Old Feb 28, 2010, 03:42 PM
N178EZ is offline
Find More Posts by N178EZ
Joined Dec 2009
RC Lander 90MM design flaw?
I purchased a LEDF90-1A16 90mmm RC Lander fan unit for a scratch built U-2. Very nice piece of hardware, but two very weird features (see pics). As I understand their concept, there are grooves cut into the circumference around the fan so they can have a zero gap fan to shroud interface (OK). Problem is there is what can only be described as a sharp trip on the inlet lip. This detail at the lead in to the fan will turbulate the flow at the wall/ blade tip and negate any affect having no gap might have added. The second feature is a .2" sharp step directly after the fan instead of the typical gradual increase in area downstream.
In my application I'm sure it will work fine, but Lander should consider changing the design. At a bare minimum they might get a few more % thrust that they could advertise. I also wonder if this is the discrepancy I've seen in many posts about the actual thrust vs what is shown on the You-tube videos. Do any of you have the other versions of their 90mm fan and do they have these goofy details in the shroud?
N178EZ is offline Find More Posts by N178EZ
Old Feb 28, 2010, 04:18 PM
Erik v. Schaik is offline
Find More Posts by Erik v. Schaik
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
IMHO It's an unfinished shroud. For milling one needs a teethed cutter to remove volume and a normal cutter for precision tolerance. The Shroud needs to be volume milled from 2 sides and finish milled after that . If they pre mill and finish one side and the other side after that you'd end up with an oval shroud. There are at least 3 clamp repositions to make this shroud and they forgot the last one. You are luckey the rotor gap is so big your rotor does fit in this unfinished dia.
go cheap,buy twice
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Old Mar 02, 2010, 07:12 AM
DominicM is offline
Find More Posts by DominicM
DominicM
DominicM's Avatar
Fleet, Hampshire, UK.
Joined May 2003
I didn't think they were cheap compared to a wemo...
DominicM is offline Find More Posts by DominicM
Old Mar 02, 2010, 09:15 AM
bruff is online now
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
My inlet is smooth, no sharp edges.
Bob
bruff is online now Find More Posts by bruff
Old Mar 02, 2010, 09:19 AM
N178EZ is offline
Joined Dec 2009
Remains to be seen. It was 150$. It seems like roughly the same or less than wemo if i had the time to trudge through a thousand threads to find a good enough 6S 6lb thrust motor setup.
More on the fan: It's a new version of their LEDF-90 series fan. It looks like the motor housing and everthing up to the stators is the same, but the fan shroud directly around the fan and the rotor are different. The rotor is 85mm not 90 and all of that goofy inlet stuff seems to be the change. The other versions of their 90mm fan look like no kidding 90mm and they have nice inlet lips and no step after the fan. The videos on line show them running both versions at about the same thrust. I'm skeptical though. The older "nice inlet" version is shown powered off of 6s packs while this new version is run off of a power supply. I've used power supplies enough to know you set the amps/ volts you want and go test. If this motor/ fan/ shroud geom can't pull 85amps then the online test is bunk. I'm inclined to send this thing back and get the older version. Thoughts??
Old Mar 02, 2010, 09:38 AM
turbonut is online now
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
A friend of my purchase one also! I did notice what you have posted! also it is not a 90mm as advertised it is 85mm..oops!
Scott
turbonut is online now Find More Posts by turbonut
Old Mar 02, 2010, 09:41 AM
Joined Dec 2003
What power range are you looking for?
Old Mar 02, 2010, 09:59 AM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Nothin' but a glass like finish on our Skyworld EDFs.
Now nickle plated.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Mar 02, 2010, 10:14 AM
efflux RC's Avatar
Joined Aug 2009
Originally Posted by plugandplay View Post
But theirs works and yours dosen't.
Remind me to NEVER buy from any vendor who would make a post like yours above. Bashing a competitor's product and promoting your own. Very unprofessional.
I didn't bash anything.
Our EDFs work fine. We have run our 70mm rotor to 1250 watts. We now have a balancer and will see how much we can increase that.
We now offer the Skyworld EDF kits only. Add your own motor, or use one of our ARC or Mega motors. Sorry, it would'nt be plug and play.
You sure are dogmatic for your 6th post. Welcome to RCG.
Site Sponsor
Old Mar 02, 2010, 10:29 AM
Socomon is offline
Find More Posts by Socomon
Joined May 2006
but theirs works and yours dosen't.
Remind me to never buy from any vendor who would make a post like yours above. Bashing a competitor's product and promoting your own. Very unprofessional.
Socomon is offline Find More Posts by Socomon
Old Mar 02, 2010, 10:37 AM
N178EZ is offline
Joined Dec 2009
I'm after 6lbs of thrust in bursts. 4lbs continuous. The RC lander may get me there, but I've got a lot of reasons to question that it will actually produce the book #'s. FWIW it's got a 85mm fan and it has the exact same #'s as their no kidding 90mm fan. That plus all of the weird aero features doesn't pass the sniff test. I'm really worried I've got a 4 lb-thrust fan not a 6 lb-thrust fan as advertised.
I think the old version may work fine. It's the one that has many videos on you-tube and does have a nice duct.
Matt
One Six Right is offline
Find More Posts by One Six Right
another MONSTER ?
One Six Right's Avatar
Valencia, CA
oops wrong thread
One Six Right is offline Find More Posts by One Six Right
Old Mar 02, 2010, 10:45 AM
Socomon is offline
Joined May 2006
Old Mar 02, 2010, 11:05 AM
Joined Dec 2003
Originally Posted by N178EZ View Post
I'm after 6lbs of thrust in bursts. 4lbs continuous. Matt
for 6s, low/mid range power:
post1-6: 1600w/2.8kg
http://www.rcgroups.com/forums/showthread.php?t=1170649
1400W:
http://www.rcgroups.com/forums/showp...postcount=1094
1700W
http://www.rcgroups.com/forums/showt...=59940&page=43
the 1700w link was quite a search because Herb used a smaller fan initially
I think you'r good enough with a midi and the $19.95 turnegy
All the best,
Erik
Old Mar 02, 2010, 11:35 AM
efflux RC's Avatar
Joined Aug 2009
Originally Posted by Socomon View Post
Stop and consider the source of this post for a moment. "plugandplay" is Mr. Curtis Mattikow of EasyTiger models.
I don't keep up with the banned and relabeled users. (except Gene )
But I've read plenty about the name.
It was a pleasure meeting him.
Site Sponsor
Discussion ESC for RC lander 90mm N178EZ Electric Ducted Fan Jet Talk 0 Feb 01, 2010 08:47 PM
Discussion RC Lander 90mm question techspy Electric Ducted Fan Jet Talk 17 Jan 19, 2010 05:44 PM
Discussion RC Lander in 2010? How about a 90mm T33 Shooting Star! Bajora Foamy EDFs 23 Jan 16, 2010 09:12 PM
Sold Rc Lander 90mm fan bruff Aircraft - Electric - Jets (FS/W) 3 Oct 26, 2009 08:26 PM
