Old Feb 26, 2010, 10:03 PM
Scratch building addict
rotagen's Avatar
United States, CA, Felton
Joined Jan 2005
What prop for a 2.3mm shaft w/ prop saver
Hey all, this is the first time I have made a model with a 2.3mm high KV (2250kv) motor, its the aurora 300df. I've calculated that a 5x3 or 5x4 prop should work well as direct drive, so I ordered some (I think they are GWS direct drive props)..
Long story short I had to drill the prop hole larger to keep the prop from bending around the conical saver so easily, and the o-ring is too lose for my liking as well.
So what prop brand and type do you think would be good for this motor?
I'm new to jets and high kv planes.
Also, anyone have any data or experience with this motor from justgofly.com?
thanks
rotagen is offline Find More Posts by rotagen
Old Feb 26, 2010, 10:10 PM
Joined Jul 2006
I'm really confused here. How does a prop bend around a prop saver????
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Feb 26, 2010, 10:32 PM
rotagen's Avatar
Joined Jan 2005
Basically due to the relatively small hole in the prop, and the larger conical shape of the prop saver, the prop was not stable on the saver.
As in it could be easily moved from side to side with my fingers.
Old Feb 26, 2010, 11:01 PM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Don't use a prop saver on a 300DF motor (far too dangerous on such a high Kv motor)... get a Graupner CAM 4x3 or 4.7x4.7 and a 3.2mm collet prop adapter. I never dared run my test motor (MTM 300DF) on 3s in direct drive, but if you do, you'll be around 20,000rpm... remember that motor is rated for maybe 7A max [http://ecsvr.com/RC-Direct/shopexd.asp?id=955].... a 4x3 may take it to 10A+, and a 4.7x4.7 may have it at 13A or so.
If I misunderstood and you are using 2s, then a Graupner 4.7x4.7 might be okay.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Feb 27, 2010, 12:04 AM
rotagen's Avatar
Joined Jan 2005
According to justgofly they run them direct drive all the time ?
They have some charts there with prop sizes and amps, most are under 10 amps even 5.5 x 4.5 or so ranges.
I guess I'll give them a call and see what they suggest, I also bought a gws type adapter regular screw on type...colette adapters are not for me, talk about a dangerous mechanism.!
guess I'll stick to drilling for now, remember, with small props even though the kv is a little high, the amps will be lower.
Old Feb 27, 2010, 09:14 AM
Dr Kiwi's Avatar
Joined May 2003
Here is what Vinnie has to say: the amp limit has been raised to 10A, so it looks as if a 4.75x4.5 might be okay on 3s if you are looking for good pitch speed. That RPM at only 66% of Kv x V is an indicator that the motor is somewhat over-loaded (75% is the typical target)... and obviously anything bigger (5.5x4.5) would NOT be suitable.
On smooth shafts, collet adapters are far more secure than the set-screw type! The set-screw type are okay if the shaft has a flat on it, but even then I don't trust them very much.
Old Feb 27, 2010, 01:29 PM
rotagen's Avatar
Joined Jan 2005
Yeah thats the chart I was using. I'm hoping my model is light enough to just use the gws 5x3 props, if not I will switch to 5x4 (my pusher model design doesnt allow anything larger than 5 diameter anyways).
Funny, I have had the opposite experience at least with GWS props, had a collette adapter fall off repeatedly until I switched to the dual screw prop savers. I just dont think you get near enough pressure clamping the collette down.
Thanks for your help, my model should be around 9 oz with 2s or 10 ounces with 3s. I want only medium speed (which will still be fast for this little jet), so I'm hoping 5x3 will work for this size model.
Old Feb 27, 2010, 06:54 PM
Dr Kiwi's Avatar
Joined May 2003
5x3 GWS HD will be okay at the 2s rpm, but on 3s it might be at its rpm limit.
Old Feb 28, 2010, 04:12 PM
Rochester, NY
JustGoFly's Avatar
United States, NY, Monroe
Joined May 2004
Prop Savers are not healthy on the high rpm 300DF. I used them for a while and ran two small bands cut from silicon tubes, but started running prop adapters after I threw a bunch of props. The high RPM will still shatter the prop on a full throttle prop strike - even with a prop adapter. And flying props at over 20,000 RPM could be very harmful to you and your co-flyers.
The benefit of the prop saver is it may keep the tiny shaft from snapping. Use two or more bands to hold on the prop. Make sure it seats well and doesn't make a high noise or your unbalanced. Imbalance can toss props or even wreck mounts. Never run up the prop when someone is standing behind the blade - even the side of the motor is not safe - so clear the rear of the plane totally.
Enjoy,
Vinnie
JustGoFly is offline Find More Posts by JustGoFly
Old Feb 28, 2010, 05:57 PM
Dr Kiwi's Avatar
Joined May 2003
I just don't think you get near enough pressure clamping the collet down.
Here is how to get plenty of pressure on a collet adapter!
Old Feb 28, 2010, 11:03 PM
rotagen's Avatar
Joined Jan 2005
cool, thanks for your help guys
Question How to mount a 4mm prop on a 3mm shaft? gobigkahuna Submarines 4 Jan 10, 2010 07:15 AM
For Sale SMOKED Neu 1107/2y w/ 2.3mm shaft Matthew Cotten Aircraft - Electric - Power Systems (FS/W) 0 Oct 17, 2009 07:50 PM
Discussion What Size Replacement Prop For Harborfreight P-51 Mustang..Also want a Prop saver goodoleboy Electric Plane Talk 1 Sep 29, 2009 07:56 AM
Help! 3mm Shaft Prop-Saver and GWS 8x4 HD Props - How to get wobble free? wingnutt Foamies (Scratchbuilt) 1 Jul 10, 2008 08:39 AM
Discussion APC prop w/ high power motor and 3mm prop saver? JWilliams2 Power Systems 8 Apr 17, 2007 12:55 PM
