Old Nov 19, 2012, 04:40 PM
mark_q is online now
Find More Posts by mark_q
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
Originally Posted by TheEarl Of Whirl View Post
Do you get any control surface slop from the z-bend & does the adjustable link bind at high angles? If not it would certainly be a lighter & simpler solution. Thanks for the info.
No, but this depends on wire size and hole size and
No, I've had no binding issues but on the DW's, it is very easy to get the geometry such that this isn't a concern.
Hey, I like cheaper and lighter!
mark_q is online now Find More Posts by mark_q
Latest blog entry: X-UAV Mini Talon #2
Old Nov 20, 2012, 12:32 AM
flarpy is offline
Find More Posts by flarpy
Flarpy
flarpy's Avatar
Kitsap County
Joined Nov 2010
Holy crapshoot egaus!! $7k!!!!
That would put a sweet 40%er in the collection!
flarpy is offline Find More Posts by flarpy
Old Nov 20, 2012, 08:39 PM
egaus is offline
Find More Posts by egaus
Quadrophenia
egaus's Avatar
Seattle
Joined Mar 2009
I think that was Spiked3. I don't have anything approaching $7k. If I add up each model individually, the number gets much larger though.
e
egaus is offline Find More Posts by egaus
Old Nov 21, 2012, 03:02 PM
Mr Whirl is offline
Find More Posts by Mr Whirl
Gone 2 Drone Darkside! FPV FAA
Mr Whirl's Avatar
United States, WA, Redmond
Joined Sep 2012
Originally Posted by harv_d View Post
i got tired of searching through all the posts so ill just ask. What did you guys think the optimum set up for the 32" crack yak was? the lite version or regular? 2s or 3s?
Leaving no stone unturned, I spent some time running thru the entire Crack Yak Std thread from begining to end compiling the best tips & tricks beyond what the build log or manual states. I figured before I build mine I could learn alot from others who are willing to share. If I am going to get addicted then I want to make sure I have got some uber super crack.
Crack Yak Build Tips & Setup Tricks
Plastic Painters Tarp
http://www.rcgroups.com/forums/showp...&postcount=155
CA or Welders glue
http://www.rcgroups.com/forums/showp...3&postcount=84
http://www.rcgroups.com/forums/showp...5&postcount=16
Control Rod Mounting
http://www.rcgroups.com/forums/showp...&postcount=264
http://www.rcgroups.com/forums/showp...&postcount=329
http://www.rcgroups.com/forums/showp...postcount=1580
http://www.rcgroups.com/forums/showp...postcount=1637
Fuselage Alignment
http://www.rcgroups.com/forums/showp...&postcount=213
http://www.rcgroups.com/forums/showp...postcount=1567
http://www.rcgroups.com/forums/showp...postcount=1594
http://www.rcgroups.com/forums/showp...postcount=1899
Control Surface free play
http://www.rcgroups.com/forums/showp...&postcount=455
Landing Gear
http://www.rcgroups.com/forums/showp...&postcount=510
http://www.rcgroups.com/forums/showp...postcount=1523
http://www.rcgroups.com/forums/showp...postcount=1535
http://www.rcgroups.com/forums/showp...postcount=2691
Durability Enhancements
http://www.rcgroups.com/forums/showp...&postcount=838
http://www.rcgroups.com/forums/showp...postcount=1007
http://www.rcgroups.com/forums/showp...postcount=1382
http://www.rcgroups.com/forums/showp...2&postcount=18
Battery Mounting
http://www.rcgroups.com/forums/showp...postcount=1477
http://www.rcgroups.com/forums/showp...postcount=1481
http://www.rcgroups.com/forums/showp...postcount=3748
http://www.rcgroups.com/forums/showp...postcount=2901
Neutral CG
http://www.rcgroups.com/forums/showp...&postcount=162
http://www.rcgroups.com/forums/showp...&postcount=557
http://www.rcgroups.com/forums/showp...postcount=1456
http://www.rcgroups.com/forums/showp...postcount=1777
http://www.rcgroups.com/forums/showp...postcount=1779
http://www.rcgroups.com/forums/showp...postcount=3030
http://www.rcgroups.com/forums/showp...postcount=3062
http://www.rcgroups.com/forums/showp...postcount=3072
Motor Thrust Angle
http://www.rcgroups.com/forums/showp...postcount=2014
http://www.rcgroups.com/forums/showp...postcount=3013
http://www.rcgroups.com/forums/showp...postcount=2908
http://www.rcgroups.com/forums/showp...postcount=1358
http://www.rcgroups.com/forums/showp...postcount=3021
Flight Trimming
http://www.rcgroups.com/forums/showp...postcount=2151
Alternate Servos
http://www.rcgroups.com/forums/showp...postcount=2097
Alternate Motors
http://www.rcgroups.com/forums/showp...postcount=1269
http://www.rcgroups.com/forums/showp...postcount=1974
http://www.rcgroups.com/forums/showp...postcount=2200
Alternate Propellers
http://www.rcgroups.com/forums/showp...postcount=1399
Alternate Prop O-Rings
http://www.rcgroups.com/forums/showp...postcount=2277
http://www.rcgroups.com/forums/showp...postcount=2278
Parallel Battery Charging
http://www.rcgroups.com/forums/showp...postcount=2678
Mr Whirl is offline Find More Posts by Mr Whirl
Old Nov 21, 2012, 03:20 PM
Lardog is offline
Find More Posts by Lardog
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
If you already have a parallel charging board for your normal connector type, it should have the 2s or 3s balance ports on it. All you need then is a parallel charge cable with JST connectors
Lardog is offline Find More Posts by Lardog
Old Nov 21, 2012, 03:39 PM
Mr Whirl is offline
Mr Whirl's Avatar
Joined Sep 2012
Thanks for the tip. I figured I have to buy a separate six position balance board since I only have the stock thunder power balance board with one 2s JST connector port. Also I don't feel warm an fuzzy about charging without a balancer what are your thoughts?
