Old Apr 16, 2010, 12:37 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Originally Posted by littleoak View Post
My CG is just behind the carbon wing spar. About 75mm from leading edge. Seemed to fly nice and stable at that point.
Mine ended up at 72mm. I am sure this will be good for starters.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Apr 16, 2010, 12:57 AM
Donflyer is offline
Find More Posts by Donflyer
Valley Springs CA
Joined Apr 2010
My problem with the Sky Surfer was the propeller blades seperated from it's hub during motor checks. I have emailed the tech support and wating for their response.
Donflyer is offline Find More Posts by Donflyer
Old Apr 16, 2010, 03:24 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
What do you mean separated? I am having a hard time visualizing that.
AJ
Old Apr 16, 2010, 08:16 AM
road_rascal is offline
Find More Posts by road_rascal
Joined Dec 2008
Sounds like the prop threw a blade.
road_rascal is offline Find More Posts by road_rascal
Old Apr 18, 2010, 10:35 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Yeah. That makes sense.
AJ
Old May 09, 2010, 03:59 PM
Vantasstic is online now
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Hey AJ...did you fly your SS yet? I'd not buy a RR version, but have thought about a kit version. I really like the idea of the white wings and tail which lend for better decorating and visibility than the blue or silver MPX ones.
Vantasstic is online now Find More Posts by Vantasstic
Old May 14, 2010, 07:34 PM
Ron RC is offline
Find More Posts by Ron RC
Parma, Ohio
Joined May 2010
Mine did the exact same thing. The hub in the center of the prop just broke and the blades went south. This was before I even flew it. Just a runup of power to check everything. Changed to 6x4 that I had to ream out to fit. Glad to know I wasn't the only one experiencing that and also glad the prop was not it the front. Told BH it was defective.
Ron
Ron RC is offline Find More Posts by Ron RC
Old May 31, 2010, 08:10 PM
jonnyd is offline
Find More Posts by jonnyd
Joined Mar 2010
AJ
what is an appropriate cg for a first time flier. where do you measure from. how do you check for cg.
jonnyd is offline Find More Posts by jonnyd
Old May 31, 2010, 08:26 PM
donsinger1 is offline
Find More Posts by donsinger1
aka KF7DS
United States, OR, Portland
Joined Nov 2009
Mine is also at 72mm from leading edge along the fuselage. It is very stable at 1/2 to 2/3rds throttle and handles breezes very well.
Don
donsinger1 is offline Find More Posts by donsinger1
Old Sep 11, 2010, 08:58 AM
Germanjr is offline
Find More Posts by Germanjr
Joined Sep 2010
sky srufer beeping
hi
when i plug batery the motor beeping and beeping, no other action,no control nothing, what is the problem?
Germanjr is offline Find More Posts by Germanjr
Old Sep 11, 2010, 06:44 PM
Germanjr is offline
Joined Sep 2010
Originally Posted by Germanjr View Post
hi
jjjj
Old Nov 02, 2010, 02:49 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
ESC problem
jjjj
Bad ESC, maybe
AJ
Old Feb 18, 2016, 07:29 PM
seek1369 is offline
Find More Posts by seek1369
Joined Feb 2016
Having major troubles programming my Esc for Throttle .all control surfaces work but not Throttle I've watched several videos follow the instructions but nothing. Also I've seen some pictures where it looks like the throttle is reversed is that correct? So frustrated any help would be greatly appreciated.
seek1369 is offline Find More Posts by seek1369
Old Feb 18, 2016, 08:25 PM
Glacier Girl is offline
Find More Posts by Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
Well couple of things. #1 REMOVE the prop. You don't want a motor firing up when you don't expect it to.
Usually only Futaba radios have to have the throttle reversed.
Next, trim the throttle all the way down. And try it.
Next, Transmitter off, throttle pushed all the way on, then power up the transmitter.
Followed by the airplane. Listen for a couple of beeps or tones, and immediately move the throttle to off. You should hear a tone or two, followed by the esc arming tones.
If still not working, Plug the esc into another port on the receiver, and plug a servo into the esc port of the receiver. If the servo moves with the stick on the transmitter, you know you are getting a proper signal.
Glacier Girl is offline Find More Posts by Glacier Girl
Old Mar 23, 2016, 08:10 PM
AlphaCheck is online now
Find More Posts by AlphaCheck
AlphaCheck's Avatar
United States, CA, Los Alamitos
Joined Feb 2016
Thank you Glacier Girl!
I'm glad to see some current tips on the Sky Surfer as I just picked up a couple from BH.
All went smooth.
Happy Skies!
AC
AlphaCheck is online now Find More Posts by AlphaCheck
Discussion AXN Floater-Jet vs. Sky Surfer by banana superblue Electric Plane Talk 11 Aug 08, 2014 06:12 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion 4 Ch Sky Hawk Banana Hobby, tried this one ? wnppmy Beginner Training Area (Aircraft-Electric) 7 Mar 11, 2009 10:34 AM
Hobby Zone Sky Surfer ParaGlider (New in Box) sgil2001 Aircraft - Electric - Airplanes (FS/W) 6 Apr 16, 2002 01:46 PM
