, WA, Marysville
Joined May 2009
3D,
I fly slow lumbering scale(ish) planes and gliders so I am no help in answering your question, but welcome to RCgroups.
Best,
Robert
Robert R is online now Find More Posts by Robert R
Latest blog entry: Mustang Sally Sea Trials
Old Dec 27, 2012, 02:06 PM
tconners is offline
Find More Posts by tconners
My tapeworm tells me what todo
United States, TX, Houston
Joined Feb 2007
I have a 20cc slipstream MCX for sale/partial trade. RTF minus RX.
PM me if interested. Looking for 4-5000mah 35c or better 3, 4, and 6s pairs, NAZA with GPS, 5 savox servos, ect............
tconners is offline Find More Posts by tconners
Old Dec 27, 2012, 07:49 PM
gabrielisrael is online now
Find More Posts by gabrielisrael
Got the Slickness
gabrielisrael's Avatar
Seattle, WA
Joined Jul 2010
Joe, is this your battery tests results on the Extreme Flight thread?
http://www.rcgroups.com/forums/showt...43213&page=491
gabrielisrael is online now Find More Posts by gabrielisrael
Old Dec 27, 2012, 07:58 PM
MCSGUY is offline
Find More Posts by MCSGUY
aka JetMan Joe
MCSGUY's Avatar
Joined Feb 2010
Yes Sir, my thread is:
http://www.rcgroups.com/forums/showt...3#post23223191
MCSGUY is offline Find More Posts by MCSGUY
Old Dec 27, 2012, 10:24 PM
spiked3 is offline
Find More Posts by spiked3
United States, WA, Seattle
Joined Apr 2007
Does anyone have experience with maker spaces in the area? I used to have a lot of stuff at home - CNC mill, lathe etc - but not anymore - I'm now in a small 1 BR apt - but I'm starting to have ideas for stuff I want. Can I get by using one of these places occasionally or is it time to start thinking about bigger living space again? I need a handicap apartment with a garage, no steps and no yard maintenance
spiked3 is offline Find More Posts by spiked3
Old Dec 28, 2012, 12:12 AM
MCSGUY is offline
aka JetMan Joe
MCSGUY's Avatar
Joined Feb 2010
What's a "marker space"?
Old Dec 28, 2012, 01:10 AM
Mr Whirl is offline
Find More Posts by Mr Whirl
Gone 2 Drone Darkside! FPV FAA
Mr Whirl's Avatar
United States, WA, Redmond
Joined Sep 2012
Joe, very nice work on the lipo comparison.
Got a new charger for Christmas. My new TP 820 displays charging in Amps rather than my old 610 which displayed charging in C. Argh this Amp verse C(rap) continues to drive me insane.
Help please confirm the calc for accurately converting C to amps for a given #mah lipo rated at #c constant / #c burst.
Example Nano Tech 3850mah 6s 65c lipo rated at 8c max charge.
3850mah / 1000 = 3.85amp x 8c = 30.8 amp max charge rate / correct?
However for a Nano Tech 2850mah 6s 65c lipo rated at 8c max charge.
2850mah / 1000 = 2.85amp x 8c = 22.8 amp max charge rate / correct?
If mfg charging C rating is not stated for a lipo then what is the safe calc for determining the # amp max charge rate instead just using of the default 2c rule?
Example Genace 2000mah 3s 25c
2c method 2000mah / 1000 = 2amp x 2c = 4amp max charge rate / correct?
xc method ?
Calculating the max C charge for a Lipo that isn't clearly indicated / I found the what appears to be the the methodology, calculations and rational explained on these threads:
http://www.rcgroups.com/forums/showthread.php?t=1578001
http://www.rcgroups.com/forums/showthread.php?t=1577989
Now my head hurts again.
Thanks in advance for your wisdom.
