Old Feb 27, 2010, 08:52 AM
ka244mog is offline
Find More Posts by ka244mog
ka244mog's Avatar
United Kingdom, England, Blyth
Joined Jan 2005
Idea
Let new bikers see what your using
HI ALL I AM NEW HERE ONLY BEEN USING THIS FORUM AFTER GETTING MY SELF THE ANDERSON M5 ...
WAS UNSURE WHAT TO USE IE MOTO/ESC AND LIPOS NEVER USED ELECTRIC MODELS ..
AFTER A BIT OF HELP FROM THE MEMBERS HERE THIS IS WHAT I HAVE ENDED UP WITH ..
MOTO EZRUN 5.5 6000KV
ESC EZRUN 60 AMP WITH PROGRAM CARD
LIPOS 2 CELL 3200 MAP 25C CONSTANT AND 30 C BURST HARD CASE ..
NEVER RAN IT YET WITH THE LIPOS BUT I HAVE USED THIS SET UP WITH A 4000MAH NIMH AND COULD NOT GET IT TO WHEELY .GOT SMALL AMOUNT OF LIFT ON FRONT WHEEL .. BUT IT WAS ..
FAST IN A STRIGHT LINE ..
ka244mog is offline Find More Posts by ka244mog
Old Feb 27, 2010, 10:22 AM
rpedro is offline
Find More Posts by rpedro
NO PRESSURE NO DIAMONDS
The Woodlands, TX
Joined Dec 2009
first thing... turn off the CAPS!!! seriously, why must all rooks type in CAPS??? THIS IS WHAT IT LOOKS LIKE!!! glad to hear you are having fun, but typing in lower case will help you a lot better on here...
rpedro is offline Find More Posts by rpedro
Old Feb 27, 2010, 10:28 AM
Timmahh is offline
Find More Posts by Timmahh
Michigan, Tri City area
Joined Jun 2006
the EZRun 35A ESC isnt large enough to handle the amnp draw needed to spool up the gyro. the 60A should be better. but MAY be a smidge on the small side. If it shuts down trying to run on you. the ESC will be a bit too small (Amp wise).
but if it can deal with the amp draw, it should be a good ESC. 6000KV motor will be a handfull to handle i think. let us know how you make out.
Timmahh is offline Find More Posts by Timmahh
Old Feb 27, 2010, 01:39 PM
ka244mog is offline
ka244mog's Avatar
Joined Jan 2005
hi sorry for the caps .. like i said bike was fast on my setup
5.5 6000kv moto / 60amp esc /and runnning on 4000mah nimh .was fast
but no wheely ..
also is there any way of stopping the rear tyre from balloning off ..
Old Feb 27, 2010, 02:21 PM
test driver is offline
Find More Posts by test driver
newcastle Australia
Joined May 2004
This might sound strange but at what rate did you charge the nimh battery? If you only charged it at 1amp then it probably won't deliver enough punch. You need to charge it at 4-5 amps so it will deliver the iniial current required. With the lipos it will be a different matter as they will be substantially lighter and let it wheelie a lot easier (only charge lipos with a lipo charger at their specified charge rate though)
test driver is offline Find More Posts by test driver
Old Feb 27, 2010, 02:42 PM
ka244mog is offline
ka244mog's Avatar
Joined Jan 2005
hi i have been charging the nimh at 1amp... was told not to put anymore than 1.5 amps in as i would kill battrie quicker .. should i now charge it at 4/5 amps the batrrie has been charged about 6 times ..
used to using lipos as i have these in my rc helicopters for the reciver packs and allways use a v balancer .when charging them ..
Old Feb 27, 2010, 02:56 PM
newcastle Australia
Joined May 2004
the only time I ever charge my nimh batteries that low is when they are used for receiver packs in my 1/6 scale truck or airplanes. generally then I want longevity out of the pack not punch. When charging at the higher rate, they down supply the charge for as long but, deliver more power while they do deliver.
I would suggest charging them at the higher rate now and you should notice the difference.
Old Feb 27, 2010, 03:24 PM
ka244mog is offline
ka244mog's Avatar
Joined Jan 2005
ok will try charging at 4amps see if it makes a diffrence ...
Old Mar 02, 2010, 12:15 PM
ka244mog is offline
ka244mog's Avatar
Joined Jan 2005
wow just been out with the bike on large muddy field .
running on my new 32000 lipos /60amp esc and 6000kv moto ..
never had such fun .. bike was balistic .. mud flying everywere....and wheelys like mad .. quick pull on the throttel and the front wheel was in the air ...
managed to snap my rear mud gaurd clean off the bike .. oh such fun ...
the best fun i have had in ages
Old Mar 03, 2010, 12:53 AM
Risknreward is offline
Find More Posts by Risknreward
Risknreward's Avatar
Joined May 2009
Never too old to play in the dirt
Risknreward is offline Find More Posts by Risknreward
Gallery Let's see your boats flailing Scale Boats 257 Mar 08, 2012 01:38 PM
Discussion Let's see your SLR rig muidaq Aerial Photography 2 Dec 11, 2009 07:31 PM
Discussion Let's see what's in your hangar!! jwhitacre Sailplane Talk 0 Aug 23, 2008 02:27 PM
Idea Let's see your sloper pics! Ben74 Slope 161 Aug 04, 2005 05:44 PM
Let's see your Pumkins! Troy Life, The Universe, and Politics 27 Nov 07, 2002 11:00 PM
