Old Feb 27, 2010, 07:40 AM
HugePanic is offline
Find More Posts by HugePanic
German Engineering.......
HugePanic's Avatar
Auxsburg
Joined Dec 2007
Raptorski: another 6mm depron slot-jet
Here are some pictures of my slot-jet Raptorski.
Modeled after the PAK FA Sukhoi T50 jet that maidend a couple of weeks ago.
Inspiration is (obvious) the F22 build thread here at rcgroups.
Servos: HXT-900
Motor: eMAX CF2822
BEC: 18 Turnigy
Battery: 3s1000mah Lipo
Prop: 8x6 APC-Style
Total weight is about 480g
It flies very good. Stable like a jet with lots of elevator authority, but it is also very stable.
Roll rate could be better, maybe i will add ailerons later. 1 roll per second is possible at the moment.
Its not very fast, but i plan to experiment with props in the near future. The slot can be increased to fit 9" props if needed, but i plan to install so a 9x8 prop cut back to 8" diameter.
mfg
Ich
HugePanic is offline Find More Posts by HugePanic
Old Feb 27, 2010, 08:50 AM
inline300 is offline
Find More Posts by inline300
Joined Jan 2009
looks good
inline300 is offline Find More Posts by inline300
Old Feb 27, 2010, 12:17 PM
HugePanic's Avatar
Auxsburg
Joined Dec 2007
some inflight fotos from the raptorski...
Old Mar 03, 2010, 01:32 PM
Vanish is offline
Find More Posts by Vanish
Concept Builder
Vanish's Avatar
United States, CO, Boulder
Joined Feb 2008
Looks good!
Vanish is offline Find More Posts by Vanish
Old Mar 03, 2010, 07:15 PM
pcfisher66 is offline
Find More Posts by pcfisher66
Frequent Crasher Club
pcfisher66's Avatar
Crestview, FL
Joined Sep 2007
Nice looking jet!
pcfisher66 is offline Find More Posts by pcfisher66
Old Mar 03, 2010, 07:54 PM
cdebaca is offline
Find More Posts by cdebaca
cdebaca's Avatar
USA
Joined Oct 2005
Nice! thanks for sharing.
cdebaca is offline Find More Posts by cdebaca
Old Mar 03, 2010, 08:06 PM
Giedi_Prime is offline
Find More Posts by Giedi_Prime
When I fly, Birds attack
Giedi_Prime's Avatar
Aveiro, Portugal
Very very nice
Giedi_Prime is offline Find More Posts by Giedi_Prime
Old Mar 04, 2010, 12:05 AM
drew1231 is offline
Find More Posts by drew1231
drew1231's Avatar
Joined Jan 2009
Very good looking!
drew1231 is offline Find More Posts by drew1231
Old Mar 04, 2010, 01:41 AM
starscream4002 is offline
Find More Posts by starscream4002
starscream4002's Avatar
Tabriz, Iran
Joined Sep 2008
very very nice!!! I bet you can get it much "nicer" with making it a thrust vectored jet
starscream4002 is offline Find More Posts by starscream4002
Old Mar 04, 2010, 01:56 AM
rudes is offline
Find More Posts by rudes
Australia Sunshine Coast
Joined Sep 2007
HugePanic been trying to figure out how to hide all the radio gear battery etc. very nice build.
The wing is all one piece right through to the tip of the fuse ????. Can you please show where your battery is.
Any chance of a straight on from the front up slightly picture so that I can see the shape of the fuse please.
Thanks great idea
Rudolf
rudes is offline Find More Posts by rudes
Old Mar 04, 2010, 08:31 AM
HugePanic's Avatar
Auxsburg
Joined Dec 2007
Thanks great idea
Rudolf
battery is inside the fuselage, the servos are inside the pods.
here is a picture, the best i have for the moment.
basically it's pretty easy, since all the stuff is inside the fuse....
the wing is is one part of flat foam. fuse obove, pods below.
i just added the tail and nose section to the center piece, to save material.
(the idea was to use just one sheet of 0.8m x1.25m depron)
Old Mar 04, 2010, 04:55 PM
drew1231 is offline
drew1231's Avatar
Joined Jan 2009
you could always go with the classic battery cage on the bottom.
Old Mar 05, 2010, 01:57 AM
rudes is offline
Joined Sep 2007
Thanks heaps HugePanic the photos make it so much easier. Any other photos would be great.
Thanks again
Rudolf
Old Mar 07, 2010, 03:37 AM
rudes is offline
Joined Sep 2007
4 hours later and nearly ready for 2 coats of WBPU
Old Mar 21, 2010, 03:13 PM
HugePanic's Avatar
Auxsburg
Joined Dec 2007
finally it was too less "stealth"....
they were close behind me.... no chance of escape....
Build Log Prop in slot Kfir / Mirage 6mm depron Blueangels4 Pusher Prop Jet Models 4 Oct 23, 2013 05:28 PM
Discussion 6mm depron mini rc plane h max_mac Foamies (Scratchbuilt) 4 Dec 21, 2011 08:40 AM
Question 6mm Depron beemerdon Charlotte Area Flyers 0 Jan 26, 2010 09:45 AM
Discussion Any recommendations for a 3D from single sheet 6mm Depron RJPIoW Foamies (Scratchbuilt) 2 Jan 10, 2010 04:12 AM
Discussion 6mm depron glider max_mac Scratchbuilt Indoor and Micro Models 1 Jan 09, 2010 02:36 PM
