Old Feb 28, 2010, 10:55 AM
pryor808 is offline
Find More Posts by pryor808
pryor808's Avatar
United States, NY, Medford
Joined Oct 2008
Sullivan Dynatron Starter
If I hook up my Dynatron starter to 24v, will it work on a DLE55?
pryor808 is offline Find More Posts by pryor808
Old Mar 01, 2010, 02:17 PM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
Maybe. But get ready for super fast spinning. I find 24v a chore to control and have seen others have the same problem. I have used a milwakee 18v battery drill with a 3" spinner insert to start G62's and DL50's. 18v might do you better if there is an easy way to do that. My dynatron easily starts my crrc40cc with a 12v garden tractor battery. Never tried my DL50. You might try a bigger 12v battery just for grins and see what happens. I know if you have a small battery that dynatron can suck a LOT of juice and bring a 12v gel cell to its knees. Just my opinion.
Edwin
edwin1 is offline Find More Posts by edwin1
Old Mar 01, 2010, 03:43 PM
proptop is offline
Find More Posts by proptop
Airplane Gearhead
Central N.Y.
Joined Jan 2005
Agreed...I think what you need is more cranking amps. A 12V. "Garden Tractor" battery from Wal Mart (or equiv.) is relatively inexpensive, and will allow the Dynatron to give you a LOT more torque that a small "motorcycle" size battery.
I have a Dynatron that I occasionally use w/ 2X 8 cell 3300 NiMh packs which give me lots of R.P.M. but what you need is torque.
proptop is offline Find More Posts by proptop
Old Mar 01, 2010, 08:28 PM
pryor808 is offline
pryor808's Avatar
Joined Oct 2008
I am currently running the Dynatron on a 12v gel cell and, the battery holds up fine but, then again I am only using it on my .91 size glow engines. I am adding another 12v battery in series to my flight box to get the 24v. I will try it first on my 26cc SV. I will let you guys know how it does.
Old Mar 02, 2010, 06:31 AM
edwin1 is offline
Joined Sep 2003
Careful with plastic spinners. I melted one on 24v.
Edwin
Old Mar 03, 2010, 12:33 PM
pryor808 is offline
pryor808's Avatar
Joined Oct 2008
Edwin
Thanks, I only use aluminum spinners. I gave up on plastic spinners when I saw a pilot starting a 40 size airplane and, the plastic spinner desintagrated and, a piece of plastic ended up in one eye. All I know is that he was rushed to the hospital. He did not belong to our club.
Old Mar 03, 2010, 05:00 PM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
Two words - SAFETY GLASSES.
Pinecone is offline Find More Posts by Pinecone
Old Mar 03, 2010, 10:14 PM
Ira NZ is offline
Find More Posts by Ira NZ
Bombs away! Err...landing
Ira NZ's Avatar
Upper Hutt, New Zealand
Joined Apr 2006
You absolutely must wear this any time anytime you even come within earshot of a glow engine. Don't even THINK of starting it!
Seriously, it's a freak accident. I once poked myself in the eye with a straw, should I wear safety goggles before drinking?
Ira NZ is offline Find More Posts by Ira NZ
Old Mar 04, 2010, 09:12 AM
I TOBOR is online now
Find More Posts by I TOBOR
I TOBOR's Avatar
Joined Feb 2007
Edwin
Actually its easier to burn one up with a weak battery because the engine stops on each compression stroke and the starter slips a little until it leaks off and spins to the next one. A strong battery just spins it, no stops on compression strokes.
I TOBOR is online now Find More Posts by I TOBOR
Old Mar 04, 2010, 04:01 PM
Pinecone is offline
Will fly for food
Maryland
Joined Sep 2004
Maybe YOU should.
Be seriously, there are plenty of accidents waiting to happen around engines. Safety glasses are a simple way to protect yourself.
It is funny, in the industrial world, you never see a guy who lost an eye NOT wearing safety glasses. Freak accident or not, it is very easy to lose an eye.
Old Mar 07, 2010, 03:07 PM
KB9STD is offline
Find More Posts by KB9STD
Joined Feb 2007
Try the 2 12volt batteries in parrallel.I thenk You will be surprised at the difference twice the cranking amps will make.
KB9STD is offline Find More Posts by KB9STD
Old Mar 15, 2010, 03:03 PM
mkk8 is offline
Find More Posts by mkk8
mkk8's Avatar
Turku, Finland
Joined Apr 2007
Dynatron and 6cell lipo...wow. DL55 started with one light touch on the propeller. I think it will spin everything under 100cc.
I borrowed it from my friend to start my .46 evolution and melted my spinner. Be careful with fluidlocks on small engines. I think Dynatron + 6S combo WILL break every shaft inside engine
mkk8 is offline Find More Posts by mkk8
Old Mar 23, 2010, 07:13 PM
crashxr is offline
Find More Posts by crashxr
rhode island
Joined Aug 2004
If you want to be able to start any engine...... the answer is a Miller belt reduction starter kit. Use your dynatron and add the Miller unit to it and you will never have a problem starting anything!!!!! You can purchase from Miller or Mac Hodges .If you do a search you will find the phone #'s for each of them. There is no web site to order from.
Here are the #'s
Mac Hodges 866-924-9505
Miller 707-833-5905
Spend the $125 and never have a problem turning over an engine again !
Bob
crashxr is offline Find More Posts by crashxr
Old Mar 25, 2010, 06:43 AM
Pinecone is offline
Will fly for food
Maryland
Joined Sep 2004
True, I think that setup with 24 volts on the Dynatron would start a truck engine, full scale truck, not model.
Old Mar 25, 2010, 08:06 AM
706jim is online now
Find More Posts by 706jim
Canada, ON, Thunder Bay
I was going to use one to drive a piston pump at my summer camp.
706jim is online now Find More Posts by 706jim
Wanted Sullivan Dynatron Starter cliffusaf Aircraft - General - Miscellaneous (FS/W) 3 Oct 25, 2009 05:20 PM
Sold Sullivan Dynatron Starter wjjones Aircraft - General - Miscellaneous (FS/W) 4 Oct 18, 2009 06:48 PM
Found Sullivan Dynatron Starter ncpiperpilot Aircraft - Fuel - Engines and Accessories (FS/W) 0 Oct 15, 2009 04:43 PM
Wanted Sullivan Dynatron Starter andernamen Aircraft - General - Miscellaneous (FS/W) 1 Sep 24, 2009 03:24 PM
Discussion Lost Sullivan Dynatron Starter w/Sullivan Heli Extension McLaren 114th RC Aero Squadron 0 May 31, 2009 08:20 AM
