Old Nov 03, 2012, 03:31 PM
MCSGUY is offline
Find More Posts by MCSGUY
aka JetMan Joe
MCSGUY's Avatar
Joined Feb 2010
Hey guy's the Slick is finished but I need some feedback regarding the balancing. Using the method of hanging it by the spar tube the nose dips about as much as it shows in the manual (gas tank filled). Because it was coming out nose heavy you can see how I put everything towards the back. However when I try double checking by suspending it 4-5" back on the wing tips it appears tail heavy. Which method should I trust?!
(BTW, a shout out to Cry for giving me a bunch of the braided wire cover, it's excellent at protecting the wires from chafing!)
MCSGUY is offline Find More Posts by MCSGUY
Old Nov 03, 2012, 03:42 PM
Aeroplayin is offline
Find More Posts by Aeroplayin
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
I thought I'd stop by to ask this question... might be a longshot considering the location, but a friend of mine has a son in the Nevato, CA, area who flew years ago (he's probably in his mid-40's now), then got into racing cars (full scale), and how has a young family and is looking to get back into flying. He's interested in the 50cc - 120cc size 3D/extreme aerobatic airplanes and I'm trying to help him find a club that's 3D-friendly in northern California. I'd appreciate any help you can give me.
Second, I finally got around to getting the Javascript done for the PropEngine, so it's back up and has a new home: http://rcwebclub.com/PropEngine.aspx
Aeroplayin is offline Find More Posts by Aeroplayin
Old Nov 03, 2012, 03:48 PM
Lardog is online now
Find More Posts by Lardog
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
Considering there is a whole state + (~800 miles) between us here in Seattle and Novato, CA, I'm not sure you're going to find any assistance from this group.
Good luck though.
Lardog is online now Find More Posts by Lardog
Old Nov 03, 2012, 03:54 PM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
Yeah, I thought it would be a longshot, but if anyone knows of guys coming up your way, like for IMAC competitions, Huckfests... I think a few guys come up from as far south as San Diego for events... so maybe someone from the Bay area, or Sacremento, knows of a club. Thanks, anyway.
Old Nov 03, 2012, 08:25 PM
harv_d is offline
Find More Posts by harv_d
Canada, BC, Surrey
Joined Apr 2008
i would start by putting the canopy on. that would make a difference. and ive always measured from the wing tips. not sure if it makes a difference
harv_d is offline Find More Posts by harv_d
Old Nov 03, 2012, 09:23 PM
MCSGUY is offline
aka JetMan Joe
MCSGUY's Avatar
Joined Feb 2010
That's what's confusing. The manual says it shouldn't be different but it is. I'll put the canopy on and use the wing tips. Thanks!
Old Nov 03, 2012, 11:04 PM
Mr Whirl is offline
Find More Posts by Mr Whirl
Gone 2 Drone Darkside! FPV FAA
Mr Whirl's Avatar
United States, WA, Redmond
Joined Sep 2012
The Slick looks Beautiful Joe.
I don't fly gas but I have always had the best luck measuring CG balance with the plane set up to fly. As Harv indicated canopy on, in my case measuring at the wing cord at the fuselage root using a cg machine/tool. I then separately measure left / right balance using a piece of string attached to the freely rotating nose cone & and looped around the tail section behind the canopy.
Then the real work begins when I start flying as I then dial in the CG, setup & trim based on my flying style, following a specific flight test protocol. Here is a link to a great examplehttp://trabucorcflyers.com/uploads/T..._RC_Flight.pdf
Throughout last year as I pushed myself into new & unfamiliar 3D territory, I zeroed my trims & sub-trims. re-measured cg & repeated the flight test sequence to dial it in again and again. I wanted to start to feel & see the subtle setup differences. In my opinion Kody is one of the best in the Mob at the CG & trim setup art. I always quietly have my eye on him, watching & listening to learn something new.
Mr Whirl is offline Find More Posts by Mr Whirl
Old Nov 03, 2012, 11:10 PM
racerxky is offline
Find More Posts by racerxky
Watts is where its at!
racerxky's Avatar
United States, WA, Seattle
Joe, nose heavy is not a bad thing! Tail heavy is much scarier for a maiden.
