Old Feb 27, 2010, 02:19 PM
randy57 is offline
Find More Posts by randy57
Joined Feb 2010
14dbi 2.4GHz patch antenna with EagleEyes ground station
I'm using this 2.4GHz patch antenna with the EagleEyes Antenna Tracker. It seems to function fine but I'm worried the antenna may be too heavy and putting a strain on the structure of the antenna tracker and the gears and motors in the servos. What do you guys think? Should I downgrade to the 8dbi antenna? Should I use different servos? I'm currently using the stock servos (HS-485HB)
randy57 is offline Find More Posts by randy57
Old Mar 03, 2010, 05:08 PM
Mr.Pibb is offline
Find More Posts by Mr.Pibb
Mr.Pibb's Avatar
Lewis Center, OH
Joined Jun 2006
You should be fine as long as you have the receiver mounted on the back side of the tilt mount (or some other counter weight). I use an 8dBi 900MHz antenna and the 11dBi 2.4GHz diversity antenna which are both the same size and approximately the same weight with no issues.
Tim
Mr.Pibb is offline Find More Posts by Mr.Pibb
Site Sponsor
For Sale 2.4ghz Video system - 2 tx, High Res Camera, Patch Antenna- Sweet Deal!!!!! wac Aircraft - Electric - Airplanes (FS/W) 2 May 30, 2010 10:04 AM
New Product DealExtreme.com: 2.4GHz 14dBi Flat Panel Antenna for Wifi/Wireless Network CrashingDutchman FPV Talk 17 Jun 23, 2009 02:40 PM
Question What Patch Antenna for Video Ground Station ? Tatty Aerial Photography 15 Mar 21, 2009 09:55 AM
Discussion Problem with video signal.. 14dBi patch antenna! kenzky FPV Talk 17 Dec 12, 2008 01:43 PM
Hawking 802.11b/g 2.4Ghz 14Dbi High Gain Antenna mckaneorg UAV - Unmanned Aerial Vehicles 6 Nov 07, 2005 12:06 PM
