Old Mar 24, 2012, 10:58 AM
The_RattleSnake's Avatar
Joined Jul 2007
I was having loads of trouble changing the date on my #3 cam
I was doing all the correct date formats but it wasnt changing anything.
A few times in this thread said to take a video then turn it off which was what I was doing.
Taking video didnt work for me, as soon as I took a picture instead it worked first go.
The_RattleSnake is offline Find More Posts by The_RattleSnake
Old Oct 12, 2012, 06:45 AM
tow
tow's Avatar
Norway, Nord-Trondelag, Namsos
Joined Dec 2003
I`m getting grey-haired over this. I tried every possible suggestion in this thread but no help Not sure wich version I have, but the date stamp showa a slash (/) so...........???? HEEELP!!!!
tow is offline Find More Posts by tow
Old Oct 13, 2012, 01:13 AM
gazza2003au's Avatar
Sydney, Australia
Joined Jul 2003
post a video of your camera i spent the extra bux on the #11 camera and its great so far records in HD the other #3 cameras have great quality picture but crap out all the time and u need to keep buying more ive had the #11 camera for i donno maybe 9 months? now and rarely use it but everytime i need to use it it works as it should i have 2 other keychain cameras here that have crapped out and also had another exploded while charging
gazza2003au is offline Find More Posts by gazza2003au
Old Dec 16, 2012, 02:18 PM
Trying to fly
Joined Dec 2012
keychain cam
I've used the keychain cameras for a while on my rockets, has anyone modded the camera for a light weight heli(mjx f47)or does it not weigh enough to worry about?I love these things I have two and am getting one or two more..there cheap enough
Aiolos is offline Find More Posts by Aiolos
Old Jan 11, 2013, 09:27 PM
Joined Jan 2013
Help with 808
Hello,
I just purchased a 808 camera from Amazon. (This one: http://www.amazon.com/gp/product/B00...ls_o03_s00_i00)
When I plug it in, the light flashes (should be steady). When I unplug it, it is unresponsive. Youtube recognized it as a camera and I was able to record a short clip. In the bottom left corner it says "DV V0.29". The resolution is 360. Other than Youtube, no other program (so far) has recognized it and I cannot get it to record to SD at all.
So, I have two questions.
1. How can I determine which version of camera I have?
2. Any tips on how I can get it working?
I have tried:
New USB cord, new usb port, format SD card, reset camera, unplug while pushing power button, plug in while pushing power button, charge from USB wall adapter.
Thanks!
TrekMac is offline Find More Posts by TrekMac
Old Jan 12, 2013, 05:55 AM
If it flies - it's good
Fred_L's Avatar
Randwick, NSW Australia
Joined Sep 2003
Does it appear to respond to the button presses correctly?
I assume you have charged the battery. Without it connected to anything does pressing the rear button turn it on (light illuminates)? From there, does a quick press of the front button take a picture (light goes out momentarily)? Does a long press put it into movie record mode (light goes out)?
Mine saves the pictures as .jpg files and the movies as .avi files (very large ones at that). I haven't tried to use it as a webcam while connected to a computer.
Fred_L is offline Find More Posts by Fred_L
Old Jan 12, 2013, 11:02 AM
bsfixit's Avatar
Sarasota, FL
Joined May 2009
you have to make sure the SD card is formatted in FAT, using a PC , it doesn't work formatting it on my MacBook Pro. Do yourself a favor and get a keychain camera that specifically states it is HD 720p with the H.264 codec. The video files it makes are .mp4 and are excellent quality as long as the camera doesn't vibrate on your plane. There is a list of trusted sellers somewhere in the threads about the 808 keychain cameras.. and in the following link.. I have a #11
http://www.chucklohr.com/808/index.shtml Navigate to that link and read. It tells you which version you have , problems, solutions and even firmware updates for some. Good luck!
Bsfixit
EDIT: Sorry ... FAT32 is the format type not FAT..
bsfixit is offline Find More Posts by bsfixit
Old Jan 16, 2013, 02:21 AM
Joined Apr 2007
Would this sd card be ok for the 808? http://www.ebay.co.uk/itm/TRANSCEND-...item1e72e083f4
symon is offline Find More Posts by symon
Old Jan 16, 2013, 07:53 PM
bsfixit's Avatar
Sarasota, FL
Joined May 2009
I use a class 10 SD card with my Nikon D-90 DSLR,
class 4 or better seems to work well... the higher the better...http://www.chucklohr.com/808/index.shtml
Old Jan 16, 2013, 11:58 PM
Tassie Electric, Heli, Glider
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
I'd be getting something better especially if its a HD recorder (#11, 16 or 18). I use a class 10 on my #18. Also get a known brand. Worth spending a few dollars more as you can get missing frames on cheap cards.
ChrisJ800 is offline Find More Posts by ChrisJ800
Old Jan 18, 2013, 08:09 AM
Joined Apr 2007
Hi,
Got the card through....fixed it all up....works great!..great video...also the time/date in bottom right hand corner is yellow...does this mean its a 3 version?
Old Jan 18, 2013, 01:52 PM
Joined Apr 2007
Hi,
Would this be ok to charge the 808 battery?..http://www.ebay.co.uk/itm/Brand-New-...item3f1b2590b3
Old Jan 19, 2013, 07:30 PM
Chasin' that Neon Rainbow
Grantham Kid's Avatar
Australia, QLD, Grantham
Joined Oct 2012
Our own Aerial Photography forums have some of the best info on these cams. I don't use my #11 anymore after buying the #16 HD V2 with the D lens for $43. I love it. The great thing is, you can plug it into your puter and change any setting you want to with a GUI program available free.
This is where I get my cards and postage is free. http://www.ebay.com/itm/OEM-16GB-16G...item4844b94657
Symon, 5 volts is OK but at those amps you will burn the battery real quick.
Grantham Kid is online now Find More Posts by Grantham Kid
Old Jan 20, 2013, 02:37 AM
Joined Apr 2007
Hi,
Thanks,,,so what volts should it be charged at??
Old Jan 20, 2013, 03:50 PM
Joined Oct 2012
I know the #16 should not exceed 5 volts absolute maximum. Mine came with a cable that can plug direct into your plane receiver. This extends the video filming time and keeps it charged. This is the one I got here and it shows the cables that come with it. This seller is the manufacturer of these cams. There are many different copies out there. http://www.ebay.com/itm/Mini-DVR-808...item2a20b389dc
Only safe way for you is charge it with the mini USB cable via your 'puter.
Discussion manufacturer of key chain help you solve the problem for you Eric-cn Aerial Photography 5 Feb 01, 2011 06:29 AM
Cool MINI Spy Camera Key Chain Camcorder ken_nj Dock Talk 190 Jun 25, 2010 11:24 PM
Discussion Key Chain Camera - Park flyer Learjets Aerial Photography 1 Jan 22, 2010 08:07 PM
Discussion Key chain camera battery Crist Rigotti Batteries and Chargers 6 Nov 25, 2009 10:50 AM
