Old Feb 27, 2010, 04:29 PM
elkay31 is offline
Find More Posts by elkay31
elkay31's Avatar
UK, Greater Manchester, Manchester
Joined Jan 2010
Help!
Pats brakes outer cable needed!
Hi all, i have just bought a used front pair of Pats brakes in great condition, but they do not have the inner or outer cables for them, does anyone know if the outer cables can be bought or maybe suggest a suitable alternative for them? It looks like they slip inside the small hexagonal bolt on the caliper which is then clamped with a small grubscrew.
Thanks in advance, Lee.
elkay31 is offline Find More Posts by elkay31
Old Feb 27, 2010, 04:44 PM
test driver is online now
Find More Posts by test driver
newcastle Australia
Joined May 2004
contact scaulfi on this forum
test driver is online now Find More Posts by test driver
Old Feb 27, 2010, 04:48 PM
elkay31 is offline
elkay31's Avatar
Joined Jan 2010
Thanks.
Old Feb 27, 2010, 06:49 PM
scaulfi is offline
Find More Posts by scaulfi
Big thrills w/o hospital bills
scaulfi's Avatar
Brisbane, Australia
Joined Sep 2003
I think I still have some left, but I need to know the lengths you need, you don't want to be short..
scaulfi is offline Find More Posts by scaulfi
Old Mar 02, 2010, 06:27 AM
Lukey B is offline
Find More Posts by Lukey B
Me Likee Motorbikee
Lukey B's Avatar
Melbourne Australia
Joined Nov 2009
Hey guys... don't know if anyone else has tried this.... but for my venom( I know it's not 1/5th but still uses the same principle) I went to K-Mart of all places... and I bought a packet of "trace line", in the fishing department... there is heaps of different gaudges, and the quality is far better than anything I can find at a hobby store.... and you can also buy crimp tubes to fit... really cheap, good gear, and you get enough for about 10 pairs of brake cables too.....
Still haven't found anything for outer yet though....
hope it helps someone out...
..Luke..
Lukey B is offline Find More Posts by Lukey B
Old Mar 02, 2010, 06:31 AM
Torrance is offline
Find More Posts by Torrance
Torrance's Avatar
Joined May 2009
antenna tubes perhaps?
Torrance is offline Find More Posts by Torrance
Old Mar 02, 2010, 06:37 AM
Lukey B is offline
Me Likee Motorbikee
Lukey B's Avatar
Melbourne Australia
Joined Nov 2009
And here is some pics.....
Old Mar 02, 2010, 06:38 AM
Lukey B is offline
Me Likee Motorbikee
Lukey B's Avatar
Melbourne Australia
Joined Nov 2009
I've tried antenna tubes... but they're way too stiff for the little bikes...
Old Mar 02, 2010, 02:39 PM
elkay31 is offline
elkay31's Avatar
Joined Jan 2010
Great Idea Lukey, gonna get some and deffo try it out, I used an electric guitar string(the top E, for those who play) seems to work ok....
Old Mar 02, 2010, 03:08 PM
Akura2 is offline
Find More Posts by Akura2
PROFESSOR TRUTH JIMMY ICE
Akura2's Avatar
Joined Sep 2003
you can also use leader line... I use that all the time on my bikes.... nylon-coated steel leader line... and it come in various strengths..
as far as the outer housing, I've been looking for a local source for years (literally)
Akura2 is offline Find More Posts by Akura2
Old Mar 02, 2010, 03:22 PM
Allan Waterfall is offline
Find More Posts by Allan Waterfall
No Shelf Queens.No Bling
Allan Waterfall's Avatar
Newark.Nottinghamshire.UK
Joined Jan 2005
My local model shop which is mainly plane orientated sells lead out wire for controle line models,they also sell a nylon outer in three ft. lengths which the wire slides in nicely.
I don't know what it's called but I believe it's what the electric fliers use for routing closed loop systems through fuselages,it's about 2mm OD.
It can be made to hold a curve by a quick warm with a cigarette lighter.
You can see it in the bottom pic..
Allan
Allan Waterfall is offline Find More Posts by Allan Waterfall
Old Mar 02, 2010, 03:42 PM
DEISEL is offline
Find More Posts by DEISEL
OLD ROAD RACER
LAKEWOOD CO.
Joined Jan 2010
Brake cable
Hi I think this is what i used it worked great bought it at a hobby shop.
sullivan #s507 tower #is lxfu94 it has a yellow jacket and brass coated stainles cable it is the same as what nf bikes come with.
DEISEL is offline Find More Posts by DEISEL
Old Mar 02, 2010, 04:39 PM
Akura2 is offline
Akura2's Avatar
Joined Sep 2003
the only thing don't like about that stuff is that it frays... especially when you have to make more than one adjustment... and once it's frayed you may NEVER remove it from it's jacket or you won't get it back in
Old Mar 02, 2010, 07:25 PM
DEISEL is offline
OLD ROAD RACER
LAKEWOOD CO.
Joined Jan 2010
brake cable
Hi Thats why its brass coated so you can tin the end with soulder.
Old Mar 02, 2010, 09:09 PM
BACKEMFNRG is offline
Find More Posts by BACKEMFNRG
BACKEMFNRG's Avatar
Canada, ON, Acton
Joined Oct 2003
I've mentioned at NAUSEUM that to make the outher sheths is a piece O cake!
just get "French wire" or "Boullion" (Med size) from Ebay for a couple bucks, some heat shrink & K&S tubing and make yourself with above fishing gear.
If you want a link just ask, getting tired of digging it up for no reason.
Almost identicle to Pats brake cables.
BACKEMFNRG is offline Find More Posts by BACKEMFNRG
Discussion Wanted - Pats Brakes JDCrow Motorcycles 4 Aug 05, 2007 06:18 AM
Discussion i need some info on mounting bracket for pats front brakes nitro_nutts Motorcycles 4 Feb 03, 2006 08:08 AM
Discussion couplers for pats brakes nitro_nutts Motorcycles 2 Jan 23, 2006 08:09 PM
TT Nitro with Pats brakes. GAZ NITRO Motorcycles 25 Aug 24, 2005 09:55 AM
Pats Brakes cable layout? edv2122 Motorcycles 16 Apr 22, 2005 10:19 PM
