Joined Feb 2010
The T-28 roars with this motor compared to stock, there is no comparison. It also maneuvers better and glides slower without the heavy stock motor out on the nose. No longer much need for flaps, I have since pulled out my extra servos and taped up my flaps. I'll post some airborne video when my keychain cam gets here, I ordered it from Hong Kong a few days ago. ![]() Flaps. |
Joined Jul 2006
http://www.rcgroups.com/forums/showt...6#post14427646 Tell the good Dr Kiwi that you have the real facts on the Tigre .10 I'll meet ya over there... PS: the Tigre .10 is a disappointment... ![]() Chuck |
Joined Jul 2006
Here's the actual test data for the Super Tigre .10
http://www.rcgroups.com/forums/showt...=supertigre+10 Chuck |
Joined Feb 2010
Your loss of a fantastic $24 upgrade that provides a 1.1 T:W with the stock ESC, one that anyone can measure for themselves. But I will post an airborne video in a week or so. |
Joined Feb 2010
http://www.rcuniverse.com/forum/fb.asp?m=9099196 "I just put a supertigre st .10 in mine and like it a lot as well. For under 30 bucks it works great. Kv is 1250 with 320 watts constant and 370w surge. Using the stock prop I have unlimited vertical now, and when I tried an apc 9x9 the speed was quite nice, but lost some thrust, so I'm gonna stick to stock prop for now. It feels lighter than the stock 480, not sure though. But it is a lot more compact than stock motor with a bit better performance." As you can see from my chart, he is way over-propping it with the square prop and probably flying well into ESC cutoff land. But even so, that doesn't sound at all like his corsair flies poorly with the ST .10 motor. I'm certain that "unlimited vertical" with a low static thrust prop choice, is not flying poorly. But the weight savings, way out on the moment arm, is really where the ST .10 shines. It is a GREAT motor for those looking to turn their T-28 into an A6M, not into an F-104. No matter what people who've never flown the motor say. |
Joined Jul 2006
It's rising as the current is rising. |
Joined Feb 2010
- Recording the thrust scale, W meter, and/or Amps in various orders on various runs - Different numbers of blades pushing the engine WAAAY into no-no land - The W and Ammeter meters jumping around 5% or so percent during real life sampling - My lack of utter perfection Bottom line: These tests are empirical, not perfect, and they are fundamentally correct and easily verified by anyone who's actually flown the motor. |
Joined Feb 2010
You said: "At any rate, it paled by comparison to the stock motor in the Corsair and Trojan." A Corsair flyer said: "I just put a supertigre st .10 in mine and like it a lot as well. For under 30 bucks it works great. Kv is 1250 with 320 watts constant and 370w surge. Using the stock prop I have unlimited vertical now" I'm not sure why you are predisposed to dislike a motor. Are you a vendor of another type of motor? |
Joined Jul 2006
Stick a GWS 11x7 HD prop on that plane and with a 3s Li-Po on the stock motor, you'll get 50 ounces of thrust. Now THAT is some serious vertical for about 24 amps of current from the stock motor. |
USA, FL, Doral
Joined Jul 2006
Going back to the original Op question.....
I still fly my old trojan (the one with a 25 amp esc stock)....i just added a dimension enginering external park bec....works like a charm...and i also changed the stock pro to a bit larger apc...(cant remember the exact size, and its after midnight, so i dont have any intention to go down to my garage...), using 3s 2200 25 and 30 c lipos flies beautifully.... |
| Thread Tools | |
| Found Parkzone P-51 Brushless BNF or Parkzone T-28 Trojan | CGReload | Aircraft - Electric - Airplanes (FS/W) | 3 | Aug 10, 2009 09:55 PM |
| Discussion parkzone trojan t-28 esc | keithn4 | Beginner Training Area (Aircraft-Electric) | 20 | Jan 10, 2009 01:05 PM |
| Discussion parkzone T-28 Trojan esc? | ggjj | Parkflyers | 1 | Oct 08, 2008 05:48 PM |
| Sold Parkzone T-28 Trojan Parts. E-flite 25AMP ESC/Parkzone 480 Motor/2 Props/DC Carger | CGReload | Aircraft - Electric - Power Systems (FS/W) | 7 | Sep 03, 2008 04:35 PM |
| Sold Parkzone 480, 960kv motor for trojan t-28 | la528it | Aircraft - Electric - Power Systems (FS/W) | 10 | Apr 02, 2008 03:32 PM |
