Old Mar 02, 2010, 10:40 PM
brianlt29 is offline
Find More Posts by brianlt29
Redlands, California
Joined Nov 2004
This is what's used for the outer cables. It's Pearl Sadi Thread (coiled) fine gauge. It's usually sold in 2 meter lengths. Then cover with some 1/16" heat shrink tubing and you've got your outer cable. I use sevenstrand Duratest 40 lb for the inner cables.
brianlt29 is offline Find More Posts by brianlt29
Old Mar 02, 2010, 11:37 PM
BACKEMFNRG is offline
Find More Posts by BACKEMFNRG
BACKEMFNRG's Avatar
Canada, ON, Acton
Joined Oct 2003
That is better stuff, though Boullion will work
BACKEMFNRG is offline Find More Posts by BACKEMFNRG
Old Mar 03, 2010, 11:59 AM
Akura2 is offline
Find More Posts by Akura2
PROFESSOR TRUTH JIMMY ICE
Akura2's Avatar
Joined Sep 2003
I looked at (and bought) the boullion AND the pearl Sadi Thread, but the one I got was WAY too soft and springy and wouldn't hold up to use as a cable housing
Akura2 is offline Find More Posts by Akura2
Old Mar 03, 2010, 12:21 PM
BACKEMFNRG's Avatar
Canada, ON, Acton
Joined Oct 2003
You would be very surprised how strong it gets with 1 or 2 layers of heat shrink on it.
Pat1967 used this stuff in the beginning, not sure now??
Old Mar 03, 2010, 01:14 PM
Joined Nov 2004
I believe pat would use 2 layers of heat shrink tubing on the sadi thread.
Old Mar 03, 2010, 01:21 PM
Akura2 is offline
Akura2's Avatar
Joined Sep 2003
I'm still trying to find the stuff that comes on the OTO bike and the TT Nitro... it's a heavier spring that doesn't need any shrink wrap... the people that can get that stuff have been very tight-lipped...(I guess it's not to reveal their sources and sell the stuff themselves)
the stuff I'm looking for has a conical end to it which allows you to screw on end into the other and make a continuous circular spring (maybe something that goes around a motor piston)... you just cut the conical end off and viola! brake cable housing... I'll post a pic when I get home for those that are not getting it
Old Mar 03, 2010, 01:57 PM
slawsonb is offline
Find More Posts by slawsonb
Bruce
Palmdale, CA
Joined Sep 2005
Not sure if I can but I'll see if I can get the OTO/ZH housing in bulk.
Bruce
slawsonb is offline Find More Posts by slawsonb
Old Mar 03, 2010, 02:02 PM
BACKEMFNRG's Avatar
Canada, ON, Acton
Joined Oct 2003
I get it, that rings a bell now!
Old Mar 03, 2010, 03:31 PM
Akura2 is offline
Akura2's Avatar
Joined Sep 2003
Bruce
that would be awesome... been looking for that stuff literally for years
Old Mar 03, 2010, 06:17 PM
Akura2 is offline
Akura2's Avatar
Joined Sep 2003
found it... it's called "garter spring".... now I just need to find some place that will sell it
Old Mar 03, 2010, 07:37 PM
Jonathan Bradbury is offline
Find More Posts by Jonathan Bradbury
Occasional useful idiot...
Joined Nov 2009
Good find!!! Bobbed 'Garter spring' into google and got lots of choices. Ask the manufacturers who buys it for retail if they will not send samples.
Can't help further than that, sorry.Here is one based in LA that could help you http://www.centuryspring.com/
Jonathan Bradbury is offline Find More Posts by Jonathan Bradbury
Old Mar 04, 2010, 04:31 AM
Lukey B is offline
Find More Posts by Lukey B
Me Likee Motorbikee
Lukey B's Avatar
Melbourne Australia
Joined Nov 2009
Akura2.... If that's what I think it is.... it's the same spring stuff they use in seals (wheel bearings... fork seals... just about all seals I know of) in 1-1 cars and bikes, sometimes if you can't get a replacement seal in time, we would cut a little off the spring, and wind it back together, fit it back in the seal and it would ussually help fix the leak, temporarly anyway....
Lukey B is offline Find More Posts by Lukey B
Old Mar 04, 2010, 02:06 PM
Akura2 is offline
Akura2's Avatar
Joined Sep 2003
ya.. that's what it's designed for... but finding a source seems to be a challenge... everyone wants you to send for a quote, and jump through hoops... all I'm looking for is enough to fix my bikes when needed, and maybe help some friends out..
Old Mar 04, 2010, 05:02 PM
BACKEMFNRG's Avatar
Canada, ON, Acton
Joined Oct 2003
Talk to a GM mechanic or something, he may have a piece kicking around...
Old Mar 04, 2010, 05:45 PM
elkay31 is offline
Find More Posts by elkay31
elkay31's Avatar
UK, Greater Manchester, Manchester
Joined Jan 2010
I think i found somewhere you can order specific dimensions, heres a link to the size gauging, let me know if you can see it, if not i'll cut and copy the graph amd mail it to anyone who wants it, its based in the UK.
Lee.
http://www.assocspring.co.uk/SPECII/...&Action=Submit
elkay31 is offline Find More Posts by elkay31
Discussion Wanted - Pats Brakes JDCrow Motorcycles 4 Aug 05, 2007 06:18 AM
Discussion i need some info on mounting bracket for pats front brakes nitro_nutts Motorcycles 4 Feb 03, 2006 08:08 AM
Discussion couplers for pats brakes nitro_nutts Motorcycles 2 Jan 23, 2006 08:09 PM
TT Nitro with Pats brakes. GAZ NITRO Motorcycles 25 Aug 24, 2005 09:55 AM
Pats Brakes cable layout? edv2122 Motorcycles 16 Apr 22, 2005 10:19 PM