Mr Whirl is offline Find More Posts by Mr Whirl
Old Dec 28, 2012, 01:20 AM
spiked3 is offline
Joined Apr 2007
"Maker" space joe. I meant to post a link to the one I know of but got into something else and forgot.
http://metrixcreatespace.com/
It looks like they have 3D printers, but no mills/lathes. And then I start thinking about a sherline CNC setup again (which wasn't half bad) and I quickly try to divert my mind somewhere else, or else .... :|
Old Dec 28, 2012, 01:33 AM
Lardog is offline
Find More Posts by Lardog
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
xc method ?
Steve,
Your calculations are correct. Also, I think your 2c charging rule is sound. However, I'm pretty sure GensAce packs are good for a 5c charge rate.
Lardog is offline Find More Posts by Lardog
Old Dec 28, 2012, 01:53 AM
danielph is offline
Find More Posts by danielph
TEAM EXTREME!
danielph's Avatar
High Prairie, WA
Joined Nov 2007
Anyone else enjoying the snow, or are you all huddled indoors smoking - I mean flying Crack? LOL The weather has been nasty here for a while, but we finally got some calm weather yesterday.
Extreme Flight 48'' Extra 300EXP snow flying 2012.mp4 (5 min 34 sec)
danielph is offline Find More Posts by danielph
Old Dec 28, 2012, 03:49 AM
Mr Whirl is offline
Mr Whirl's Avatar
Joined Sep 2012
Originally Posted by Lardog View Post
Steve,
Thanks Larry.
To add to the complexity. Does it matter what the input voltage is from the power supply (12v or 24v or 28v) in relation to the afore mentioned calculations or do all quality chargers self adjust the voltage output based on 4.20 volt per cell max? Hence the need for intergrated balance board?
Example, so in the case of a 3s lipo the charger will only utilize 3x4.2v per cell or 12.6v total output to the lipo even if there is 28 volts input into the charger from the power supply?
Oh how I wish now that I had taken some EE classes in college beyond electrical physucks 201. Volts, Amps, Watts, Ohms, C, Wave Form, Flux Capacitor. lol I really don't want to burn my house down in a giant lipo ball of flames.
Old Dec 28, 2012, 10:20 AM
stumpygarner is offline
Find More Posts by stumpygarner
stumpygarner's Avatar
Joined Feb 2012
Batteries for crack planes
Where are you guys getting parallel charge cables and balanced cables for six batteries at a time
stumpygarner is offline Find More Posts by stumpygarner
Old Dec 28, 2012, 10:27 AM
xxD-Manxx is offline
Find More Posts by xxD-Manxx
Go Fly Yourself...!!
xxD-Manxx's Avatar
United States, WA, Bonney Lake
Two great places to get balance boards:
Progressive RC
EPBuddy
Some will say to go with the cables instead of the boards due to the power limitations of the less expensive boards.
Boards or cables... you can't go wrong with the two suppliers above.
Hope this helps,
D-Man
xxD-Manxx is offline Find More Posts by xxD-Manxx
Old Dec 28, 2012, 11:44 AM
Got the Slickness
Seattle, WA
Joined Jul 2010
http://www.youtube.com/watch?v=kDPEN...ature=youtu.be
Nice vid!! Really like the down lines into the knife edge spins.
For Sale 3DHS Aspera - p/u only, Seattle or Portland Earthbound Aircraft - Electric - Airplanes (FS/W) 1 Feb 26, 2009 07:16 PM
Cool seattle area pilots b36roxs Slope 0 Jul 26, 2008 12:32 PM
A Few Wood Built-up 3D Planes in the Seattle Area xwingnut Non R/C Items (FS/W) 4 Jan 07, 2008 07:12 PM
Sold Parkzone Typhoon 3D (Seattle area only) price reduced to $100 corsha99 Aircraft - Electric - Airplanes (FS/W) 3 Feb 04, 2007 11:44 AM
Seattle Area Pilots, lets fly this weekend Todd Long Electric Plane Talk 9 Sep 08, 2001 03:40 AM
