This thread is privately moderated by alexedit, who may elect to delete unwanted replies.
Old Mar 01, 2010, 03:02 PM
alexedit is offline
Find More Posts by alexedit
Trader Rating: 17
alexedit's Avatar
United States, FL, Miami
Joined Dec 2008
Trader Rating: 17
Wanted
OS 61 SF head needed or other OS 61
I have an OS 61SF (round head) and I need the head for it. The spark plug hole is stripped.
Or - does anyone have any ideas how to fix this head. I don't think that it will ever be like it was before so I rather buy the head from someone
alexedit is offline Find More Posts by alexedit
Old Mar 01, 2010, 03:04 PM
alexedit is offline
Trader Rating: 17
alexedit's Avatar
Joined Dec 2008
Trader Rating: 17
Os sf
Old Mar 01, 2010, 03:32 PM
Comet1 is online now
Find More Posts by Comet1
Trader Rating: 99
Glued to the CA bottle
Sunny So Cal
Joined Aug 2008
Trader Rating: 99
Helicoil kits are available at Pep Boys , have to ask 1/4 x 32 is the size.
Or send to:
C.F.Lee Mfg.Co.
10112 Woodward Ave.
Sunland, CA 91040
(818)352-3766
Comet1 is online now Find More Posts by Comet1
Old Mar 01, 2010, 06:49 PM
alexedit is offline
Trader Rating: 17
alexedit's Avatar
Joined Dec 2008
Trader Rating: 17
thanks comet1, but I have a question...if you "re-thread" it...wont the hole be wider and the glow plug will not fit tight?
Old Mar 01, 2010, 06:55 PM
Trader Rating: 99
Sunny So Cal
Joined Aug 2008
Trader Rating: 99
Nope , it will have the same fit as original , have been using them for years on all types of stripped threaded holes
More info:
http://www.rcgroups.com/forums/showt...+thread+1+4+32
Old Mar 01, 2010, 07:15 PM
Trader Rating: 99
Sunny So Cal
Joined Aug 2008
Trader Rating: 99
About C. f. Lee:
http://www.craftsmanshipmuseum.com/Lee.htm
Old Mar 01, 2010, 07:16 PM
softlanding is offline
Find More Posts by softlanding
Trader Rating: 189
ann abor
Joined Jun 2003
Trader Rating: 189
Os 61 sf head
I have a good head with excellent threads i will sell shipped to you for $12 in the usa
softlanding is offline Find More Posts by softlanding
Old Mar 01, 2010, 07:22 PM
Trader Rating: 99
Sunny So Cal
Joined Aug 2008
Trader Rating: 99
Most excellent can't beat that deal
Old Mar 01, 2010, 09:24 PM
alexedit is offline
Trader Rating: 17
alexedit's Avatar
Joined Dec 2008
Trader Rating: 17
PM Sent -
Still wondering though about the re treating. Im going to try it and report back. I just think that re threating would eat more "meat" away from the engine so the glow plug would dance in the hole...I am not debating this...I have no doubt...I am just trying to understand it. :-D
Old Mar 01, 2010, 10:24 PM
SRush99 is offline
Find More Posts by SRush99
Trader Rating: 199
SRush99's Avatar
Spring, Texas
Joined Feb 2004
Trader Rating: 199
You would drill and tap the glowplug hole oversized. The helicoil is a threaded coil of thread "wire" that screws into the oversized threaded hole. Check out this link:
http://www.emhart.com/products/helic...iex/design.asp
SRush99 is offline Find More Posts by SRush99
Old Mar 02, 2010, 07:12 AM
alexedit is offline
Trader Rating: 17
alexedit's Avatar
Joined Dec 2008
Trader Rating: 17
OOOKKKK see now that I understand because then I'd be adding material to the head. Cool thank you all so much
Old Mar 02, 2010, 08:56 AM
Cougar429 is offline
Find More Posts by Cougar429
Trader Rating: 125
Cougar429's Avatar
Canada, ON, Windsor
Joined Apr 2008
Trader Rating: 125
Personally I have no reservations using them where the bolt goes in and stays there, but a better solution to helicoil in a temp and vibration environment is what is called a "Timesert":
http://www.timesert.com/
We used them for years to repair stripped plugs, some the result of automakers posting their 100K before the first tuneup. Ever try and pull a plug in an aluminum head that long?
p.s. I've seen too many helicoil inserts come out with the plug, or worse, thread inwards with the new plug to fall into the cylinder.
Cougar429 is offline Find More Posts by Cougar429
Wanted Wanted: YS .61 or the OS pumped .61 SF or Hanno Special le fou Aircraft - Fuel - Engines and Accessories (FS/W) 6 Jul 06, 2015 10:42 AM
Sold Os 61 SF tony0707 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Oct 09, 2009 07:32 AM
Help! OS 61 SF Pump Screws jjaypops Engines 0 Aug 28, 2009 11:29 AM
Wanted OS .61 FSR Round head needed lcyrace Aircraft - Fuel - Engines and Accessories (FS/W) 0 May 28, 2007 03:16 PM
OS 61 SF ABC, Sell or trade Fastandlow Aircraft - Fuel - Airplanes (FS/W) 0 Jan 09, 2004 05:25 AM
