Old Mar 11, 2010, 06:48 AM
bsfixit is offline
Find More Posts by bsfixit
bsfixit's Avatar
Sarasota, FL
Joined May 2009
yes I am in the US. Great tip on taping the SD card in ..will do !
bsfixit is offline Find More Posts by bsfixit
Old Mar 30, 2010, 07:44 PM
captain stowed is offline
Find More Posts by captain stowed
One More Chuck
captain stowed's Avatar
Sydney, Australia
Joined Sep 2007
I swear it wasn't me...
http://www.smh.com.au/national/hidde...0331-rc5r.html
captain stowed is offline Find More Posts by captain stowed
Old Mar 31, 2010, 03:02 AM
gouch is offline
Find More Posts by gouch
de-registered abuser
gouch's Avatar
Lake Macquarie, Aust.
Joined Dec 2002
After reading that, I better order one before they ban the import of them or make them illegal. The way this place is going lately it wouldn't surprise me
gouch is offline Find More Posts by gouch
Old Mar 31, 2010, 03:45 AM
RoGuE_StreaK is offline
Find More Posts by RoGuE_StreaK
Caution: Noob in training
Australia, QLD, Redbank Plains
Joined Jun 2007
Should band together and get them to make new cases in a bright colour with something like "this is a video recording device" branded across it, so we can't be seen as trying to be doing something sneaky. We just want a small, light, good quality stand-alone system, not something for "spying", just something to legitimately record with without breaking the bank. I don't care what the hell it looks like, in fact I'm probably going to be stripping mine and making a new case, or series of cases, to incorporate a wide-angle lense and maybe go waterproof (I've already made a waterproof helmet-cam casing for surfing, hopefully will get some footage this weekend)
RoGuE_StreaK is offline Find More Posts by RoGuE_StreaK
Old Apr 03, 2010, 07:28 AM
annarelli is offline
Find More Posts by annarelli
Grampa Tony
annarelli's Avatar
Lawrenceville, GA - Northeast Atlanta
Joined Jan 2009
After far too many hours trying to figure out how to set the time, this is what I came up with:
Connect the camera to your PC with a USB cable. You can do most of this if you can plug the card into your PC or some sort of card reader if you like.
Create a file named tag.txt in the root of the SC card
File contents should be in the format of (Note the date format is YYYY.MM.DD):
[date]
2010.04.03
08:22:00
Disconnect the keychain camera. Power the keychain off. Power it back on again. Take a video - the time should be correct. Note that the tag.txt file has been deleted.
annarelli is offline Find More Posts by annarelli
Old Apr 03, 2010, 10:37 AM
bsfixit is offline
bsfixit's Avatar
Sarasota, FL
Joined May 2009
That is the method that works for me as well annarelli. I have been waiting for mild winds so I can take some video from a plane...
Old Apr 03, 2010, 05:43 PM
Stunt Double is offline
Find More Posts by Stunt Double
Australia, VIC, Melbourne
Joined Oct 2007
Thanks Annarelli. I tried a few different methods now finally something has worked!! You should try removing the date/time stamp using Virtual Dub & the Timestamp filter. Works well for me.
Virtual Dub - http://www.virtualdub.org/
Timestamp Filter - http://home.people.net.au/~aircommand/md80clone.htm
Stunt Double is offline Find More Posts by Stunt Double
Old Apr 03, 2010, 07:47 PM
junglegym is offline
Find More Posts by junglegym
3 Strykers,your out !
junglegym's Avatar
Lurking Melbourne Australia
Joined Apr 2008
Keychain cam
You won't be disappointed.Quality is great However you loose a bundle uploading it to YT unfortunately
Blizzard run MPX (1 min 31 sec)
Blizzard, Multiplex wing cam (1 min 50 sec)
junglegym is offline Find More Posts by junglegym
Old Apr 03, 2010, 10:16 PM
bsfixit is offline
bsfixit's Avatar
Sarasota, FL
Joined May 2009
nice.. I get some RF noise from the outrunner on my video as well.. not as bad as your first video. I wonder if foil around the camera would block some brushless RF noise...
Old Apr 04, 2010, 01:53 AM
One More Chuck
Sydney, Australia
Joined Sep 2007
That's not RF noise, it's just what props look like through a CMOS camera. Something to do with the fact that not all of the frame is recorded at the same time.
m.
Old Apr 04, 2010, 07:31 AM
bsfixit is offline
bsfixit's Avatar
Sarasota, FL
Joined May 2009
really? I thought my camera was far away from the prop on my left wing.. and the short video I took so far shows the lines on the left of the screen...
Old Apr 08, 2010, 05:53 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Finally got the date to change in my cam! took a few goes to get it to take. Does anyone know if its been removed altogether? IE someone written a patch or something to remove the stamp..
Extreme_RC is offline Find More Posts by Extreme_RC
Old Apr 08, 2010, 07:23 PM
woodsy is offline
Find More Posts by woodsy
Woodsy
Drouin, Australia
Joined Sep 2003
Not that i can find so far
woodsy is offline Find More Posts by woodsy
Old Apr 09, 2010, 12:05 AM
Zootster is offline
Find More Posts by Zootster
Joined Jul 2007
If you dont want to see the prop............................. face the camera backwards
PA Shocky2_0002.wmv (5 min 54 sec)
Zootster is offline Find More Posts by Zootster
Old Apr 09, 2010, 05:47 PM
flyonline is offline
Find More Posts by flyonline
Twisted and Confused
flyonline's Avatar
Joined May 2003
......fly a slopey
Steve
flyonline is offline Find More Posts by flyonline
Discussion manufacturer of key chain help you solve the problem for you Eric-cn Aerial Photography 7 Feb 07, 2016 03:00 AM
Cool MINI Spy Camera Key Chain Camcorder ken_nj Dock Talk 190 Jun 25, 2010 11:24 PM
Discussion Key Chain Camera - Park flyer Learjets Aerial Photography 1 Jan 22, 2010 08:07 PM
Discussion Key chain camera battery Crist Rigotti Batteries and Chargers 6 Nov 25, 2009 10:50 AM