Andrew has a quote in the manual: "I prefer the forward rudder servo location with a DA-100 or DA-120 and in-cowl mufflers, this gives me the CG I want, which results in zero pitch coupling in knife-edge flight. I do not rear-mount the rudder servos unless I am running canister exhaust.”
I would move the rudder servos to the rear of the airplane like Andrew is suggests. That will give you the CG you are after. Then the rest of the gear can go in the normal locations and you should have a sweet flying airplane.
racerxky is offline Find More Posts by racerxky
Old Nov 04, 2012, 12:56 AM
cryhavoc38 is offline
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
I have plenty more if you need to finish off your plane with it.
cryhavoc38 is offline Find More Posts by cryhavoc38
Old Nov 04, 2012, 01:00 AM
JohnVH is offline
Find More Posts by JohnVH
Qualified
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
Originally Posted by TheEarl Of Whirl View Post
Rollin Rollin Rollin. the votes just keep rolling in!
(3D/FPV Supportive / RC Groups members):
If you know these guys / gals are MAR/C members encourage them to vote.
blk822
egaus - Voted
Rexor
viperjody
rdjay
Kai_Shiden
QuietRCFly
Jaguar_5
unshackledbuzz
jsomerville
nwsalmon
SabreHawk
flarpy - N/A
ee4air
airmanthesixth
eagle777
JohnVH
SupaTim - N/A
ecaa3d
tconners
Magneto
hcannon98 - Voted
Rudderman98
Sorry, wish I was a member to help!
Nobody likes chafing!!
JohnVH is offline Find More Posts by JohnVH
Old Nov 04, 2012, 01:01 AM
cryhavoc38's Avatar
Joined Mar 2007
at the top of the RCG page above, click "MAPS"
type in Novato and you will see one club just north of Novato near Petaluma, and several just south of Novato
Old Nov 04, 2012, 10:24 AM
MCSGUY is offline
aka JetMan Joe
MCSGUY's Avatar
Joined Feb 2010
That's makes me feel better, that's why I had to mount everything rear of the carbon spar tube to get it to hang right. I'm going to relocate the tank in front of the tube so it's sure to favor nose heavy and give it a whirl
Old Nov 04, 2012, 11:27 AM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
Thanks, Cry... I sent him the link. His father was an F-16 instructor in the AF and there also seems to be a club at Beale. Maybe that would be a good place to start -- even though the link is broken. He also writes the Rotorspeed heli section for MAN so I'm sure there will be some heli's involved eventually. Thanks, again.
Jim
Old Nov 04, 2012, 01:58 PM
pro bro steve is offline
Find More Posts by pro bro steve
pro bro steve's Avatar
Sammamish WA
Joined Sep 2003
Its warm outside I think I am hitting the club.
pro bro steve is offline Find More Posts by pro bro steve
Old Nov 05, 2012, 08:53 PM
Sammamish WA
Joined Sep 2003
What happened to the 3 D mob ? Everybody should be posting with all the Halloween candy left over . LOL
Kody you got one nice flying 30 CC Slick there . I found out today about Tims orange 30 CC slick Sorry to here it went in . With your new plane and radio I wish you good luck.
For Sale 3DHS Aspera - p/u only, Seattle or Portland Earthbound Aircraft - Electric - Airplanes (FS/W) 1 Feb 26, 2009 07:16 PM
Cool seattle area pilots b36roxs Slope 0 Jul 26, 2008 12:32 PM
A Few Wood Built-up 3D Planes in the Seattle Area xwingnut Non R/C Items (FS/W) 4 Jan 07, 2008 07:12 PM
Sold Parkzone Typhoon 3D (Seattle area only) price reduced to $100 corsha99 Aircraft - Electric - Airplanes (FS/W) 3 Feb 04, 2007 11:44 AM
Seattle Area Pilots, lets fly this weekend Todd Long Electric Plane Talk 9 Sep 08, 2001 03:40 AM
