Gallery
11" Diameter NutBall
Special thanks to goldguy for the design, i have a very awesome little flyer for my AR6400 that was sitting around. It can fly right off my front porch and hover like a 3d plane. I'm thinking of painting it like a pizza
![]() Specs: Channels - Throttle, Elevator, Rudder Motor and prop - PZ UM P-51 RX/ESC/Servos - AR6400 Battery - eFlite 3.7v 150 mah Foam - 3mm EPP Weight w/ Battery - 1oz or 27g |
Hawaii
Joined Oct 2009
Very nice. Isn't an ounce a bit heavy? Maybe upgrade to elevon mixing.
i was trying to figure out how do do the elevons on the brick but then i just decided to go with a rudder/elevator format. it works just fine. later though i might stick my AS2000 on it and go with a elevon/rudder setup.
I flew it some more today and its crazy cool. it can punch out of hovers and even roll with tight rudder ![]()
Hawaii
Joined Oct 2009
Thats pretty good. SO about 2x the speed of the vapor?
Joined Feb 2007
If it is crazy on the rolling side, you might consider adjusting the base of your rudder angling up so that it clears a full shape elevator instead of having the elevator cut out for rudder movement. About 17 degrees dihedral would also tame it a little I bet...
![]() Great job. Some video would be nice... |
Hawaii
Joined Oct 2009
Cool. It hovers at half throttle? I thought the Mustang motor has only 36 grams of thrust! Cool. Video!
its more crazy on the pitch side not the rolling but that would be a simple solution
try to get some better vid but heres one for for now http://www.rcgroups.com/forums/showt...6#post14475286 |
Hawaii
Joined Oct 2009
Sweet. Epp? Looks like depron. If flies very slowly even though much heavier then Vapor. COme on! Switch to elevon! Then you can roll…
Just move the left pushrod from rudder to elevator and cut in half!
Why Elevons?
I rigged elevons on my first NutBall. I wondered what the fuss was about since I didn't think it flew well at all. Then I re-read the original thread and tried rudder/elevator. Ah big improvement.
Elevons would probably be OK with reduced dihedral - or none like a Pizza Box Flyer. |
Hawaii
Joined Oct 2009
Ohhh. I just thought it would be cool becuase you could roll and do real aerobatics other then loops.
Hawaii
Joined Oct 2009
Cool.
| Category | Thread | Thread Starter | Forum | Replies | Last Post |
| Discussion | 10" NutBall | goldguy | Scratchbuilt Indoor and Micro Models | 37 | Mar 24, 2010 01:18 PM |
| Discussion | Whats the diameter of the Mini Edge 540 wing rod? | Speedfreak | 3D Flying | 2 | Jan 27, 2010 09:20 PM |
| Discussion | Airflow Outlet diameter to use? | CSI | Electric Ducted Fan Jet Talk | 4 | Jan 08, 2010 05:00 AM |
| Discussion | Love that Nutball! | BillL | Foamies (Scratchbuilt) | 1 | Sep 05, 2009 03:47 PM |