Old Nov 21, 2012, 04:40 PM
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
I never charge without balancing!
I use the ProgressiveRC cables and on the balance side I use the 6S cable set for everything I do because you can plug 2,3,4,5 & 6S connectors into it.
Just my 2 cents -
Old Nov 21, 2012, 05:41 PM
Lardog is offline
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
I also typically balance everytime I charge as well, although it really isn't critical if your packs are in balance to start with. I regularly use a paraboard for normal balance charging. Mine is setup for XT60 connectors. Since the board already has the balance ports, all I need for the small packs that use JST power connectors is the adapter cable I linked to and I can balance charge up to 6 packs simultaneously, which just about covers most outings with my foamy.
Old Nov 21, 2012, 07:20 PM
Mr Whirl is offline
Mr Whirl's Avatar
Joined Sep 2012
Thank you guys. I am listening and learning. Keep feeding me the good stuff, I'm like a info shamwow. lol Once I get my custom parts fab'd and my uber super enhanced crack yak flying your welcome to take the sticks.
Old Nov 21, 2012, 09:31 PM
cryhavoc38 is offline
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
Is it summer yet?
I mean August?
cryhavoc38 is offline Find More Posts by cryhavoc38
Old Nov 21, 2012, 09:42 PM
MCSGUY is offline
Find More Posts by MCSGUY
aka JetMan Joe
MCSGUY's Avatar
Joined Feb 2010
That's pretty incredible, I wish I'd have talked with you guys a few power supplies ago
MCSGUY is offline Find More Posts by MCSGUY
Old Nov 21, 2012, 09:53 PM
m0dest is offline
Find More Posts by m0dest
aka ECAA3D
m0dest's Avatar
United States, WA, Olympia
Joined Apr 2012
Crazy drivers out there. Be Careful!
Went to the HobbyKing warehouse earlier to pick up a motor/esc to get the crackyak going and it was the first time I have witnessed an accident in my rear view mirror right before the 512n exit.
I guess the lesson learned is.....if your cars quarter panel barely makes contact with someone elses car.....don't jerk your car completely off the road and fishtale through a field of grass.
I thought the person recovered, but coming back there was a whole accident scene. Didn't look like anyone was hurt though.
m0dest is offline Find More Posts by m0dest
Old Nov 21, 2012, 11:14 PM
SupaTim is offline
Find More Posts by SupaTim
Owner/Operator at NorthWest RC
SupaTim's Avatar
United States, WA, Orting
Joined Jan 2010
Hey guys! Just wanted to pop back in to say Happy Thanksgiving to all my 3d knuckle head bros! Miss you guys and sorry to be a recluse the last few weeks, but the new job and family have had me burning the candle at both ends with not much left in the middle for sleep...
Making sure all my new big builds are running cans so I can play up north without ruffling any feathers. I'm in Auburn M-F 7-6 so I'm halfway north for any random fun, just keep me in the loop. Rarely on the web or email, but shoot me a text at my new cell # any time.
Take care boys and huck on!
Tim
(253)383-5496
SupaTim is offline Find More Posts by SupaTim
Old Nov 21, 2012, 11:19 PM
JohnVH is online now
Find More Posts by JohnVH
Qualified
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
Originally Posted by cryhavoc38 View Post
Is it summer yet?
I mean August?
No summer until we get a few feet of snow!
JohnVH is online now Find More Posts by JohnVH
Old Nov 22, 2012, 01:42 AM
Azhar is offline
Find More Posts by Azhar
Joined Aug 2007
Happy Thanks Giving All!!
Azhar is offline Find More Posts by Azhar
For Sale 3DHS Aspera - p/u only, Seattle or Portland Earthbound Aircraft - Electric - Airplanes (FS/W) 1 Feb 26, 2009 07:16 PM
Cool seattle area pilots b36roxs Slope 0 Jul 26, 2008 12:32 PM
A Few Wood Built-up 3D Planes in the Seattle Area xwingnut Non R/C Items (FS/W) 4 Jan 07, 2008 07:12 PM
Sold Parkzone Typhoon 3D (Seattle area only) price reduced to $100 corsha99 Aircraft - Electric - Airplanes (FS/W) 3 Feb 04, 2007 11:44 AM
Seattle Area Pilots, lets fly this weekend Todd Long Electric Plane Talk 9 Sep 08, 2001 03:40 AM
