Old Mar 04, 2010, 05:47 PM
elkay31 is offline
Find More Posts by elkay31
elkay31's Avatar
UK, Greater Manchester, Manchester
Joined Jan 2010
what would be the OD?? 3mm i'm guessing, and ID 1.5mm??
elkay31 is offline Find More Posts by elkay31
Old Mar 04, 2010, 05:57 PM
BACKEMFNRG is offline
Find More Posts by BACKEMFNRG
BACKEMFNRG's Avatar
Canada, ON, Acton
Joined Oct 2003
Barnes is international, They had a factory of some kind 15 minutes from me.
BACKEMFNRG is offline Find More Posts by BACKEMFNRG
Old Mar 04, 2010, 06:01 PM
Akura2 is offline
Find More Posts by Akura2
PROFESSOR TRUTH JIMMY ICE
Akura2's Avatar
Joined Sep 2003
Maybe as small as 2mm for the OTO/ZH bike... which would also work for the 1/5 scale if you are using fishing leader wire 40lb test or less
i have my OTO here with me at work, but no calipers....
Akura2 is offline Find More Posts by Akura2
Old Mar 04, 2010, 07:35 PM
scaulfi is offline
Find More Posts by scaulfi
Big thrills w/o hospital bills
scaulfi's Avatar
Brisbane, Australia
Joined Sep 2003
Originally Posted by brianlt29 View Post
I believe pat would use 2 layers of heat shrink tubing on the sadi thread.
This all sounds like dejavu to me, been down this road before.. lol
That was me that used to make/supply the Sadi thread cables for Pat all that time ago. For the 1/8 bikes I used 1 layer of heat shrink and 2 layers for the 1/5 bikes. In the end, the place I was getting it from went out of business so I ended up sourcing a local Spring and Steel company to make me the outer cable to the dimentions I wanted,.. they did me lengths by the meter; 0.4mm stainless with 2.5mm OD x 2mm ID and I used 40 - 60lb leader wire from the local fishing tackle store.. Now Pat gets his cables made the same way I think.
scaulfi is offline Find More Posts by scaulfi
Old Mar 04, 2010, 07:41 PM
BACKEMFNRG's Avatar
Canada, ON, Acton
Joined Oct 2003
Tks
Old Mar 04, 2010, 07:53 PM
Guidoracer is offline
Find More Posts by Guidoracer
Guidoracer's Avatar
United States, CA
Joined Nov 2004
Shaun -- that is great info -- thanks!
Guidoracer is offline Find More Posts by Guidoracer
Discussion Wanted - Pats Brakes JDCrow Motorcycles 4 Aug 05, 2007 06:18 AM
Discussion i need some info on mounting bracket for pats front brakes nitro_nutts Motorcycles 4 Feb 03, 2006 08:08 AM
Discussion couplers for pats brakes nitro_nutts Motorcycles 2 Jan 23, 2006 08:09 PM
TT Nitro with Pats brakes. GAZ NITRO Motorcycles 25 Aug 24, 2005 09:55 AM
Pats Brakes cable layout? edv2122 Motorcycles 16 Apr 22, 2005 10:19 PM
